Old 30th March 2010, 14:15   #1  |  Link
ohadsc
StreamRecorder.NET - GUI Front end for recording media streams
Intro
StreamRecorder.NET is a free, open source GUI front end for programs related to the capturing of streaming media
Motivation
As far as I know, the most robust, free solutions for recording streams of all types today are MPlayer and VLC. Both require some command line arguments which, for many users, would be difficult to use (and find!). In addition, they do not cater to all stream capturing needs. Note: For IceCast/Shoutcast streams, StreamRipper is an excellent piece of software that is very much capture oriented, still using it via StreamRipper has its advantages IMHO.
Features
  • Records, joins and post processes stream using the tools you choose (defaults supplied)
  • Full Command Line Interface (CLI) for scheduling and automation
  • Automatically create windows tasks for scheduled recordings
  • Copy current configuration parameters to the clipboard
  • Keeps the recording process alive (restarting when necessary)
  • Time stamps file names to avoid overwrites
  • Logs recorder output to file
  • MP3 and Windows Media easy presets
  • Complete Tool tip coverage explaining all functionality
  • Portable mode saves all settings in the application folder
Requirements
Source and Binaries
http://sourceforge.net/projects/streamrecnet/
Homepage
http://ohadsc.wordpress.com/2010/03/...mrecorder-net/
I would love to hear your comments, for suggestions and bug reports please use http://sourceforge.net/projects/streamrecnet/support
Enjoy !
Changelog
* Added Play/Test button
* Added scheduling support (windows tasks)
* Copy commandline to clipboard
* Improved help
* Fixed settings window icon
* Internal code improvements
1.0.5
* Fixed another instance of the long tray text bug (>64 chars)
1.0.4
* Fixed long tray text bug (>64 chars)
* Revamped countdown mechanism, fixed precision bug (time drift)
* Changed VLC default interface to no_gui to avoid opening another window
* Improved mono support
* Portable pack included
1.0.3
* The default executable locations are now blank, so they don't fail validation
* On first run, MPlayer (MuldeR's package) and/or VLC are serached for in their default location
* The default output directory is now the "My Music" folder
* The executable location dialogs now only accept the expected filename by defaul (e.g. mplayer.exe)
* The "Get MPlayer" link now directs to MuldeR's MPlayer package
1.0.2
* Portable mode
* Time stamped logs
* Misc Fixes and improvements
1.0.1
* Improved tray behavior
* Some issued from 1.0.0 taken care of
1.0.0
* All around polish
* Tray/balloon support
Release Candidate 1
* First public release
ohadsc is offline   Reply With Quote
Old 30th March 2010, 15:30   #2  |  Link
avih
Capture, Deinterlace
avih's Avatar
Sounds like a useful tool
Keep up the good work!
avih is offline   Reply With Quote
Old 10th April 2010, 15:08   #3  |  Link
ohadsc
Thanks
Version 1.02 released!
Author of StreamRecorder.NET
Old 15th April 2010, 01:45   #4  |  Link
ohadsc
Version 1.0.3 released
Old 23rd January 2012, 21:22   #5  |  Link
ohadsc
Version 1.0.6 Released
audio, capture, recording, streaming, video
