18th March 2009, 18:12 | #2121 | Link | |
You can check this in tsmuxer on the chapter page with the right mpls is loaded. |
18th March 2009, 18:46 | #2122 | Link | |
Had the same error and found a work around that worked for me had a few others do the same error. This is what I did and has worked 100% on all that gave me that error. When I open the folder in BD Rebuilder I noticed there is an extra video file showing up under the audio so what ever file it was for eg 0002 I moved the file to another folder temporarily and told BD Rebuilder to open the folder again and now that extra file is not there, now click backup and you will get an erro "to be expected" in the BD log on the screen. Move that file back to where it came from and do not rescan the folder again and just click backup again and let it go. I've done this on about 5 so far and all work great. Not sure why it has worked but it has. |
18th March 2009, 18:55 | #2123 | Link |
Hi jdobbs and every one.
Well i still had a few problems with some discs and even got the notice of audio/PGS sizing issue and asked if I wanted to continue, then continued with the immediate error 8 [08:25:13] DoEncoding() 00009 8. So what i did was REMOVE ALL CODECS FROM MY SYSTEM. REBOOTED. REINSTALLED ONLY FFDSHOW V 2768, AVISYNTH V 258, AND HALI SPLITTER. I`ve now had no errors at all and all working fine. Hope this helps others. Kind regards all. Last edited by jewish; 18th March 2009 at 19:29. |
18th March 2009, 23:18 | #2124 | Link | |
I ran it again for BD-25 and no problems... yet. I'm thinking its just gremlins at work. |
18th March 2009, 23:25 | #2125 | Link |
I think that the last version have problems of rebuilding. The film Let the Right One In stop the menu and have problems of sync with the audio with all Powerdvd. The same reencoding with 0.20.0.1 no stop the menu and its ok.
I return to this old version because a couple of films only it is posible to se it with Power dvd 7 and not with Powerdvd 8. regards |
18th March 2009, 23:36 | #2126 | Link | ||
Webmaster
18th March 2009, 23:47 | #2127 | Link | |||
I'm getting a "audio PGC oversize" dialogue box appear after encoding the 2nd m2ts on "Animatrix Bluray" UK version.
(command might show "fastest" encoding on, but I set this just to reproduce the error). System is clean as a whistle and not experienced this error before. |
19th March 2009, 03:03 | #2129 | Link | |
A very simple one that has worked on all 5 that have given me the error. So now when I load up a folder I can tell before I run the backup and waste the hours that it's going to fail with this error. I make the change and run the backup and none have given me the error since. Not sure why it works but maybe one of the future versions will fix it. |
19th March 2009, 04:08 | #2130 | Link |
I'm beginning to wonder if something in the program has timed out... Everything has been cookin' along just fine since 20.03 was released, and all of the sudden about 4 people report the same problem, with different movies, in one day...
19th March 2009, 04:21 | #2131 | Link | |
It is probably possible to find out which track it is using txMuxeR or eac3to. Just my 2 cents.
Vista SP1 32-bit w/4GB RAM AMD Athlon 64 X2 4400+ @ 2.23GHz nVidia GeForce 8400GS w/512MB RAM |
19th March 2009, 04:22 | #2132 | Link |
Well I just finished Australia last night with 20.03 just fine... just frickin took 13 hours though!!
I know this is a really long movie... but 13 hours!?!??? [03:29:09] BD Rebuilder v0.20.03 (beta) - Source: AUSTRALIA - Input BD size: 33.75 GB - Approximate total content: [02:45:28.960] - Target BD size: 8.06 GB - MOVIE-ONLY mode enabled [03:29:11] PHASE ONE, Encoding - [03:29:11] Extracting audio/subs [VID_00013] - [03:37:32] Reencoding: VID_00013 (1 of 1) [16:23:46]PHASE ONE complete [16:23:46]PHASE TWO - Rebuild Started - [16:23:46] Rebuilding BD file Structure [16:29:40] - Encode and Rebuild complete [16:29:40]JOB: AUSTRALIA completed.
MBK |
19th March 2009, 04:29 | #2133 | Link | |
I have been rebuilding the Harry Potter set without any issues, and those are VC-1 video tracks. Have those with problems checked on the Slysoft forums about possible issues with the discs' authoring or maybe BD-Java? Just my 2 cents.
19th March 2009, 04:32 | #2134 | Link | |
@ MikeyBK
I'll now return you to the regular BD-RB programming. \
19th March 2009, 04:35 | #2135 | Link | |
Yeah, as I posted about doing Australia with 20.03, I haven't had any problems with this version at all, from when it was released til now.
Just was a bit surprised at how long Aystralia took on my system, which usually geta all movies done in the 8 hour range , +/- an hour here or there... Quote:
Will let you know maybe tommorrow... lol
MBK Last edited by MikeyBK; 19th March 2009 at 04:37. |
19th March 2009, 09:12 | #2136 | Link |
morning guys just got up left bd rebuilder2003 last night with independence day trying to shrink to bd 25 got this error after 100% [08:09:09] BD Rebuilder v0.20.03 (beta)
- Source: ID4_F4 - Input BD size: 35.97 GB - Approximate total content: [02:24:48.680] - Target BD size: 22.90 GB - MOVIE-ONLY mode enabled - Resuming from previously started job. [08:09:13] PHASE ONE, Encoding - [08:09:13] Extracting audio/subs [VID_00002] - [08:09:13] Reencoding: VID_00002 (2 of 2) - [08:09:22] DoEncoding() 00009 8 any ideas tia |
19th March 2009, 09:18 | #2137 | Link |
im using 8gb ocz 1333 ddr on asus p5e3 deluxe quad core 9300 vista 64 with asus limited edition fan and have also done over 100 blurays all to bd25 and burnt them all back onto traxdata bd-r and or sony bd-re or verbatim bd-re
19th March 2009, 10:29 | #2138 | Link |
I'm new to BD-RB (just became aware of its existence a couple of days ago) so please bear with me. I read Furiousflea's guide and got the impression I can keep original TrueHD tracks by ticking the "Do not reencode AC3" box. I tested Full Backup with Nikita (US) which has two TrueHD tracks (English and French). I de-selected the English one by double-clicking the track in Stream window and made sure I had ticked the "Do not reencode AC3", then started Backup.
Some 8 hours later and I was testing the output. Wow! Menus work, pop-up works as well... but there's no TrueHD audio - only 448kbps Dolby Digital. Did I do something wrong? |
19th March 2009, 10:46 | #2139 | Link | |
JDobbs has purposely not enabled the abilty to retain TrueHD audio as of yet... he wants to keep the betas without some capabilities to help speed up bug issue fixes if there arises a need. Anyways, sounds like you got a successful encoding on your first attempt... great job... Also shows how far along BD-RB Is already..
MBK Last edited by MikeyBK; 19th March 2009 at 10:49. |
19th March 2009, 10:48 | #2140 | Link | |
Webmaster
No TrueHD & DTS-HD are currently not supported although I have succesfully (works on my player at least) re-encoded a disc with DTS-HD still intact and working by seperatly demuxing the audio track and overwriting the DTS core track that BD-RB demuxed and letting it rebuild |
