28th February 2007, 15:42 | #682 | Link | |
http://www.w6rz.net/xport.zip This is version 0.93 (I just started counting at 0.9). For the sample file: Code:
C:\xfer>xport -h head.m2ts 1 1 2 xport Transport Stream Demuxer 0.93 program = 1, video channel = 1, audio channel = 2 Program Number = 0 (0x0000), Program Map PID = 31 (0x001f) Program Number = 1 (0x0001), Program Map PID = 256 (0x0100) program descriptor = 0x05, 0x04, 0x48, 0x44, 0x4d, 0x56 program descriptor = 0x88, 0x04, 0x0f, 0xff, 0xff, 0xfc Video PID = 4113 <0x1011>, type = 0x02 ES descriptor for stream type 0x02 = 0x05, 0x08, 0x48, 0x44, 0x4d, 0x56, 0xff, 0 x02, 0x61, 0x3f ES descriptor for stream type 0x81 = 0x05, 0x04, 0x41, 0x43, 0x2d, 0x33 ES descriptor for stream type 0x81 = 0x81, 0x04, 0x06, 0x48, 0x0e, 0x00 Audio PID = 4353 <0x1101>, type = 0x80 ES descriptor for stream type 0x80 = 0x05, 0x08, 0x48, 0x44, 0x4d, 0x56, 0xff, 0 x80, 0x61, 0x7f ES descriptor for stream type 0x81 = 0x05, 0x04, 0x41, 0x43, 0x2d, 0x33 ES descriptor for stream type 0x81 = 0x81, 0x04, 0x06, 0x48, 0x0e, 0x00 Sequence Header found 0 frames before first Sequence Header Horizontal size = 1920 Vertical size = 1080 Aspect ratio = 16:9 Frame rate = 23.976 Sequence header bitrate = 30000000 bps Progressive Sequence = 1 First Video PTS = 0x000ffff0 LPCM Audio Mode = 3/2+lfe LPCM Audio Bits/sample = 16 LPCM Audio Sample Rate = 48000 ts rate = unspecified, video rate = 15194822 packets for pid 0 <0x0000> = 205, first = 1, last = 259620 packets for pid 31 <0x001f> = 22, first = 3, last = 254928 packets for pid 256 <0x0100> = 205, first = 2, last = 259621 packets for pid 4097 <0x1001> = 214, first = 4, last = 259429 packets for pid 4113 <0x1011> = 180949, first = 5, last = 260315 packets for pid 4352 <0x1100> = 8688, first = 246, last = 260283 packets for pid 4353 <0x1101> = 61446, first = 248, last = 260417 packets for pid 4354 <0x1102> = 8688, first = 251, last = 260285 coded frames = 456, video frames = 456 C:\xfer> For multi-channel audio, we'll have to decide what the best raw file format is. Either one file wit all channels, or multiple files with a pair of channels each. Ron
HD MPEG-2 Test Patterns http://www.w6rz.net |
28th February 2007, 16:19 | #683 | Link |
Suppose I demux the EVO to VC1/AC3/SUP files, then I reencode the VC1 into an h264 HD-DVD compliant file.
My goal would be to then reauthor (or remux) the h264 to replace the demuxed VC1 and remux h264/AC3/SUP back to a .EVO file to replace the original on the disc. Hopefully this would mean I could reburn the HDDVD content, only with my reencoded h264 to a DVDR-DL. the big question is - how can we generate .MAP file for the new authored/muxed EVO, I managed to make a .EVO with scenarist 4.1, but it only builds it in IFO-based structure, so no .MAPs. |
28th February 2007, 16:40 | #684 | Link | |
28th February 2007, 16:44 | #685 | Link | |
DD+ convert to AC3-5.1
I am surprised that nobody in this forum noticed that the so-called 2.0 output delivered by the IntervideoAudioDecoder is in fact a Dolby Prologic II signal containing all the information needed for channel routing. Starting from that evidence, it is easy to upmix to 5.1 channels with very good results, see: http://forum.doom9.org/showthread.php?s=&threadid=57736 I have personally reencoded a couple of HD-DVDs DD+ tracks into AC3-5.1 using this technique. As the IntervideoAudioProcessorFX is an active filter using patented software from Dolby, the output is like to be the best for such an upmix. You will be surprised by an excellent centering of the voices as well as excellent surrounding effects. Even did I notice actual stereo in the rear channels. Friends of mine have been completely mistaken by the result ("whouah....such a sound!". No comment...) Of course, the DirectX 2GB limit can be overcome by splitting the 2.0 track into 50-minute parts prior to upconverting, giving smaller-than-2GB 6-channel wav files. The split 5.1 files are then reassembled in VEGAS, using the 2.0 track for synchro. Why dont you give it a try? |
28th February 2007, 17:05 | #687 | Link | |
28th February 2007, 17:39 | #689 | Link | |
For the intervideo filter, you probably need to get this rev: Binsearch: Windvd.8.Hd-Dvd.Blu-Ray In the meanwhile: http://www.binnewsgroup.com/binnewz/...&CODE=03&id=92 Last part "ENCODAGE AUDIO" to get the 2.0 wav file. Then the upmix: FileSource(async) "in-2ch.wav" => WaveParser => IntervideoAudioProcessorFx => WAVdest => FileWriter "out-6ch.wav" I will provide you with a hard-wired "upmix.grf" file which takes c:\track2.wav and outputs c:\upmix6.wav This patched GRF file will prevent you from having to HEXedit the output file as required in: http://forum.doom9.org/showthread.php?s=&threadid=57736 Jack |
28th February 2007, 17:44 | #690 | Link | |
That's good to finally here something out of a DD+ track ! Do you know if it's possible to feed Scenarist Nav Filter directly with a DD+ track (like a ddp file) ? Does it work for Dolby TrueHD audio tracks too ? |
28th February 2007, 17:53 | #691 | Link |
From what I understand every E-AC-3 stream contains a 640Kbps "AC-3 core" that can be extracted by DD+ capable software.
Most of the DD+ soundtracks on HD DVD movies that I have seen have been at 640Kbps (only a few have been higher). Am I correct when I assume that audio information found in a 640Kbps E-AC-3 stream is identical to the "AC-3 core" of the same stream? |
28th February 2007, 17:55 | #693 | Link | |
Coder
It needs a partially re-encode to get a normal ac3 sound. PowerDVD can do it during playback... Last edited by Pelican9; 28th February 2007 at 18:20. |
28th February 2007, 17:57 | #694 | Link | |
http://en.wikipedia.org/wiki/Meridian_Lossless_Packing http://en.wikipedia.org/wiki/Dolby_TrueHD |
28th February 2007, 18:22 | #695 | Link |
Well, another DD+ decoder. So we know Intervideo audio decoder outputs 2.0 instead of 5.1.
asasadad_1 mentioned that Sonic decoder pack can work with EVOB/VC1/DD+ at http://forum.doom9.org/showthread.ph...436#post962436 I tried sonic decoder pack on two PCs, works on one PC, does not work on another PC. No idea what's wrong. Anyway, I modified DTS/AC3/DD+ source filter which can work with sonic audio decoder. The source filter I posted a few pages eariler does not work(need small tweak). I'm pretty sure the output is real 5.1. You may want to give it a try http://www.sendspace.com/file/knvhiz For the sonic decoder pack, PM me please. |
28th February 2007, 18:58 | #696 | Link | |
Furthermore I do not have a filter called wavdest? Where to get from? |
28th February 2007, 19:22 | #698 | Link | |
WAVdest.ax is part of the graphedit pack. You just have to register it in a DOS-like window: regsvr32.exe wavdest.ax Jack |
28th February 2007, 19:31 | #699 | Link |
I think that 1,509 Mbps DTS is the best sounding multichannel signal that can be sent over an S/PDIF interface (please correct me if I'm wrong here). If that is the case it's what I would like on most backups if the source has a lossless audio track.
28th February 2007, 19:34 | #700 | Link | |
A bunch of DVD Audio authoring software out there wouldn’t recognize the MLP extracted with EVODemux. I think it’s encapsulated into Dolby TrueHD format somehow and as we know, there is no Dolby TrueHD software decoder yet. If we’ll be able somehow decode this track, we would be able to encode it to another lossless multichannel codec like FLAC or WMA and add it to a new container, and play on computer without HDMI. |
