16th February 2009, 11:17 | #1082 | Link |
Programmer (or just 教务长)
It is out of the scope of this thread, but:
Option 1: use software product to make it for you. There are a lot of tools in this forum. Option 2: you need to have * AVC decoder * AVC/h264 splitter * AviSynth Create a simple AVS script to process your video file, adding borders. For example if you have 1920x800 video, you need to add 140 pixel on both top and bottom sides. Easiest way to get it done is with: AddBorders(0, 140, 0, 140) Of course you can write it this way: myheight = (width()==1920) ? 1080 : 720 bordersize = int ( (myheight-Height() )/2 ) AddBorders(0, bordersize, 0, bordersize) It will add top and proper top/bottom borders for 1920x.... or 1280x... clips. |
16th February 2009, 11:36 | #1084 | Link |
Avisynth is a frame server and can be used with directshow.
Let's say you have a video file of non-compliant resolution called Movie.mkv. Copy and paste this code in notepad and save it as Movie.avs Code:
directshowsource("D:\MyFiles\Movie.mkv",audio=false) orgheight = int( Height() / 2 ) * 2 myheight = (width()==1920) ? 1080 : 720 bordersize=int( (myheight-orgHeight )/2 ) AddBorders(0, bordersize, 0, bordersize) ConvertToYV12() Don't forget that complete re-encoding to AVC (with x264) for hour and a half movie could take 2-4 hours on a fast machine (and sometimes a lot more - depending on x264 parameters). What avisynth does is process each frame of your video, apply these transformations and outputs the changed frame to your player or encoder. So you will need to give this script as input to x264.exe and it will produce a nice .264 file that you can mux with tsmuxer. A nice Picture in Picture for custom menu may be created in seconds with avisynth and look like this: creating 2 video (motion) thumbnails of two titles playing for 10 seconds and creating title preview Last edited by deank; 16th February 2009 at 13:04. |
16th February 2009, 13:11 | #1086 | Link |
We're really getting off-topic here. For a quality encoding you must give it a time... Two pass encoding takes more than twice longer but creates better quality videos. It all comes to x264 settings. And of course your machine performance is one of the major factors.
16th February 2009, 14:48 | #1087 | Link |
A preview of what can happen in some of the next releases:
15 seconds video for top menu (preview)... (10MB) Last edited by deank; 16th February 2009 at 15:05. |
16th February 2009, 14:54 | #1088 | Link | |
instead of putting a preview of the movie one could also put a picture like the front cover as preview.... this could be also much more faster and more simpler than a clip that had to be encoded first?! as i said , just a proposal |
16th February 2009, 15:40 | #1091 | Link | |
н∂-ƒαиαтι¢
ps. pls can everyone stay on topic.. Last edited by ~bT~; 17th February 2009 at 01:20. Reason: typo |
16th February 2009, 19:01 | #1093 | Link |
Yes, prediction is like ~ +10%... not a real value to count on, but most of the time the difference is about 10-300MB which is not a big deal and the output is almost always a bit smaller then the prediction (it is better having your output a bit smaller than the prediction and having it fit in the output media).
16th February 2009, 20:27 | #1094 | Link |
yes you are correct, however this is not true when adding a single m2ts file.
in my case i added a 7.93GB m2ts. the estimate shows around 8.8GB. now, i know this is wrong, but it could easily mislead ppl who doesnt have this info. if removing this feature when adding avchd/m2ts is a problem i guess we can live with it |
16th February 2009, 21:01 | #1095 | Link |
Brazilian PS3 Fanboy
+1 donator, just as I promised.
Keep up the good work!! I've been advertising your program on a brazilian PS3 forum, check it out: http://www.htforum.com/vb/showthread.php?t=91999&page=1 Cheers! |
16th February 2009, 21:05 | #1096 | Link | |
Compilation contents as subtitles, audio tracks that will be reencoded or not included or.... or... - they all affect output size and there is (probably) no application that can give you estimate output in advance. I can remove this info, but I don't see the point. If one uses the program long enough or is aware of media input, he won't rely 100% on the 'estimated output' value. It is just for guidance... Hence the "~" symbol. @jdeiro: I know I read it every day. Thanks Last edited by deank; 16th February 2009 at 21:07. |
17th February 2009, 19:37 | #1097 | Link |
hi, I'm using multiavchd build 386 to build a bluray
with advanced options keep all audio tracks + add external audio tracks + and keep original - activated but still have trouble. the true-hd is converted again and only 10 of 23 subtitles are added. also track infos are lost :-( |
17th February 2009, 19:43 | #1098 | Link |
I don't know who would need 23 different subtitle tracks when using multiAVCHD for HOME ENTERTAINMENT.
About True_HD - you need to remove the checkbox to convert TrueHD to AC3, but it will not be muxed properly (because of tsmuxer). You can use another tool to fix the TrueHD track - it came up few days ago - take a look at AVCHDmanager thread. |
18th February 2009, 03:45 | #1099 | Link |
deank,
Another donation! (actually five days ago, but had to wait to post) Thanks again for making this program! I burned a AVCHD format disc with 4 clips from a Canon HF100 using the custom menu, played on a Panasonic DMP-BD35 NTSC. Everything worked perfectly! The only unexpected item I noticed was that if I picked white for the text color, the main title was gray instead of white, but the list of video titles were in white. If I selected other colors, the main title and video titles were the color chosen. It showed up that way on the preview as well. (I really like the title listing preview!) This tool was the missing piece to my camera-to-archive puzzle. This is the only tool I have found that can use an "average" computer to archive AVCHD video to disc (since there is no processing of the original footage). Your title additions over the last couple of weeks have really upgraded the quality of the end result. Thanks again, and I'll be ready to test the panasonic SDHC card version if you happen to add that functionality. |
18th February 2009, 05:10 | #1100 | Link |
Upon further review (Build 386), the main title is always a few shades darker than the video titles, so I'm guessing that was by design. It's easy to work around because of the preview capability...I just got caught having a gray background, where the white lettering was clear but the main title was a little hard to read.
The following aren't major items, but I'm just hoping to help with small cleanup items, as finding them yourself can get very tedious. Let me know if you need or want further clarification on these below. How is the file order determined when dragging multiple files over to the Media tab? I dragged file names 00000.MTS through 00024.MTS over to the media tab, and the order was shown as 00019-00024, then 00000-00018 (The list will always be in order , but the first file will be down in the list somewhere instead of the top). I noticed then that if no files are selected and del is pressed, it will take the top file and move it to the bottom of the list, so by hitting the delete button a few times I was able to get the list showing in chronological order, 00000-00024. Once I found that out, it was easy to get the listing the way I wanted it. Once when I was adding and removing files, I deleted all of them but had one still listed in the Title editor. adding and removing programs did not get rid of it, though I did not use the clear button. I restarted the program and couldn't reproduce it. Thanks! |
