20th April 2004, 12:34 | #1923 | Link |
noise is all around us...
i wanted to view the printable version of this thread on one page in order to search for something easier and i got:
Fatal error: Allowed memory size of 8388608 bytes exhausted (tried to allocate 2188533 bytes) in /home/httpd/docs/vbb/admin/functions.php on line 582 is this thread to long?
((( atom ))) |
20th April 2004, 15:32 | #1924 | Link | |
Re: Re: Re: Re: Question
20th April 2004, 21:14 | #1925 | Link | |
BeSweet Author
if someone is into extreme normalization, he can change his personal default mode to using -azid( --maximize ). postgain of 18db [like you could see in the logfile of "-ota( -G 1 )"] will never make sense to me.
FAQs : BeSweet, Audio :readfaq: Homepage : DSPguru's Webpage http://dspguru.notrace.dk/cs.gif Guides : Multilingual Guides of my tools http://dspguru.notrace.dk/1zhelp.gif Last edited by DSPguru; 20th April 2004 at 21:16. |
21st April 2004, 10:13 | #1926 | Link | |
I'm afraid we've to stop
P.S. Personally I have no opinion on the subject as very rarely do mp3 myself.
Gordian Knot Family: Gordian Knot: website, download Auto Gordian Knot: Website and download, tutorial, FAQ |
21st April 2004, 13:37 | #1927 | Link |
Xubuntu21.04 AVS+3.7 x265
hi, dunno know if it's really a bug, but autogk saying chosen resolution ***x304, but final avi is ***x288...
=========================================================== [21.04.2004 08:45:59] Duration was: 12 minutes 35 seconds [21.04.2004 08:45:59] Speed was: 8,07 fps. [21.04.2004 08:45:59] Compressibility percentage is: 20,38 [21.04.2004 08:45:59] Using softer resizer. [21.04.2004 08:45:59] Using softer resizer. [21.04.2004 08:45:59] Chosen resolution is: 512x304 ( AR: 1,68 ) [21.04.2004 08:45:59] Predicted comptest value is: 32,35 [21.04.2004 08:45:59] Running first pass. [21.04.2004 08:45:59] Writing the following script to D:\tmp\gk_tmp\asterixinamerika_movie.avs =========================================================== LoadPlugin("c:\PROGRA~1\DVDRIP~1\AutoGK\filters\mpeg2dec3dg.dll") LoadPlugin("c:\PROGRA~1\DVDRIP~1\AutoGK\filters\autocrop.dll") LoadPlugin("c:\PROGRA~1\DVDRIP~1\AutoGK\filters\undot.dll") LoadPlugin("c:\PROGRA~1\DVDRIP~1\AutoGK\filters\kerneldeint.dll") function getOrder(clip c) { order = GetParity(c) ? 1 : 0 return order } movie = mpeg2source("D:\tmp\gk_tmp\asterixinamerika.d2v") cropclip = autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=10,aspect=0,threshold=35) c_width = width(cropclip) c_height = round(height(cropclip) / 1.09401709401709) input_par = float(c_width)/float(c_height) fixed_aspect = input_par > 1.4 ? 1.09401709401709 : 1.06666666666667 c_height = round(height(cropclip) / fixed_aspect) input_par = float(c_width)/float(c_height) out_width = 512 out_height = round(float(out_width) / input_par) hmod = out_height - (floor(out_height / 16 ) * 16) out_height = (hmod > 4) ? (out_height + (16 - hmod)) : (out_height - hmod) new_aspect = (float(out_width) / float(out_height)) / fixed_aspect KernelDeInt(movie,order=getOrder(movie),sharp=true) autocrop(mode=0,wmultof=4,hmultof=4,samples=10,aspect=new_aspect,threshold=35) Undot() BicubicResize(out_width,out_height,0,0.5) XviD, 876 kb/s, 512x288 (1.78:1) [=16:9] just wanna to drop you this info...
Xubuntu 21.04 // AviSynth+ 3.7.0 (r3406, master, x86_64) // x265 3.5+20+2-8c44f9e9b [DJATOM's Mod] |
21st April 2004, 14:05 | #1928 | Link | |
21st April 2004, 16:23 | #1930 | Link |
ht bug
lenox > is there public cvs server for autogk ? i would like to fix the HT bug coz its annoying me very much, when i set compatibility with windows 98 for autogk it runs virtual dub in some weird mode
with one cpu affinity and makes my whole computer superslow, i have to run into taskmanager and change affinity for the vdub process everytime, if there isnt public cvs please contact me on hujer@users.sf.net and let me know if i can help you fixing this crash somehow, its really pissing me off, thanx for autogk btw |
22nd April 2004, 02:07 | #1931 | Link | |
DVD Rebuilder!
I mean in your .credits directly use the timestamp instead of the frame #. So the conversion is done by your internal code. thank you. |
22nd April 2004, 10:00 | #1932 | Link | |
23rd April 2004, 03:25 | #1933 | Link | |
I sent you a new version which can read CLI parameters - you might be able to add a button to AutoGK now to launch the "Hidden Options.exe" after the user selects the input directory, that would probably simplify things a bit for many users. v-0.6 (April 22, 2004) ---------------------- -Added CLI (Command Line Interface) - 'Hidden Options.exe' can now accept the target path as a command line parameter. I coded it to be fairly forgiving, you can use one of the following formats: "z:\hidden options.exe" x:\path name "z:\hidden options.exe" -x:\path name "z:\hidden options.exe" /x:\path name You can enter the path in all caps, all lower case, or a mix, it doesn't matter. You can also either add or omit the trailing "\" Also checks if the drive and path exists, and provides error messages if not. -Added error checking when selecting an empty CD or Floppy Drive from the drivelist pick-box - program would crash with runtime error before (not like you're going to actually work from one of those sources, but you might pick it by accident).
Cheers, The REAL Joe |
25th April 2004, 23:39 | #1934 | Link | |
º¿º XviD N00B º¿º
Re: ht bug
That bug really irritates me too. I usually disable Hyper Threading in bios before encoding with GK |
26th April 2004, 08:54 | #1935 | Link | |
Re: Re: ht bug
26th April 2004, 09:59 | #1936 | Link |
It would be nice to have a priority setting for AutoGK. Similar to the one in DVD2SVCD ("Process priority for all used programs" -> Idle|Normal|High).
Mainly for running AutoGK and still be able to use the PC for other stuff (using the "idle" setting). Regards /max |
26th April 2004, 10:34 | #1937 | Link | |
Re: Re: Re: ht bug
I had another ago but still unable to detect the problem so far...
26th April 2004, 14:52 | #1939 | Link |
RE HT bug(?)
lenox is in the process of trying to figure out what the bug is so far after numerous attempts theres been no luck he is hard at work at it so give him some time and support as it must be frustrating when he cant test directly as he does not have HT cpu otherwise on my cpu 1.18b starts up 50% of the time and the other 50% it says runtime error 216 at XXXXXX I dont have it set to compatibility mode ie im running it normally when it does start up it runs perfectly with both cpus as affinity and on the right priority without slowing down my comp for those of you who are using compatibility mode or turning off ht try not doing so and just keep clicking on the exe till it starts up (as i said on my comp its 1/2 chance of it working but once started everything works!) JEREMY
The Ferrets Are Out To Get You ..... Muwahhhhhaaaa Alienware Area 51 PC, 3.2ghz P4C 800mhz FSB, 1X Western Digital 10,000 rpm Raptor 74 gb SATA, 1X 80 Gb IBM Deskstar 120GXP and 7200rpm 2 mb cache, 1X 80 Gb Hitachi Deskstar 7K250 7200 rpm SATA 8mb Cache (The Two 80Gb drives are striped with win XP dynamic disks) and 1X 5400 Maxtor 30gb Drive , 1 Gb XMS corsair pc 3200 ram (2X512), ATI Radeon 9600XT, 8X +/-R Plextor DVD Writer PX-708A,LiteON 52X32X52 CDwriter, 19" Iiyama Vision Master 1451 monitor, Audigy 2 ZS, Nebula DigiTv USB 2.0 version For DVB-T, Leadtek WinFast XP/2000 Expert For TV Capture And Analogue TV, Logitech Cordless Desktop MX (MX 700 mouse Cordless optical and cordless keyboard) |
26th April 2004, 15:04 | #1940 | Link | |
lenox if you still have problems finding the problem after some time, feel free to mail me, to debug it one only needs the code that runs on startup, that should be only few onshow/onload functions and you can strip rest of the project..., well anyway, good luck, its a nasty problem |
