28th January 2006, 04:36 | #261 | Link | |
No crash ! Thank's I tested it tonight |
28th January 2006, 08:31 | #262 | Link |
Pig on the wing
Playing the avs script doesn't crash but when I close the file in VDubMod, the program vanishes after a while. I don't know if it's actually MT that causes it though. Maybe tsp could also provide a debug build so that could be double-checked.
28th January 2006, 09:17 | #263 | Link |
Ok. Well, after all, it was - as always - a silly mistake. I was compiling the masktools with the single thread windows library. What amazes me is that pre a18 were also compiled in that fashion, but didn't crash.
Anyway, I'll clean the mess I've done with the debug log, fix the YUY2 crash, add another of tsp's optimization for the median computation, and release a new, proper version. Thanks a lot Boulder and vanessam for the help.
4th February 2006, 08:54 | #264 | Link |
Pig on the wing
A new item that doesn't like SetMTMode(2) is Cedocida, the open source DV codec. See the sticky thread in the DV forum for its own thread if you're interested. Using SetMTMode(2) produces weird artifacts which disappear when you use for example ffdshow for decoding DV content.
5th February 2006, 20:24 | #265 | Link |
Boulder:
Does it help to use something like this: Code:
SetMTMode(5) Avisource("c:\foo.avi") SetMTMode(2) filter() filterMore()
Get my avisynth filters @ http://www.avisynth.org/tsp/ |
6th February 2006, 15:34 | #266 | Link |
Pig on the wing
I couldn't reproduce the problem with SetMTMode(2) again but I now started encoding a long DV clip with SetMTMode(5).AVISource().SetMTMode(2) and see if there are any artifacts. When they appeared, they looked like the ones you get with a broken stream although they were not green as usually.
8th February 2006, 08:35 | #267 | Link |
Pig on the wing
OK, I didn't see any artifacts in the one encoded with SetMTMode(5) in the beginning so that's what I'm going to use from now on - in all of my scripts just to be safe
4th March 2006, 10:42 | #269 | Link |
Due to lack of spare time I did not worked very much on MT but in the next couple of days I will get a dualcore opteron 165 so that should speed up development. Most of the "bugs" is incompatiple filters though and it is difficult for me to fix that.
20th March 2006, 15:21 | #270 | Link |
Horizontal Line with LimitedSharpenFaster
I'm almost positive that I've already seen some posts about this, but I can't find them:
When I run this filter I get a thin hoizontal line across the middle of my screen: SetMTMode(2) MT("LimitedSharpenFaster(ss_x=1.0,ss_y=1.0,Smode=3,strength=60,overshoot=7)") When I run it without MT, as follows, I don't get a line: LimitedSharpenFaster(ss_x=1.0,ss_y=1.0,Smode=3,strength=60,overshoot=7) Can someone help me figure out where it's coming from? It's pretty subtle and isn't a big bother - but I'd still like to get rid of it. Thanks! Mike P.S. Did I mention how awsome this thing is? I have a 2.8 Northwood, and I can't run LMSF + a denoiser in realtime without major league stuttering - until I put MT in the mix. Wow. Last edited by aberforthsgoat; 20th March 2006 at 15:27. |
20th March 2006, 16:11 | #271 | Link |
Angel of Night
You shouldn't mix MT() with mt-enabled avisynth. Instead, change SetMTMode until you get to a mode that works for the filter; each step higher is more compatible.
MT is more of a workaround if you can't install mt-avisynth. (Since I run 2.5.7-pre, I should try MT, that might've sped up my last 18-hour filtering...) Edit: TSP, have you considered using Tritical's avisynth releases to base your filter on? They include some nice patches that aren't in cvs (such as lifting autoload restrictions, \n in subtitle, and a bunch of others I forgot about). That would be most excellent. =D Last edited by foxyshadis; 20th March 2006 at 16:21. |
20th March 2006, 16:48 | #272 | Link | |
20th March 2006, 17:15 | #273 | Link | |
When I try to drop the MT() part and just use the SetMTMode command, I loose my multithreading. CPU two maxes out while CPU one stays stuck very low. However, I have realized that I can run MT() without the SetMTMode line. Multithreading comes back to normal. However, the horizontal line also remains in the screen. Could it be an installaton error? I reinstalled avisynth 2.5.6, copied the modified file into my system32 directory and copied in the MT plugin - all to no avail. Same as before. Bother. Mike P.S. Could it be that I installed the wrong version of avisynth 2.5.6? There seems to be a 2.5.6a and a 2.5.6 RC2 on the avisynth site. Last edited by aberforthsgoat; 20th March 2006 at 17:20. |
20th March 2006, 18:11 | #274 | Link | ||
Angel of Night
20th March 2006, 19:37 | #275 | Link | |
However, the SetMTMode command still won't do it for me. MT() is working nicely though. Thanks for the tips! Mike |
21st March 2006, 00:17 | #276 | Link | |||
21st March 2006, 05:40 | #278 | Link |
Posts: n/a
aberforthsgoat,
Ive found that line to be a problem between versions of MT and masktools - I cant tell you which combination causes it - only that ive fixed it previously on my system by the same method (re-installing versions of each) Cheers, Bitey |
21st March 2006, 07:59 | #279 | Link | |
Mike |
