27th December 2012, 23:37 | #16642 | Link | |
Also, why not just leave the "refresh" tag instead of "refreshRate"? It doesn't really need fixing.
MSI MAG X570 TOMAHAWK WIFI, Ryzen 5900x, RTX 3070, Win 10-64. Pioneer VSX-LX503, LG OLED65C9 |
28th December 2012, 02:27 | #16643 | Link | |
My mini-server's C2D P8600 (1.6 ~ 2.4GHz) + dual-ch DDR3-1333 is not powerful enough to handle such material, either. My HPTC is C2D E8400@3.6GHz + dual-ch DDR2-800. There is no problem for this CPU to deal with all Hi10 1080p24 contents. Since H.264 Hi10 profile is not used in any industrial standard, I guess no graphics chipset vendor even considers to support such mode decoded with the GPU's video bitstream processor. So... Hi10p 1080p24~ needs a more powerful CPU --- at least Core2Duo 3 GHz performance level. (I guess) |
28th December 2012, 03:20 | #16644 | Link |
Kid for Today
I still would welcome a SD/HD threshold(as these days there are obviously far more WMV/XVID HD-to-SD 709 encodes around than upscaled PAL DVD's) but I've just been confirmed that the next build of PotP will advertize the first filename when opening a bunch of movies in seamless playback mode so at least tags will work
28th December 2012, 15:43 | #16645 | Link |
I've tried to reset the settings using "restore default settings.bat" but nothing has changed. I've looked in the registry to "HKEY_CURRENT_USER\Software\madshi\madVR" and there is only the key "LastSettingsKey". How can I do the reset? I'm using the Windows 7 x64. Thanks |
28th December 2012, 22:15 | #16648 | Link | |
From another forum:
28th December 2012, 22:26 | #16649 | Link |
With latest madvr and latest mpc-be auto play works again on extended display, thanks madshi if you fixed it.
ajp_anton: The bottom 2 lines are damaged of every mod2 video I've seen, avisynth problem I think, that one is no exception. It can be really annoying at times if you look for it. I'm glad madvr is cropping to mod4 but wish it wasn't stretching back. DXVA2 resizing with a little edge enhancement is very pleasing to my eyes, even if it is just bilinear with post-unsharp. I wonder what the more sophisticated resizers would look like with a post-unsharp. Last edited by turbojet; 28th December 2012 at 22:42. |
29th December 2012, 00:47 | #16650 | Link | |
Addition to the above, after I asked about scaler algo:
I don't want madVR to crop it. It shouldn't try to protect the user from bad encodes, it's the encoder's job to do the job right in the first place. Even if h.264 somehow inherently sucked at mod2 (which it doesn't) and a codec-based fix is needed, that would be the job of the decoder. Last edited by ajp_anton; 29th December 2012 at 00:54. |
29th December 2012, 02:57 | #16651 | Link |
I suggest to give the chance to adjust color and a transparency of panels Exclusive mode.
Win7x64 Core i7 920 3.5GHz Noctua NH-D14/ArcticCooling MX-3 6(3x2)GB Transcend 1426MHz RoyalHD (64MB)[Solo6c][JPLAY]/HD7850DC22GD5V2[EIZOT965] Seasonic X-750 VelociRaptor WD4500HLHX/16TB_STORE |
29th December 2012, 09:12 | #16652 | Link |
I spoke too soon about auto play working again with latest madvr+mpc-be, it only works when player is opened on primary display then moved to extended display when it used to pause. If player is open open extended display it starts paused every time still. Madshi can you let me know if it's madvr or mpc-be's issue to fix?
While I agree it really isn't the video renderer's responsibility to fix badly encoded files but it does the job currently, same could be said for colormatrix issues. I found out it's x264 to blame for the damaged lines when height is not mod4 and reported it. |
29th December 2012, 23:09 | #16653 | Link |
Thank you, madshi for implementing the custom pixel shader trade-offs!
On my laptop the result is: 1. doesn't make a difference if it's on or not: store custom shader results in 16bit... 2. the other is making the difference: run custom shaders in video level... 3. "don't use copyback for DXVA decodeing" causes bigger GPU usage if it's enabled !!! (using LAV dxva native) GPU:62%/69% , VPU: 23%/27% !!! , MCU: 42%/50% And when I enable it on the fly it results constant green picture (it works fine in the opposite way). Edit: tested with the v306.97, now I realised that a newer whql is out, I will test them again ... Edit2: situation is the same with the new v310.70 driver.
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config Last edited by chros; 30th December 2012 at 12:25. |
30th December 2012, 13:51 | #16654 | Link |
I honestly don't think my eyes are deceiving me, overlay looks to be smoothest option.
I don't have dropped frames without overlay, possible or placebo? Each time I look at overlay I can see it, like it's rendered to the screen ever so slightly faster. |
30th December 2012, 15:46 | #16655 | Link |
quality 'first
v0.85.5:
* up to 56% speed improvement for Jinc3 chroma upscaling * up to 40% speed improvement for Jinc3 AR chroma upscaling Madshi you are a genius, I was buying a new video card and suddenly my 6670 is powerful enough, but..........What did you done? A pact with the ? Are you sure there is the same quality in this Jinc3 than before? I have a bad feeling about this and jinc3 works too good to be ruined by compromise. Good year, Fabio |
30th December 2012, 15:50 | #16656 | Link |
By hard-coding certain parameters, you can easily speed up algorithms, i have no doubt that its still at 100% quality.
Of course these optimizations only work for certain special cases, in this case a clear 2x scaling, which chroma typically is.
30th December 2012, 17:03 | #16657 | Link |
Surely 2x is rarely used for luma. Chroma 2x is obviously very useful for 1080p content on a 1080p screen but no-one has any 960x540 videos, do they? I guess those with 2560x1440 screens playing 720p content would count but if you have screens that size, surely your content would be mostly 1080p.
In any case, Jinc for chroma with 2x scaling still isn't fast enough on my HD4000 (playing a 1080i/25 file on a 1080p screen).
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 |
30th December 2012, 17:05 | #16658 | Link | |
30th December 2012, 17:10 | #16659 | Link |
soy sauce buyer
I wonder if upscaling to 2x by Jinc3 and then downscaling to 1.9x by Bicubic (or any other 2-tap stuffs, or even Bilinear) would be faster than directly upscaling to 1.9x by Jinc3 or not since 0.85.5. If it's significantly faster, it might probably worth a try even if there is a tiny quality loss.
30th December 2012, 17:21 | #16660 | Link |
Kid for Today
Yeah I was recently wondering the same stuff as this was discussed ages ago and 16/9 1440*1080 stuff is really a GPU hog here, but I'm quite sure that madshi wouldn't force double scaling anyway.
All this said I've got the automatic PS gamut mapping profiling stuff working in PotP(and also 4:3 AR for 720*576 movies) and I'm always stunned by how good the AVS script looks, getting accurate colors really seems to increase the subjective CR.....that's what struck me when I first tried it on a "Mitsubishi HC3100" ages ago and it's just as apparent on my CRT...mix it w/ the killer 24p smoothness of mVR + Reclock and movies just look so true to life There's only one last slight bug in PotP's automatic rules that would need to be ironed out but I guess I'm slowly running out of excuses to not ordering the BenQ W1070 at this point I also see refurbished HD5870's being sold for 80€(w/ a 1y warranty), and that's quite tempting as it would appear to be almost as fast as the GTX660. I know that Jinc3 AR looks AMAZING, but tossing 200€ on a board that will be worth 30€ 2 years from now makes me feel conned OTOH, I wanted to play around with 1080i@59.94fps and that'd be a no-go on the 5870's apparently.. Last edited by leeperry; 31st December 2012 at 03:36. |
