16th January 2017, 01:15 | #441 | Link | |
You must convert them to cfr manually first. I will probably code MKVCleaver to log an error in these cases if I cannot find an automatic way to convert a vfr file to cfr.
Please upload all files to ft.sapib.ca. Click Drop-off to upload files and follow the promts. |
18th January 2017, 22:55 | #442 | Link | |
Or it mightn't necessarily need to be in the top right pane. The menu item could be moved to the Video Options section in the lower right pane with a checkbox to switch between timecodes and timecodes with tracks. Just so you can see what state it's in rather than it being hidden under a menu. |
19th January 2017, 01:19 | #443 | Link | ||
The main problem is traditionally it's always been assumed the video delay is zero and the audio delay is adjusted accordingly, as mostly the video is re-encoded and any video delay is lost, but when it comes to the second rule it's being done differently. Quote:
Episode one 01 EN DELAY 0ms.h264 Episode one 02 EN DELAY -100ms.ac3 Using the current method if the video delay is 200ms and the audio delay is 100ms, after re-encoding the video, a muxer would normally need to apply a -100ms delay to the audio, but MKVCleaver writes 100ms and the audio sync would be out by 200ms. I think currently the delay written to the audio stream can be different according to whether the video delay is also requested or not. To be honest, I'm not sure that's a good idea. The above keeps the traditional "no video delay" assumption intact, but unfortunately it doesn't always work when extracting and remuxing. I don't there's an automatic solution to fit every circumstance, but maybe one idea might be to write the video delay to both streams, "if" the video delay isn't zero, as a guide for manual adjustment. ie Original video delay 200ms, audio 100ms, extracted files: Episode one <V200ms> 01 EN DELAY 0ms.h264 Episode one <V200ms> 02 EN DELAY -100ms.ac3 Original video delay 50ms, audio 200ms, extracted files: Episode one <V50ms> 01 EN DELAY 0ms.h264 Episode one <V50ms> 02 EN DELAY 150ms.ac3 That gives you the required information to extract a stream, re-encode it, then mux it back into the original MKV, so to speak. In the second example you'd extract the audio stream, add it back to the existing MKV, the muxer would automatically apply a 150ms delay, and you'd know to adjust it by +50ms to stay in sync. In my case I'd generally do the opposite and adjust both streams by -50ms, but either way you need to know the original video delay to do it. Just some thoughts.... but I think the audio delay should always be calculated the same way. Changing that according to whether it'd be positive or negative doesn't seem like a good idea to me, as I'm easily confused. Last edited by hello_hello; 19th January 2017 at 14:35. |
19th January 2017, 01:36 | #444 | Link | |
It comes down to the problem discussed in my previous post. When an audio stream is extracted the original video delay is assumed to be zero, but if you want to extract it and remux it back into the original MKV, there's no way to know if the delay needs to be re-adjusted or even if there was a video delay in the original MKV without manually checking. Even checking with MediaInfo doesn't tell you much. It adjusts the audio delay it displays automatically too, so if it shows a -100ms audio delay there's no way to know if the audio delay is 0ms and the video delay 100ms, or if the audio delay is 50ms and the video delay is 150ms etc. It never displays a video delay. |
25th January 2017, 00:45 | #445 | Link | |
25th January 2017, 00:55 | #446 | Link |
As for the delays, they are not purely for informational purposes. When muxing mkv files mkvmerge will read the delays from the audio files and set it automatically. It won't do the same for video files. So having an audio delay is more important. So if we can subtract audio delay from video delay and get a positive number, the video delay is removed completely from the file name, because it is no longer needed. Now, if we get a negative audio delay after the subtraction, there are multiple ways to go:
1) Write a negative delay to the audio file and forget about the video delay. 2) Write both the video and the audio delays to their respective files as they were in the source. I personally do not like negative delays since some muxers will just drop the negative frames possibly making the audio cut out. I also don't know how every video player handles negative delays. So I chose not to deal with negative delays. I think I will keep MKVCleaver the way it is in regards to writing negative delays to audio files, unless you can point me in a direction of some discussion where I can find more information about why I should not do it.
25th January 2017, 00:59 | #447 | Link | |
I will test it to make sure the delays are calculated and written correctly, however, I don't see a reason to add that information to the GUI. Again, if you can make a case as to how this saves time vs having the delay in the filename, I will reconsider.
25th January 2017, 01:03 | #448 | Link | |
25th January 2017, 16:43 | #449 | Link |
I was going through possible scenarios with the audio,video delay and, you're right hello_hello, there are too many possibilities. So I've decided to just write the original values from source to the file name.
31st January 2017, 09:29 | #450 | Link | ||
I have a file with a 100ms video delay and a 150ms audio delay. 150ms is written to the audio stream when it's extracted. If the video is re-encoded the video delay will become zero and 150ms will be wrong. It should be 50ms. The only way to know what a 50ms or 150ms audio delay means (however you do it) is if you can check the video delay. DGIndex has always written negative audio delays and it's never been an issue for me. I can't say I've even felt like important audio was removed when muxing because the delay was negative. Does the audio ever start before the first frame? If you happen to have an issue with that, it's easy enough to manually over-ride when muxing. "Episode one 02 EN DELAY -117ms.ac3" The muxer will automatically apply a -117ms delay. Change it to zero manually, make the delay for the video stream 117ms and the beginning of the audio won't be cut, but most people would probably be used to the "video delay is zero" method, and I suspect prefer it, otherwise every muxer wouldn't do it. Personally I think the precedent set by DGIndex should be adhered to, because that's what everyone expects. The delay written to the audio stream should assume the video delay is zero and adjusted accordingly, whether that makes it positive or negative. I still think the best compromise is to stick to that system and also write the video delay to the audio stream, if it's not zero. Something like: "Episode one <V50ms> 02 EN DELAY 150ms.ac3" You know if you're re-encoding the video a 150ms audio delay will be correct. You know if you extract the audio, re-encode it and remux it with the original file there's a 50ms video delay to account for, so the audio delay needs to be manually adjusted to 200ms. Quote:
If anything I'd at least prefer to go with the "always assume the video delay is zero" method because generally it is. Video delays in MKVs aren't particularly common, but they do exist. One final thought..... I've not used DGIndexNV or any of the newer flavours, which I assume can extract audio from MKVs, as most encoder GUI's do, as does MKVExtractGUI or gMKVExtractGUI etc..... but it'll be really nice if it didn't matter which program you used to extract the audio, it'd have the same delay written to the stream when it's extracted. Do you know if DGIndexNV can extract the audio and does it write negative delays? As far as I know, all programs would write the same delay now as long as the video delay really is zero, but so far the only other program that takes any video delay into account is gMKVExtractGUI (aside from maybe DGIndexNV) and it works on the "video delay is zero" principle, but you can at least check the video delay with the GUI if need be. Thanks. Last edited by hello_hello; 31st January 2017 at 09:53. |
16th March 2017, 00:08 | #451 | Link |
MKVCLeaver 0.6.0.8 Hangs On Batches
When running a batch of MKV’s, MKVCleaver 0.6.0.8 (32-bit) hangs on my Win 7, at various points in a batch list, about half the time. This requires killing the process and, when restarted, picking up where it left off.
Looking for hints in an old thread, I find that, once MKVCleaver hangs, mkvextract.exe does not appear in the task manager. |
26th March 2017, 14:51 | #452 | Link |
MKVToolNix author
problem with v10.0.0?
Hey,
someone just reported to me that using MKVToolNix v10.0.0 breaks mkvcleaver. Note that I haven't verified this myself, but please look into it. My guess is that it's one of two things:
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. |
4th April 2017, 19:02 | #455 | Link |
MKVToolNix author
The author has written here that it was indeed a buggy version check, and that this check's been fixed for the upcoming release.
7th May 2017, 16:13 | #456 | Link | |
I am unable to extract the audio from mkv files when I use MKVToolNix version 10.0.0 or 11.0.0. I get the following error message in the log file:
9th May 2017, 20:10 | #457 | Link |
sheck,
Will the next MKVCleaver support older versions of MKVToolNix or will an MKVToolNix that goes "ding" be required (version 11+)? It seems MKVToolNix can never work on XP again because apparently some people wanted a muxing program to play sounds, and that'll prevent it working on XP forever. I'm just wondering if we'll still be able to use older XP machines for extraction with a version of MKVToolNix that runs on them because it doesn't go ding (version 10 or older). Cheers. |
9th May 2017, 20:23 | #458 | Link |
AFAIK the sound playing is a feature of MkvToolNix GUI and shouldn't affect other tools using mkvextract or mkvmerge. Of course no one will guarantee you for how long. And usually old versions work for quite some time because the basic CLI usage rarely changes.
10th May 2017, 03:49 | #459 | Link |
v0.7.0.0 Realeased
Changes:
* Implemented SQLIte database as the storage engine for internal arrays and the log * Added utility to rotate logs * Added log settings and log viewer * Added more detailed logging * Update check is now using JSON format * Changed mkvmerge -i to mkvmerge -J. MKVCleaver is now using JSON format to query MKVtoolNix CLI tools * Removed mkvextract version check * Added minimum MKVToolNix version. Minimum version is 10 * Added [LNG3], [LNGf] and [Delay] placeholders * Removed [vDelay] placeholder * Changed how [aDelay] placeholder works * Added Quick and Full VFR detection modes * Added VFR to CFR conversion (experimental) * Removed avdump2 * Added batch filters for extraction * Moved About button under Help menu * Added Segment UIDs extraction * Added ability to add files to MKVCleaver by dragging and dropping a text file * Added instance check. Max instances is now 1 * Removed Audio FLAC in OGG container option * Major source changes to accommodate SQLite DB and Windows 10 * MKVCleaver minimum GUI size is now set for both x and y axis * Minor changes to custom.ini file options * Timecodes checkbox text will be red when Timecodes Only option is selected (visual aid) Fixes: * Fixed Drag & Drop on Windows 10 * Fixed state and text detection for files and tracks windows under Windows 10 * Fixed Go button state changes based on what is selected * Fixed Audio track language was displayed as English when no language was set * Fixed h.264 to avi conversion errors * Optimized code to idle CPU when nothing is happening * Changed acv2avi.exe to the version from VideoHelp
Please upload all files to ft.sapib.ca. Click Drop-off to upload files and follow the promts. Last edited by sheck; 10th May 2017 at 03:55. |
10th May 2017, 03:52 | #460 | Link | |
It should still work on XP, however, I don't have XP any longer to test.
batch extract, extractor, matroska, mkv, mkv batch, mkv decoder, mkvextract |
