29th January 2021, 21:34 | #804 | Link |
Formerly davidh*****
No, I don't get the drift, so maybe you didn't get the drift in the first place. If a user doesn't have Nvidia hardware then they're not going to be able to use anything that relies on CUDA. OpenCL, if I understand correctly is practically ubiquitous.
29th January 2021, 21:55 | #806 | Link | ||
Broadcast Encoder
(Honestly, though, I hope all the cuda core in my Quadro P4000 are fine xD) Quote:
The thing is that OpenCL has been proven to be slow, especially on Nvidia cards, so losing a lot in performance only to make it run on different cards isn't generally something that businesses are willing to accept. I work in broadcast and I can tell you that no matter where you go, if you open up the workstations of any studio, you'll find an NVIDIA Quadro, it's just the way it is. Some very small studios may have an RTX but that's about it, it's always NVIDIA. What I'd like to see in the future for Avisynth is a widespread use of cuda with plugins that can work on the CPU for the rest of the community and on the GPU for those owning an NVIDIA card. I know it may not make some users happy, but industry-wise it makes a lot of sense. I work in the encoding department, we have servers running Avisynth automated tasks all the time for ingest and outgest (incoming and outgoing media) and I have plenty of NVIDIA Quadro cards that are used by AVID Media Composer and Davinci Resolve, but I can't use them for Avisynth (except for a very limited set of plugins - Thank you Donald ) and I can't use them in encoding either due to the lower quality outcome compared to x264/x265. I am actually using them to encode with x264 + OpenCL but honestly, the speedup is so reduced that I can barely tell the difference. I would love to be able to use them for Avisynth as it would speed up things a lot! Last edited by FranceBB; 29th January 2021 at 21:57. |
29th January 2021, 21:56 | #807 | Link | |
Useful n00b
It's like a joke from our youth: Why did the man jump out of the airplane? Answer: Because if he didn't jump out of the airplane he'd still be in the airplane. You are saying nothing. Putting stuff in bold doesn't improve an argument. |
29th January 2021, 22:12 | #808 | Link |
So look at all the work pinterf and others have done to NOT keep Avisynth tied to a particular operating system. I just wondered if it might be preferable not to throw in with another proprietary system when there are open alternatives, but I appreciate that pinterf isn't starting something new from scratch here, if he's even starting anything at all.
29th January 2021, 22:22 | #809 | Link |
maybe both or all (with Vulkan) since Vulkan not work with many old gpus but OpenCL do
like this plugin do https://github.com/HomeOfVapourSynth...h-Waifu2x-w2xc (it even work with CPU only) Code:
gpu: Controls the environment to use. 0 = disable GPU 1 = auto detect. It will run on the first available environment in the following order: CUDA Vulkan AMD OpenCL FMA AVX Intel OpenCL SSE3 OpenCV filter2D 2 = force to use OpenCL
See My Avisynth Stuff |
29th January 2021, 22:42 | #811 | Link |
it's self-evident that CUDA is better for Nvidia
29th January 2021, 23:29 | #814 | Link |
True NVIDIA fanboy would buy rtx3090 instead of that rtx2070 you have now. You must upgrade NOW!!!! Sell your kidney or/and car if you can't afford IT.
30th January 2021, 00:04 | #816 | Link |
They will dump maybe after 4000 series... But then 3080 will be outdated and new series will be again sold out directly to chinese crazy miners.
31st January 2021, 18:42 | #820 | Link |
> TI
I'll consider it based on my local prices and availability. Literally I need it for filters like eedi3/nnedi3 where 10G memory isn't really a problem. In fact, 2070 with 8G is enough for it, but eedi3 is slow. |
