Old 15th June 2005, 22:23   #421  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
Strange...works fine here. Have you got BeLight.ini file in BeLight folder ?
Old 16th June 2005, 07:53   #422  |  Link
Pyscrow
Yeah, but I am running the older beta in my normal besweet directory, so I just copied the ini file from its directory, into the new directory and now stays in english.
Pyscrow is offline   Reply With Quote
Old 16th June 2005, 08:58   #423  |  Link
daphy
Miles Freak
daphy's Avatar
write protection?
Edit:
BTW: added on needfulthings
CYA Daphy
daphy is offline   Reply With Quote
Old 16th June 2005, 09:20   #424  |  Link
Kurtnoise
Kurtnoise's Avatar
Don't forget also to copy the "lang" folder...
Old 16th June 2005, 15:16   #425  |  Link
dwrbudr
Unregistered User
dwrbudr's Avatar
Little bug report
When I select 'All Files supported (*.*)' I don't see for exapmle *.mp2 files. This options works fine in Beta1, but doesn't work in the latest Beta
my subtitle site
dwrbudr is offline   Reply With Quote
Old 16th June 2005, 18:07   #426  |  Link
Kurtnoise
Kurtnoise's Avatar
Indeed...I miss a "*." in the code. Shame on me. It's fixed now...
Old 16th June 2005, 18:08   #427  |  Link
Kurtnoise
Kurtnoise's Avatar
BeLight 0.22 beta 3
beta 3 is out.
changelog :
- Fix the '*.' missing concerning the mp2 files in the dropdown list.
- Fix the "-azid( )" command when input are different from AC3.
- Fix the disabling options with multiple selection at the opening.
- Fix internal error when we have 2 or more files to transcode.
Old 16th June 2005, 18:36   #428  |  Link
humax
hi
need some dll. for AAC but dont using ist.
i want only ac3 to mp3 converten but wont work with 0.22 beta 3
screeenshot shows prob
thx for help
humax is offline   Reply With Quote
Old 16th June 2005, 18:51   #429  |  Link
LigH
LigH's Avatar
Seems that BeLight wants to ensure that you have all required DLLs if you might want to convert to AAC. Please check well if it is just a "warning" (which you may ignore) or really an "error" (means, the program cannot run without it); many people seem to misunderstand how important a message really is.
(I do not yet see the yet unapproved image while writing this.)
Old 16th June 2005, 18:56   #430  |  Link
humax
it doesnt work .
need theese dll. well i will put it into folder but i think its a bug.
cu
Old 16th June 2005, 19:50   #431  |  Link
tebasuna51
tebasuna51's Avatar
1) I download the zip and the installer of BeLight-0[1].22b2 to compare with my actual folder with BeSweetv1.5b29 and I have two questions:
Is besweet.dll necessary? It is not present in the DSPGuru package.
BeSweet.exe is the same version (v1.5b29), size and day, but different hour and content than BeSweet.exe in the DSPGuru package. Is a modified version?
2) Cosmetics:
Don't work 3 Hints: RearChan_Hint, PlugdllName_Hint and Equalizer_Hint
My spanish translation need to be modified (sorry, I can't test it before). Here is the new version:
http://www.cdmontecanal.com/img/spanish.ini
Edit: Don't work the link with "Espaņol.ini". You need rename it.
3) If you plan support Tranzcode, please, don't forget the option for demux a wav_6chan in 6 mono wav.
BeSweet have a limit in 2 GB (only 62 min. in a 48 KHz 6 channel wav). Tranzcode can work with wav6 > 4 GB.
Old 16th June 2005, 22:32   #432  |  Link
Kurtnoise
Kurtnoise's Avatar
ok...fixed.
Old 16th June 2005, 22:38   #433  |  Link
Kurtnoise
Kurtnoise's Avatar
Not necessary....
No.
Indeed...they were disable.
yes it's expected but the 2Gb limit has been corrected in the last BeSweet beta. Make a search...
btw, thanks for the update ini file.
Old 17th June 2005, 01:10   #434  |  Link
tebasuna51
tebasuna51's Avatar
No.
Old 17th June 2005, 06:27   #435  |  Link
Kurtnoise
Kurtnoise's Avatar
Works with the floating-point (32 bits)...Read Q30 in BeSweet FAQ and here.
Old 17th June 2005, 06:58   #436  |  Link
daphy
Miles Freak
daphy's Avatar
Hi Kurt,
corecodec.org is currently down, so I canīt offer a mirror, plz upload your smaller version on to the needfulthings upload folder
THX Daphy
CYA Daphy
Old 17th June 2005, 10:06   #437  |  Link
Kurtnoise
Kurtnoise's Avatar
Done...but probably you need to wait a couple of hours to have a new beta. I'll build a new one tonight.
Old 17th June 2005, 11:57   #438  |  Link
daphy
Miles Freak
daphy's Avatar
okey dokey
CYA Daphy
Old 17th June 2005, 16:51   #439  |  Link
Kurtnoise
Kurtnoise's Avatar
BeLight 0.22 beta 4 released
beta 4 is up...
changelog :
- Fix the warning loading concerning the aac dlls missing.
- Fix the hints which were disabled.
- Update the Azid command even if the Input File List is empty.
- Update the command line for the 5.1 channels with Advanced Settings.
- Update Spanish language.
As CC.org is down, there is a link mirror in my sig. You could wait also that Daphy updates this new beta on needfulthing.
Old 17th June 2005, 19:41   #440  |  Link
JoeBG
stupid
JoeBG's Avatar
beta 4 is up...
changelog :
Thanks
cu
Joe
freedom is just another word for nothing left to loose
JoeBG is offline   Reply With Quote
