31st May 2011, 21:48 | #281 | Link | |
Thanks for the fast reply and also for the new CUE import wizard, seems to be working flawlessly so far Great work!
Maybe if you change this text to "(.m3u8 - Unicode)" maybe people don't get confused about why LameXP is outputting some strange ".m3u8" playlists? EDIT: I was playing some playlists that were created with LameXP v3.18 a while ago and noticed that these playlists, although being .m3u, recognize files with special characters. So, there must be some difference between the v3.18's .m3u creation method and the v4.xx's. Last edited by Raen; 1st June 2011 at 19:55. |
2nd June 2011, 01:53 | #282 | Link | |
Software Developer
All strings were simply in the local 8-Bit encoding, i.e. whatever Codepage happened to be configured for Non-Unicode applications on the individual computer. If you have luck, the 'special character' can be represent in your local 8-Bit encoding, so LameXP 3.xx will be able to display it correctly and save it to the M3U file (again in a local 8-Bit encoding). And, if you have even more luck, then the other application (e.g. Winamp) will interpret the M3U file with the same local 8-Bit encoding as LameXP and thus will read the 'special character' correctly. But there is absolutely no guarantee it will work as desired! Also with a local 8-Bit encoding, it is never possible to have characters from different Codepages at the same time... LameXP v4.xx provides proper Unicode support. Internally everything is represented as Unicode/UTF-16. Only question is: How do we export strings to other programs? I have now changed the playlist creation in the following way: * If all file names in the playlist can be represented correctly as Latin-1 (ISO 8859-1) then the M3U file is written as plain Latin-1 text with a '.m3u' extension. * If there is at least one file name that contains Unicode (Non-Latin1) characters, then the M3U file is written as UTF8-encoded text starting with a BOM and with a '.m3u8' extension. So can you please try again with Build #560, which is now available via auto-update?
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 2nd June 2011 at 02:09. |
2nd June 2011, 16:14 | #283 | Link | |
Yes, looks like I got some luck with those older playlists, because I found another ones that targeted files that had non-latin characters (cyrillic, japanese, etc) and those didn't play, only the ones that had latin special characters (accents, etc) played.
If I can avoid installing, the better, I prefer the portable/zip package Last edited by Raen; 13th June 2011 at 23:20. |
2nd June 2011, 19:59 | #284 | Link | |
Software Developer
http://sourceforge.net/projects/lame...pshots (BETA)/ However in order to get the latest one, you should always run auto-update. I am too lazy to upload every build twice, so the auto-update server is updated more frequently
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 2nd June 2011 at 21:47. |
3rd June 2011, 22:26 | #285 | Link |
Software Developer
Today I made a LameXP build with the recent technology preview of Qt v4.8.0:
http://www.mediafire.com/file/xeg7st....Build-561.zip You are welcome to report any regressions or improvements that you may encounter
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 3rd June 2011 at 22:37. |
4th June 2011, 21:40 | #286 | Link |
Software Developer
LameXP v4.02 Beta-7:
Implemented a custom QFileIconProvider, which (hopefully) makes the "Output Folder" view a bit faster. Note: This build, in contrast to the one from my previous post, has been made with Qt 4.7.3 again!
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 5th June 2011 at 20:32. |
5th June 2011, 09:28 | #287 | Link | |
I'm getting this error when I try to encode a 5 channel ac3 file to joint stereo. Seems that the resulted wav is aroung 5Gb. Maybe because the huge size ?
Codres A Bogdan |
5th June 2011, 13:01 | #288 | Link |
Software Developer
Wave/RIFF files cannot exceed a size of 4 GB. That's a limitation of the RIFF file format, because the size field is 32-Bit
As far as I know, ValibDec will create a RF64 file, if the size exceeds 4 GB. Unfortunately most tools, including SoX, do NOT support RF64 files yet... (Indeed there is no RIFF header in this case, only a RF64 header)
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 5th June 2011 at 19:52. |
5th June 2011, 20:35 | #290 | Link |
Software Developer
LameXP v4.02 RC-1:
Last chance to report bugs that you don't want to see in the next release version
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 14th June 2011 at 18:52. |
11th June 2011, 01:56 | #291 | Link |
Simpler Add UI
Not a bug, but a suggestion to simplify the Add File(s)/Folder features:
Why not combine them into a single Add Files button and let the user browse and select either files or a folder? Maybe with a "Add recursively" checkbox in the Browse dialog box when a folder is selected. Personally I use only the "File|Open Folder Recursively" menu, it's been a bit disappointing to see the Add Folder button disappear. That's why it would be great to be able to select either files or folders from the same button in the main UI, I don't really understand why there needs to be 3 different menu items to add files. And if it's a folder, the recursive checkbox should be selected by default. Very low priority, I just thought it would improve usability and be easier to maintain just one Add feature too. There's one little bug that bothers me, although I'm sure it's meant to be by design: When adding files, for instance a large recursive folder, each of the file names is displayed on the forefront in the middle of the screen, so you can't switch to another app like a browser or video player while it's adding the files. Which in my case took 3 minutes for over 400 files (I had another CPU-intensive app running at the same time.) Is it possible to display the file names only if the app in focus is LameXP? FYI, this is how I use LameXP: Usually once a week I rip my new CDs with WMP into lossless WMAs, takes about 2 minutes per CD max. Then I move all the CD folders into a single folder outside the WMP library and run LameXP on this folder recursively. Then the MP3s are moved to a separate folder where I can pick them up for mobile usage, the WMAs are moved back to the WMP library. I use robocopy /mov and /move to keep the same structure. If I could specify the folder to add as a parameter, everything could be scripted. |
11th June 2011, 02:48 | #292 | Link | |||
Software Developer
However you may add folders via drag&drop. The "drop box" may also be helpful here... Quote:
Shouldn't be too hard to add "--add-folder <folder>" and "--add-recursive <folder>" options in one of the next versions.
11th June 2011, 19:04 | #293 | Link |
Software Developer
LameXP v4.02 RC-3:
Added "--add-folder <path>" and "--add-recursive <path>" command-line switches.
13th June 2011, 08:04 | #294 | Link |
First, just wanted to say how much I appreciate your having created this tool and continuing to maintain it. I've been using it for a few years and think it's got to be the best for my needs.
In an earlier comment, you said “try again with Build #560, which is now available via auto-update” – not sure what you meant by this. Should I be able to run ‘Check for Updates’ from the app and it should grab the new build? If so, it didn’t work. It kept saying 418 was the latest. Anyway, the reason I came to this forum was because 418 kept crashing my system (W7Usp1 64-bit). I was encoding to mp3 it on a quad-core with a queue of over 2k files. I reduced the threads to 3, and it didn’t crash, but over 50% of the encodes failed with error code 3 or 5 and a very small or zero-byte mp3 file. I installed Build 574 and reduced the queue to fewer than 600 and left threads at 3. The app died with “Unhandled exception error, application will exit.” after 313 files completed. I ran another queue of about 250 files, all finished except two, which failed with PROCESS TIMEOUT !!! Exited with code: 0xF291 Re-ran those two after that queue finished and they encoded fine. Is there a way to start the binary with a flag to disable the startup ‘Your version is too old’ check and dialog? If so, any guesses as to the version(s) to support such capability? I wasn’t having these kinds of problems with queues over 1000 with previous versions. Though I’d bet the queue size isn’t the problem, it just increases the likelihood of a problem in any given job. Is there a way to have the debug log sent to a file as well as to the console? Is there a way to retain encode logs? All this info seems to be gone after a crash. Also, the ‘Output Directory’ tab is still quite slow to respond. Changing to that tab is quicker than before, but you have to wait a bit (on the order of 60 seconds or so) before you can do anything or even switch to another tab. Lastly, my wish list of future features: - Default for drag-&-drop should be recursive (maybe an option setting?). - An option to designate default action when encoding: whether to overwrite, create a new file, or query the user. - After adding folders, the message could be a little more descriptive as to the count of files rejected for specific reasons (not an audio file, corrupted file). - Option for more columns in the main pre-processing window (file type, size?) and sortability - Ability to sort by status in the Processing window Again, thanks for all your effort and dedication. Peace, Namaste, etc. |
13th June 2011, 14:12 | #295 | Link | |||||||
Software Developer
Also: Did you watch the memory usage (Private Bytes) of the LameXP process (e.g. in ProcessExplorer). Did it increase to ~2 GB just before the crash? [UPDATE] I just ran an encode with 800+ files on my system (Win7 x64, Core2 Quad, 4 GB of RAM, 4 threads) and everything ran through just fine. Also the memory usage (Private Bytes) ware relatively constant at around ~55 MB. So this definitely is not a 'memory leak' problem! [/UPDATE] Quote:
This can happen when the process encounters a deadlock. But it can also happen if the process didn't get enough CPU time by the OS to do its job. Did you run other CPU intensive applications in the background ??? Quote:
Also you can disable the update-reminder in the options menu. However extremely old versions will start to "force" the update at some point. This can't be skipped (and usually shouldn't be skipped), except by compiling LameXP from the sources yourself and removing the check. It is discouraged to use v3.xx nowadays, because there were a lot of nasty limitations (the lack of Unicode support is probably the worst of them). But after all this is OpenSource software. So you can always modify the application according to your needs... Quote:
But you are right. This won't be possible if the application crashed - which usually shouldn't happen Quote:
But that probably depends on the "size" (number of files and sub-directories) of the initial output directory. And of course slow Anti-Virus software might slow things down a lot here! Try to temporarily disable your real-time Anti-Virus scanner - just for testing. There's not much I can do to make it faster, as the QFileSystemModel is a part of Qt. Already tried a number of workarounds to make it a bit faster. I once made a test build with the Tech-Preview of Qt v4.8, which might (or might not) give some improvement. Did you check that one out? Quote:
(2) Asking the user every time the output file already exists doesn't fit very well into the "batch processing" concept of LameXP. However adding an "overwrite existing files" option would be possible, but dangerous. Maybe when I implement an option to re-name the output files. (3) Well, how do we know what is the reason? If the type of the file couldn't be determined, is this because it's a file type we simply don't know/support or is this a broken file? It's impossible to know. After all we can only reject everything that doesn't seem proper... (4) Not quite sure. The "size" of the input file currently is not detected (although it would be easy to add). And "file type" is a bit vague (container format? audio format? detailed compression info?). But adding some "sort" options (at least 'by filename' and 'by title') to the Source Files tab is on my TODO list. (5) Not currently possible, as jobs are appended to the list as they are created. [EDIT] Might be easier to do than I thought at first. [/EDIT]
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 14th June 2011 at 00:46. |
13th June 2011, 20:18 | #296 | Link |
Software Developer
LameXP v4.02 RC-4:
An attempt to make LameXP deal better with a large number of files (will only show the most recent 50 files in the progress view now).
13th June 2011, 23:25 | #297 | Link | ||||||||
Thanks for the quick and informative reply.
I've been running some more tests, and I was getting the PROCESS TIMEOUT quite often -- as early as the 14th and 20th file in the queue. (Private RAM approaches but never gets to 37MB.) I decreased the threads to two, and over 100 files have now completed without problem. The odd thing to me is that this never happened w/ the previous version (I think I was using the Xmas build on this same system for quite a while.) Quote:
I forgot another wish list item, which would be to be able to select multiple items in the list (shift and/or ctrl keys) and remove all selected. Am I correct that currently it's only possible to remove one at a time? Quote:
Thanks again!!! |
14th June 2011, 00:05 | #298 | Link | ||||||
Software Developer
If there is some problem with memory, then it's the 2 GB per process memory limit. A single 32-Bit process cannot allocate more then 2 GB of memory, no matter what. But it doesn't seem to be a problem with LameXP. Even when processing hundreds of files at once, memory usage for the LameXP process stays below ~60 MB. Quote:
That's why we create/run several threads in parallel. If CPU usage drops below 100%, it means the CPU or at least some of its cores were idle some of the time. If, however, there are some (high priority) processes that "eat" too many CPU cycles, it can happen that LameXP's encoder processes starve and eventually trigger a timeout. Note that LameXP's encoder processes are running with reduced priority. This is done in order to keep the system responsive while encoding... Quote:
I'm not quite sure what I can do, except for increasing the timeout interval. But it already is 30 seconds. If the encoder process doesn't respond (i.e. either complete or send a progress update) within 30 seconds, something has to be seriously wrong... Also with the old 3.xx versions you couldn't get a timeout error, simply because there wasn't any timeout check implemented (If one of the encoder processed deadlocked, LameXP v3.xx would have waited until forever...) Quote:
LameXP does it properly: It uses MediaInfo to actually analyze the file and detect the file's type from it's content. The file's name (including its extension) is not considered at all. Quote:
Yes. If you encoded a huge number of files and only a few failed, it will be hard to find those on the list...
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 14th June 2011 at 01:42. |
14th June 2011, 08:15 | #299 | Link |
Ran another set of files with only two threads.
2 of 1587 files failed with PROCESS TIMEOUT !!! Exited with code: 0xF291 One failed running tool_lame.exe, one didn't get past tool_flac.exe. I can only guess from that low-prio jobs are getting pushed back at peak times and having to wait longer than the timeout. Any chance of making the timeout another option? Maybe a range of up to 5 minutes? It would seem that when I used the older version, nothing (thanfully) ever deadlocked, but because there was no timeout, nothing ever failed for that reason. PS - max private RAM consumed with that queue was <53MB. |
14th June 2011, 12:03 | #300 | Link |
Software Developer
Still, unless you are running other CPU intensive tasks in parallel to LameXP there shouldn't be any problem. And even if you are running CPU intensive processes in parallel to LameXP and these processes have an increased priority, then the OS' scheduler shouldn't let the encoder processes starve. They might get less CPU time than the higher priority processes, yes. They might have to wait a few seconds now and then, yes. But more than 30 seconds? That's definitely too much. The only situation in which a process (one that is not in the "idle" priority class) might starve is when there's another processes running with "real time" priority and that processes uses the CPU all the time. But that's the reason why using the "real time" priority class is highly discouraged - especially for CPU intensive tasks. So either there is something seriously wrong with your system (did you install any CPU "tweak" or "optimization" tools?) or there's another problem that we didn't consider so far. Last but not least: Did you try to disable the real-time scanner (guard) of your Anti-Vrius software? It wouldn't be the first time that it turns out an Anti-Virus scanner caused all the trouble...
(Anyway, I will increase the timeout to 3 minutes. I don't want to have yet another option. Will send you the new build via PM soon!)
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 14th June 2011 at 17:45. |
aac, aotuv, flac, lame, lamexp, mp3, mp4, ogg, oggenc, opus, vorbis |
