25th March 2007, 20:27 | #901 | Link | |
DeepMeepBeep said:
25th March 2007, 21:58 | #902 | Link |
AviSynth plugger
I try to use ffdshow for realtime encoding to MPEG2 in AVI (constant bitrate, lavcodec).
I found that I must set "decoder bitsteam buffer size" to big value (about 10000000) and "maximum bitrate" to non-zero at "ratecontrol" tab. In other cases encoder freeze my system. may be it is possible somehow protect user from wrong settings. For example, use mean bitrate as a max bitrate, and auto-enlarge buffers to safe value (how to calculate it?).
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. Last edited by Fizick; 25th March 2007 at 22:29. Reason: typos |
26th March 2007, 00:07 | #903 | Link | |
26th March 2007, 00:08 | #904 | Link |
Hello, I have a problem and I can't find a solution.
Every time I close the ffdshow video or audio decoder configuration I get this error: "RunDLL An exception occurred while trying to run 'ffdshow.ax,configure'." I've installed XP SP2 and the latest ffdshow from free-codecs.com. Anyone know how I can fix it? Thanks in advance. |
26th March 2007, 02:24 | #905 | Link | |
I've only put in the functions needed for the OSD so far, because it's easy to tell when they're working and when they're not. I don't know what the other things (kernelDeint, TomsMoComp) should do, so I don't know how to tell if they're working or not. Edit: aha, the problem was I was using a signed function for something that should have been unsigned. With that fixed I now have a properly working OSD. Last edited by Dr Pizza; 26th March 2007 at 02:39. |
26th March 2007, 07:42 | #906 | Link | |
ffdshow/AviSynth wrangler
Look where the links are pointing to and make sure they're pointing at the directory where you last installed ffdshow, and probably clean up older installations if that's what's causing this... Removing all ffdshow versions and then installing just one should also fix it, I guess.
now playing: [artist] - [track] ([album]) |
26th March 2007, 08:30 | #907 | Link |
@haruhiko_yamagata
HERE is the ffdshow video preset that i use, referring my previous post...btw I've tried ffdshow_rev1074_20070325_clsid_sse_icl9 and it doesn't strech my anamorphic encodes (xvid/ac3/avi) while keeping green line in the right border. Last edited by SealTooGreat; 26th March 2007 at 08:37. |
26th March 2007, 09:56 | #908 | Link | |
Curious BetaTester
Asrock N68-S AMD Athlon(tm) II X4 620 Processor (2.6GHz) - Crucial 2GB PC6400 800MHz DDR2 - Nvidia 9600GT Tools: ProcessExplorer & ProcessMonitor - BatchCompressor Guide: MinGW Compiling GCC |
26th March 2007, 09:59 | #909 | Link | |
I found milan's 20051115 works, 20051129 does not work. beta1 works? I can't reproduce this. It's "Output->Allow output format change during playback". 3 mode for this was introduced between 20051115 and 20051129. Intermediate state does not work. It works with it checked and "Connect to compatible filters only" unchecked. If "Connect to compatible filters only" is checked MPC fails over VMR on Windows Xp. Haali's renderer is not working for me (probably because of my hardware). I have black screen. The AR changes correctly with 20051115 though. So my testing is not reliable. Should Haali's renderer be added to compatible filters? Please test rev 1075 with "Output->Allow output format change during playback" checked and "Connect to compatible filters only" unchecked. With the setting above, beta1 works, beta2a does not work. So I think I have understand your issue . Last edited by haruhiko_yamagata; 26th March 2007 at 10:46. |
26th March 2007, 12:07 | #910 | Link |
VMR9 deinterlacing with ffdshow
I have a question: is it possible to use VMR9 deinterlacing using ffdshow for decoding for example mpeg2 tv broadcasts? It is possible with dscaler5 when set to auto deinterlacing and nv12 output color space and also in coreavc (for h264 of course) when set to directshow deinterlacing. Has it something to overlay mixer hw deinterlacing option in outut tab? Regards Piotr |
26th March 2007, 12:54 | #911 | Link | |
@haruhiko_yamagata
"Use overlay mixer" also has to be checked in order to get correct AR and I always keep "Connect to compatible filters only" unchecked 'cause Haali Renderer is not on the list. And you are right it doesn't work with "Output->Allow output format change during playback" intermediate state. It seems that rev 1075 doesn't exist at ffdshow download page. Have you meant rev 1074?! Quote:
...I've rolled back to rev1006_clsid_sse_icl9 - works fine for me considering this problem I came on.(beta1 works fine too) Last edited by SealTooGreat; 26th March 2007 at 13:03. |
26th March 2007, 13:02 | #912 | Link | |
26th March 2007, 13:09 | #913 | Link | |
sidekick
ffdshow_beta2_20070319_clsid.exe PAR issue
other containers like mkv/mp4 don't show this behavior... info: latest mpc build by drevil_xxl latest haali splitter Edit: nevermind, rev 1075 should fix it
greets, kurt. Pioneer PDP-427 XA | Popcorn Hour NMT C-200 | Sony STR-DB 840 QS | Canton Ergo 91 DC Last edited by kurt; 26th March 2007 at 13:14. |
26th March 2007, 14:02 | #914 | Link | |
26th March 2007, 19:54 | #915 | Link |
AviSynth plugger
marcellus,
thanks. (My CPU is slow, so I try use 352x576. with max bitrate 4000. )
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. |
26th March 2007, 20:18 | #916 | Link |
Download
Patch (against rev. 1076) Another small update - I've added "applying pulldown" to the OSD info when pulldown is actually being applied. I've also added debug printouts, which can be activated by starting the Avisynth script with a "#debug" comment. Those printouts can be logged with utilities like Sysinternal's DebugView. np: Denzel + Huhn - Karlsruhe (Paraport)
26th March 2007, 21:29 | #918 | Link |
@Fizick
I don't know what cpu you have, mine is an AthlonXP 2600 (I wouldn't call it fast these days ) and I capture full PAL->Kerneldeinterlace->Mpeg2 encode. (the audio part is captured as wav, I convert it to mp2 after the capture). I always use icl9 ffdshow compiles, it really makes a difference. But keep in mind that a larger bitrate means more cpu needed (i don't know why) so that's why I keep it low at 1500 kpbs. 4000 kbps at 352x576 I think is overkill with libavcodec quality. I forgot to mention that I "cooked" a custom quantization matrix that works very well with libavcodec mpeg2 encoder (I tried it with Xvid too but although I got good results I sticked with H.236 for Xvid encodes): Code:
8,14,18,21,23,24,26,27 14,21,24,27,29,30,32,33 18,24,28,30,33,34,36,37 21,27,30,33,35,37,38,39 23,29,33,35,37,39,40,41 24,30,34,37,39,40,42,43 26,32,36,38,40,42,43,44 27,33,37,39,41,43,44,46 16,20,23,24,26,27,28,29 20,24,27,29,30,31,32,33 23,27,29,31,32,33,34,35 24,29,31,33,34,35,36,37 26,30,32,34,35,37,37,38 27,31,33,35,37,38,39,39 28,32,34,36,37,39,40,40 29,33,35,37,38,39,40,41 |
26th March 2007, 21:35 | #919 | Link |
Otaku
Audio request and a issue...
Hello
I was wondering if someone could add the wma decoder to the list of selectable decoders for WMA 7/8/9 like it it was done before but for WMV formats, so instead of using libavcodec I could use wma decoder within ffdshow. Also I found the following issue: If the plug in "dsp_stacker.dll" for Winamp is in the plugins folder after opening a file that uses ffdshow audio decoder if you try to open the audio decoder panel, the player (MPC in my case) hangs and you need to use the task manager to close it. This only happens if the winamp dsp option is enabled in ffdshow (i'm using enhancer for audio processing). Steps to replicate this event: Enable dsp processing in ffdshow with a plugin like Enhancer , install Multiple-DSP Stacker , open a file that uses ffdshow audio decoder and try to open the decoder panel. If you load the file then install the dsp stacker the panel will open normally and the dsp stacker will be listed in the dsp plugins list. Kado |
27th March 2007, 13:07 | #920 | Link |
Angel of Night
The wmv decoders do list wmv, as long as you have them installed correctly. I think it requires at least WMP9, I can't say for sure though, since I have 11 now.
Will have to test the DSP issue, although some DSP plugins just plain aren't coded very nicely, and practically none support greater than 16-bit stereo. |
