25th August 2008, 16:37 | #61 | Link |
I get error "Couldn't write image to "D:\000001.png"" and I am using Vista. Can this be the reason? I've set everything up and double-ensured that everything is in place. I've also included the magick_home libraries in the script.
And thanks for this plugin, though! Now I can do something I wanted to do a few months ago. Last edited by Stakiman; 25th August 2008 at 17:23. |
25th August 2008, 17:19 | #62 | Link |
Fighting spam with a fish
Okay, everything works fine. Just so you know, its a little confusing, as there are two immaavs.dll's in that zip file. The first (the "bad") one is in the initial folder. But after I noticed the folder labeled "Release" then I found the "good" one. Just something you may want to consider fixing.
25th August 2008, 17:32 | #63 | Link | ||
25th August 2008, 18:15 | #64 | Link |
I tried bmp and png - still the same result.
DirectShowSource("graph.grf",audio=false,fps=23.976024) assumefps(23.976024) crop(0,140,0,-140) spline36resize(1280,532) converttoRGB24() trim(54000,55000) ImmaWrite("D:\",type="png",magick_home="C:\WINDOWS\system32") Here's my script. |
25th August 2008, 20:02 | #65 | Link |
That's weird. So a script like this:
BlankClip(length=401, width=400, height=300, color=$616264).ConvertToRGB24() ShowFrameNumber(text_color=$fffffff, size=70, x=115, y=175, halo_color=$616264) ImmaWrite("F:\", type="png", info=true, start=2, end=5, magick_home="C:\WINDOWS\system32") Does ImmaRead work? |
25th August 2008, 21:45 | #66 | Link |
No images are saved, although here is what goes up: http://www.imagebam.com/image/fd117c11932204
The directory D:\lol\ exists. I will check ImmaRead after a bit. |
26th August 2008, 18:08 | #69 | Link | |
Stakiman, i've forwarded your question to gzarkadas. I hope that he can help, because i've no idea what the problem is. |
27th August 2008, 09:42 | #70 | Link | |
It’s because, the new version don’t work with my program. In my AviSynth scripts i’m working with relative path names (relative to the program directory). The Image Magick dll’s are in the program directory. Version 1.32 works fine so far. The new version needs the magick_home variable. How can I tell ImmaRead or ImmaWrite that the Image Magick dll’s are in the current directory (or in a subfolder)? What, if magick_home is not set? Is it possible to look in the current directory for the Image Magick dll's in that case? |
27th August 2008, 17:34 | #71 | Link | |
Btw, there's a similar bug in ImmaRead (it reads images from the same location at the script).
16th December 2008, 17:06 | #74 | Link |
I'm attempting to load an image sequence where only the heights of the images differ. I'm using the size_x and size_y parameters, but no matter what I do, it won't correctly load any images in the sequence unless they have the same height as the first image. The other images are just displayed as:
ImmaRead: image [filename] Code:
ImmaRead("*.bmp",start=35,end=735,gapless=true,size_x=848,size_y=90) I'm using v1.40 Last edited by qyot27; 16th December 2008 at 17:09. |
16th December 2008, 19:08 | #75 | Link | ||
Could you upload 4-5 bmp's which won't load somewhere (cause i can't replicate the issue)? Quote:
ImmaRead("*.bmp",size_x=848,size_y=90) Code:
ImmaRead("pic%3d.bmp",start=35,end=735,gapless=true,size_x=848,size_y=90) Code:
ImmaRead("pic%03d.bmp",start=35,end=735,gapless=true,size_x=848,size_y=90) Last edited by Wilbert; 16th December 2008 at 19:18. |
16th December 2008, 21:36 | #76 | Link |
AviSynth plugger
have we some source filter for reading jpeg, which directly import to YV12 without intermediate RGB conversion? Most jpegs have YV12 or YV24 internal format (IMO).
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. |
17th December 2008, 07:24 | #77 | Link | |
I only found out about this plugin a couple of hours before I posted, and downloaded it directly from the webpage linked in the first post.
In other words, depending on the height the starting image is, a different set of images after it won't load. It's not predictable except by the dimensions of that first image. In any case, I've attached a sample containing 8 bitmaps of varying heights and the script. |
17th December 2008, 21:10 | #79 | Link |
@qyot27,
I think i fixed it. Could you try it again? http://www.geocities.com/wilbertdijkhof/immaavs.dll |
18th December 2008, 14:52 | #80 | Link | |
Do I have to redo my system settings like I did when I initially installed, or is it something else? |
