27th September 2015, 09:15 | #161 | Link | ||
Great. It actually works. I've put it into a system directory and then it writes the config into /home/djcj/.config/Gpower2/gMKVExtractGUI/1.6.3.0/gMKVExtractGUI.ini |
27th September 2015, 09:27 | #162 | Link | |||
gMKVExtractGUI author
Thanks again! |
29th September 2015, 08:28 | #163 | Link | |
After reading the mkvmerge manual more carefully I noticed this:
So, I changed the code a bit, to set the needed environment variables to "C" locale when on Linux and not to use the "--ui-language" cli option. The environment variables values should only affect the current process, so you won't have to worry about messing with your locale settings. Could you check r82 without patching it and without adding LANGUAGE=C before running it? |
20th October 2015, 18:26 | #166 | Link |
the program keeps crashing for me after updating mkvtoolnix to 8.5.0. does anyone else have this problem?
21st October 2015, 06:54 | #167 | Link |
At what phase does the app crash?
It crashes immediately on start up? Or when you open a file? EDIT: It appears that the 8.5.0 installer deletes all files in "C:\Program Files\MKVToolnix" except the ones with "exe" extension. So if you had put the gMKVExtractGUI files in this directory, you will find that the file "gMKVToolnix.dll" is missing. In that case you should re-download gMKVExtractGUI and put all the files in the MKVToolnix directory again. Last edited by gpower2; 21st October 2015 at 07:00. |
21st October 2015, 19:01 | #168 | Link |
thanks, it works again.
29th October 2015, 10:12 | #169 | Link |
User of free A/V tools
Your tool does great job but there is one cosmetic annoyance that you could fix easily I hope:
Individual and total jobs percentage labels should be moved one row further down so as to align with their progress bars accordingly - see screenshot: |
21st November 2015, 12:51 | #172 | Link |
New version 1.6.4 is out, mostly containing fixes reported from users here, but the most exciting thing about this version, is that it's the first to fully support Linux, thanks to feedback from djcj!
Download link: http://sourceforge.net/projects/gmkv....4.7z/download Changelog:
Enjoy! |
13th December 2015, 12:05 | #173 | Link |
mkvtoolnix-64bit-8.6.1 breaks gMKVExtractGUI 1.6.4.0
The download binary name is gMKVExtractGUI 1.6.4.7, in fact it's 1.6.4.0. When I drag a MKV made with mkvtoolnix-64bit-8.6.1 it complain "Input string was not in a correct format". Thanks.
Hong Kong - International Joke Center (after 1997-6-30) Last edited by johnsonlam; 13th December 2015 at 12:09. |
13th December 2015, 13:03 | #174 | Link | |
Using MkvToolNix 8.6.1 works for me so you have to provide more details with your problem. First step would be to paste the results from the Log window. |
14th December 2015, 14:35 | #175 | Link | |
Attached was the log and the actual message dialog. Thanks. Rgds, Johnson.
Hong Kong - International Joke Center (after 1997-6-30) |
22nd January 2016, 02:26 | #176 | Link |
convert XML to CUE sheet
Hi, I'm trying to make CDs from some MKVs, and it would be VERY useful to be able to convert XML to CUE format. I need this:
PERFORMER "Electric Light Orchestra" TITLE "Hyde Park" FILE "Hyde Park.wav" WAVE TRACK 01 AUDIO TITLE "01 - All Over The World" PERFORMER "Electric Light Orchestra" INDEX 01 00:00:00 TRACK 02 AUDIO TITLE "02 - Evil Woman" PERFORMER "Electric Light Orchestra" INDEX 01 04:29:10 ... instead of this: <?xml version="1.0"?> <!-- <!DOCTYPE Chapters SYSTEM "matroskachapters.dtd"> --> <Chapters> <EditionEntry> <EditionFlagHidden>0</EditionFlagHidden> <EditionFlagDefault>1</EditionFlagDefault> <EditionUID>16840779534454836898</EditionUID> <ChapterAtom> <ChapterUID>11141243726119184491</ChapterUID> <ChapterTimeStart>00:00:00.000000000</ChapterTimeStart> <ChapterFlagHidden>0</ChapterFlagHidden> <ChapterFlagEnabled>1</ChapterFlagEnabled> <ChapterTimeEnd>00:04:29.135533333</ChapterTimeEnd> <ChapterDisplay> <ChapterString>01 - All Over The World</ChapterString> <ChapterLanguage>eng</ChapterLanguage> </ChapterDisplay> </ChapterAtom> <ChapterAtom> <ChapterUID>11775360033362589863</ChapterUID> <ChapterTimeStart>00:04:29.135533333</ChapterTimeStart> <ChapterFlagHidden>0</ChapterFlagHidden> <ChapterFlagEnabled>1</ChapterFlagEnabled> <ChapterTimeEnd>00:09:09.882666666</ChapterTimeEnd> <ChapterDisplay> <ChapterString>02 - Evil Woman</ChapterString> <ChapterLanguage>eng</ChapterLanguage> </ChapterDisplay> </ChapterAtom> ..... |
22nd January 2016, 11:45 | #177 | Link | |
Matroska find' ich toll
Such a feature was requested for my chapterEditor and its on the ToDo list. The person are used this tool(chap2cue) at the moment. |
28th January 2016, 10:06 | #178 | Link | ||
Could you upload me a piece of the video that throws the error in order to properly debug it? Quote:
You could use another utility like hubblec4's chapterEditor. |
29th January 2016, 13:29 | #179 | Link | |
Don't know whether you have already noticed, the log johnsonlam provided contains some question marks (track_name for the subtitle tracks, and file name for attachment id 6), which indicates a very possible text encoding issue. MKVToolNix used to write BOM for UTF-* encoded text files, but version 8.6.0 of MKVToolNix included a change to not write BOM anymore. The change has been reverted in 8.7.0. Considering johnsonlam was using an affected version (8.6.1), would it be possible that the problem is caused by that change? I suggest johnsonlam giving 8.7.0+ a try, to see if the problem still exists. |
2nd February 2016, 19:00 | #180 | Link | |
extractor, gmkvextractgui, matroska, mkv, mkv extract, mkvextract, mkvextractgui |
