Old 17th July 2019, 12:45   #56881  |  Link
mrmojo666
Hi all, i want just to share my experience with 1903
Yesterday I've updated and no issues so far, to be honest i saw a small improvement in the rendering times.
HDR switch is working, no strange banding, FSE still working , 10 bit is working.
I have a amd card (rx460) and amd processor (ryzen)
bye
AMD Ry 1500x - 8GB - RX460 4GB
TV Philips 55pus6501+ Marantz 1608 avr
WIN10(1903) 4K/444RGB
Mediaportal - Mpc-hc
MADVR-D3D11/10bit
mrmojo666 is offline   Reply With Quote
Old 17th July 2019, 14:07   #56882  |  Link
tp4tissue
tp4tissue's Avatar
bye
Kekekekekeke..
Ghetto | 2500k 5Ghz
Old 17th July 2019, 14:48   #56883  |  Link
must be nice to be that ignorant of issues.
it doesn't affect me if i don't use it so there is no problem!
Old 17th July 2019, 15:16   #56884  |  Link
mrmojo666
are you talking to me ?
MADVR-D3D11/10bit
Old 17th July 2019, 16:08   #56885  |  Link
chros
chros's Avatar
Sometimes he's grumpy, just leave him be
Something else: madvrlabs
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v385.28),Win10 LTSB 1607,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED65B8(2160p@23/24/25/29/30/50/59/60Hz)
chros is online now   Reply With Quote
Old 17th July 2019, 18:01   #56886  |  Link
clsid
well that's bad for my bet because i have my bet on it get's fixed with a new WDDM version.
The WDDM version defines the API, not its implementation. They can fix it in one of the monthly updates.
Old 17th July 2019, 22:02   #56887  |  Link
Alexkral
I guess that the motion interpolation refers to the Envy, does anyone know any more detail about this? It could be a very interesting add-on, especially if it's CNN based.
Alexkral is offline   Reply With Quote
Old 18th July 2019, 00:02   #56888  |  Link
mclingo
bye
good to know thanks, i've put off upgrading for now, no reason to upgrade yet as everything works fine.
OLED EF950-YAMAHA RX-V685-Win101809-4K 444 RGB 60hz-AMD RX580 19.2.2
KODI DS - MAD/LAV 92.14/0.72.2 - FSE / 3D / DIRECT3D11 / 10bit
Old 18th July 2019, 00:06   #56889  |  Link
hannes69
every 1903 user with new GPU driver get's banding everyone so you going to tell me that 5% and this is not the first time and this will not be the last time.
Windows is a general purpose platform. I think it is quite normal that you have to 'fine-tune' for a special purpose like HTPC.
For most of the problems there are workarounds, updates or according settings like madvr rendering settings.
there is not a single know major problem with win 8 for years.
Maybe. Weīre talking about an OS already older than 5 years. We donīt live anymore in the 80s, there 5 years were a long time. How long do you want to keep this system? I know there are still fans for XP out there.
We canīt talk about Windows 10 vs. Windows 8 because of the new structure of Windows 10. We have Windows 10 1507 ... 1903 so we have to compare them and not simply talk about "Windows 10".
Windows 8.1 support ends January 2023, then there will be no discussion about this anymore. I think already today most of the HTPC users use Windows 10 as OS.
because you are willing to spend hours to fix win 10 don't except other user to waste there time.
Why do you think that I have any expectations?
Everyone can do what he wants to do in free-time.
The home cinema topic always leads to a kind of tuning, fixing, optimal setting and so on.
Wasting time is a relative matter. Some people have no problem with OS tinkering. Some have no problem with pixelhunting of 400% magnified single frames. All of this can be a fascinating hobby or a total nightmare, depends on the personality.
hannes69 is offline   Reply With Quote
Old 18th July 2019, 11:32   #56890  |  Link
Mano
Hi, how do i enable madvr to convert HDR content to SDR in mpc-hc?
Mano is offline   Reply With Quote
Old 18th July 2019, 11:54   #56891  |  Link
sneaker_ger
In MPC-HC: Options->Playback->Output select madVR as video renderer.
In madVR settings: devices->[your display]->hdr->tone map HDR using pixel shaders. Set "target peak nits" to a fitting value (until it looks "right" if you don't know).
Old 18th July 2019, 14:09   #56892  |  Link
Mano
Somehow BT.2390 doesn't let me go less than 100 (higher value make it too dark). With cliping, at 130 the brightness is about ok but for color the light blue disappear next to white cloud.
Old 18th July 2019, 16:46   #56893  |  Link
el Filou
el Filou's Avatar
With the latest test builds you can set it as low as 20 nits. https://www.avsforum.com/forum/24-di...ector-203.html
(note that those are not considered ready for general use so probably no support, there have been a lot of changes)
HTPC: Windows 10 1809, MediaPortal 1, LAV Filters, ReClock, madVR. DVB-C TV, Panasonic GT60, 6.0 speakers Denon 2310, Core 2 Duo E7400, GeForce 1050 Ti
Old 18th July 2019, 17:25   #56894  |  Link
cork_OS
cork_OS's Avatar
madVR use motion vectors matching for HDR processing.
I'm infected with poor sources.
cork_OS is offline   Reply With Quote
Old 18th July 2019, 20:31   #56895  |  Link
Siso
Siso's Avatar
Can anyone help me to create 2 profiles for 1.78:1 and 1.85:1 movies?
Old 19th July 2019, 06:08   #56896  |  Link
ryrynz
ryrynz's Avatar
Originally Posted by Siso View Post
Can anyone help me
Shown on the first page of this thread.
Supported numerical values:
AR, uncroppedAR, encodedAR cropped AR (aspect ratio), uncropped AR, encoded AR,
if (AR = 16:9) and (fileName = "*horribleSubs*.mkv") "Weird profile" else "Normal profile"
Easy peasy.
Old 19th July 2019, 06:11   #56897  |  Link
QBhd
QB the Slayer
QBhd's Avatar
It's easy... Frame rate is very important and Height... I use < signs and the list increases as you go down. I am sure you don't need all of these (I'm not even sure I still do after getting my 4k OLED) so you can edit these and remove some... but the logic is simple:
if     (srcHeight < 641)  and (deintFps < 25) "720p23 Univisium"
elseif (srcHeight < 721)  and (deintFps < 25) "720p23"
elseif (srcHeight < 1041) and (deintFps < 25) "1080p23 35mm Film"
elseif (srcHeight < 1081) and (deintFps < 25) "1080p23"
elseif (srcHeight < 2161) and (deintFps < 25) "2160p23"
elseif (srcHeight < 577)  and (deintFps < 26) "576p25"
elseif (srcHeight < 721)  and (deintFps < 26) "720p25"
elseif (srcHeight < 1081) and (deintFps < 26) "1080p25"
elseif (srcHeight < 541)  and (deintFps < 31) "540p29"
elseif (srcHeight < 721)  and (deintFps < 31) "720p29"
elseif (srcHeight < 1081) and (deintFps < 31) "1080p29"
elseif (srcHeight < 577)  and (deintFps < 51) "576p50"
elseif (srcHeight < 721)  and (deintFps < 51) "720p50"
elseif (srcHeight < 1081) and (deintFps < 51) "1080p50"
elseif (srcHeight < 541)  and (deintFps < 61) "540p59"
elseif (srcHeight < 721)  and (deintFps < 61) "720p59"
elseif (srcHeight < 1081) and (deintFps < 61) "1080p59"
QB
QBhd is offline   Reply With Quote
Old 19th July 2019, 14:49   #56898  |  Link
HillieSan
bye
Same success story here with an AMD RX 480 card. Drivers are very good and no issues for a very long time. I love AMD’s stable video refresh rate. The settings are high, but not very high. I use an GTX 1080 for games.
I am looking for the AMD RX 5700 as a replacement for the RX 480. I want to go to very high settings. Anyone experienced the RX 5700 (XT) with madvr?
PS. I didn’t noticed any banding. I will check the banding after the holidays.
HillieSan is offline   Reply With Quote
Old 20th July 2019, 00:14   #56899  |  Link
ryrynz
ryrynz's Avatar
My guess based on the only feedback given in this thread on the 5700XT us that for NGU it's about on the level of a 1080. So should be a significant step up over Polaris. Purchase it and give us some hard numbers please. We can compare performance as I have a 1080.
Old 20th July 2019, 08:05   #56900  |  Link
jespermart
No it's performance is much higher on my 5700 xt. You can se my settings in the settings bin from madVR. I just made a quick settings bin on my pc so all can see my scaling settings I use for all my 3 profiles, 2160p23, 1080p23 and 1080p3d. My rendering times are under 35ms on all settings. On my previous RTX2080ti I got stuttering, repeated frames every 4.7min bogus hdr and no more support for my 3d movies. On my 5700xt i have no stuttering, repeated frames every 3. hour correct hdr passthrough and support for my 3d movies
settings.rar
jespermart is offline   Reply With Quote
