8th April 2009, 19:13 | #2441 | Link | |
8th April 2009, 19:18 | #2442 | Link | |
Resolution Frame rate Aspect ratio Codec 1920x1080 59.94-i, 50-i 16:9 1920x1080 24-p, 23.976-p 16:9 1920x800 24-p, 23.976-p 2.40:1 1440x1080 59.94-i, 50-i 16:9 MPEG-4 AVC / SMPTE VC-1 only 1440x1080 24-p, 23.976-p 16:9 MPEG-4 AVC / SMPTE VC-1 only 1280x720 59.94-p, 50-p 16:9 1280x720 24-p, 23.976-p 16:9 720x480 59.94-i 4:3/16:9 720x576 50-i 4:3/16:9 http://en.wikipedia.org/wiki/Blu-ray_Disc |
8th April 2009, 19:40 | #2443 | Link | |
south winners '87
bye |
8th April 2009, 21:54 | #2445 | Link | |
9th April 2009, 12:09 | #2447 | Link |
It's hard to tell what your problem is. BDRebuider "will" extract the dts audio track properly if you don't keep the HD audio.
1. Start by reading this guide which will explain the proper use of the audio options if it's unclear to you. http://forum.doom9.org/showthread.php?t=145024 2. Make sure you are not using the version of tsmuxer that comes with 20.05, obtain the latest version, 1.8.35 works. 3. Start from scratch after you've done these 2 things. You could work from your working files, but it would be hard to explain if you only have basic experience with this stuff. 4. Try reading back through several days of this thread to get a feel of what others have been doing to solve their issues. |
9th April 2009, 14:17 | #2448 | Link |
A bit of help please, slightly off topic.
I have just got Wallace and Gromit Loaf and Death and I'm going to make a back up before the kids have chance to trash it. The actual disc is only 9.5Gb, with the movie 6.5 Gb. I have run it through BD-RB fine and there is no issue. However, it's obvious that I can keep the main movie intact and only re-encode the extras. I therefore ran bd-rb again and forced a smaller custom size. This was fine and now I want to create a new structure. If I copy the m2ts and clpi file from the original everything functions correctly but I get dumped into the movie about halfway through. If I use the clpi from the bd-rb everything is fine except I can't access the True HD audio (it says Dolby Digital and there's no audio). The question is which clpi (or other file) should I look to modify - the original with the wrong offset or the new one with the wrong audio flag. I have played a bit with bdedit, but can never figure a way of editing the audio streams, and have heard of fixclpi but that doesn't sound quite what I need. |
9th April 2009, 15:42 | #2450 | Link | |
**Everything is fine on a PC but on a Sony standalone the main movie video and audio are very jerky - quite strange as they are untouched. Last edited by drmih; 9th April 2009 at 23:29. |
9th April 2009, 19:02 | #2451 | Link | |
south winners '87
"The first option "Do no convert DTS to AC3". If this is selected and your bluray has a DTS\DTS-HD\DTSMA audio track, then it will not be re-encoded to AC3" i can say there's a bug in 20.05,cause i get ac3 with this option selected. may be it's tsmuxer,cause i've used the one in bdrb's package @+ |
9th April 2009, 21:40 | #2452 | Link |
Twilight Region B doesn't work, replaced tsmuxer with new one so i can keep HD audio (5.1 dts-hd master audio)
Summary of problem , disk boots fine, plays studio logos and trailers, goes to main menu - any attempt to play film either from play movie command or scene selection results in play looping back to main menu... any attempt to play extras results in audio, but no video My reults are on panasonic BD30, i am no longer using fixclpi=0 since this was apparently fixed. If you need any more details please let me know what. p.s. if you count a lot of universal titles there is a mounting list of films that this program doesn't work with.... |
10th April 2009, 00:42 | #2453 | Link | |
Older versions don't work well with HD audio, newer versions break playback in some standalones with bluray output (which BD-RB uses). |
10th April 2009, 03:39 | #2454 | Link | |
10th April 2009, 10:39 | #2456 | Link | |
10th April 2009, 11:05 | #2457 | Link |
If you already had some success with tsmuxer 1.8.35+ then it won't be that, it's just that the bluray output changed dramatically with these new versions and I haven't seen one report of a player that's working with it. 1.8.30 works fine with HD audio unless you have DTS MA and popcorn hour or tvix player.
10th April 2009, 11:33 | #2458 | Link |
Did South Park S12 D3 last night. Original disc is 26.6 GB and Full Backup turned out to be only 21.4 GB. So while the backup is undersized, it seems to be working perfectly, TrueHD audio and all. Used RB v0.20.05 with tsmuxer 1.9.1(b).
10th April 2009, 12:02 | #2459 | Link |
hi,
i've tried reenconding erin brokovich leaving true hd on disk,.... used actual bd-rebuilder and tsmuxxer 1.9.1(b). the reencodes disc works on computer, laptop and my bd-55, but the sound is stuttering. I've got this problem with any bd using keep hd audio. I'always do a movie only backup with the following sound configuration: keep hd audio = on dts reencode = off ac3 reencode = off ac3_640 off using tsmuxxer only to keep hd data, everything is ok,...., but the filsize is too high in some case so i have to use bd-rebuilder any ideas ? Last edited by Lif3styl3; 10th April 2009 at 12:05. |
10th April 2009, 12:41 | #2460 | Link | |
