23rd July 2017, 15:14 | #44422 | Link | |
Changed DSPlayer for MPC-HC, still crashes. Or well, rather it doesn't play. Then if I open it just in MPC-HC, it plays fine O.o Anyone have a clue? |
23rd July 2017, 17:15 | #44423 | Link |
No clue. Which one is it in MPC-HC: "still crashes", "doesn't play" or "plays fine"? I'm afraid you'll have to be more specific.
Roelofs Coaching |
23rd July 2017, 17:24 | #44424 | Link | |
Make sure you have only Lav Filters + madVR only . Did you set the player correctly ? how does it crash, is there video ? sound ? What the event viewer error say ? it might tell us if it's DLL with other program,plugin,software,driver. You have Windows 10 x64 with newest drivers ? Nvidia , ATI ? |
24th July 2017, 09:11 | #44425 | Link |
I have actually manged to "fix" it.
I am/was only using Lav Filters + MadVR. What was happening was I tried to play a movie located on my NAS, quite a large movie I may add. Upon opening it with DSplayer from inside Kodi, Kodi/DSplayer would just crash. (not sure why it crashes with a generic error) Upon opening it with MPC-HC it faired "Fine", until I started it from inside Kodi. Starting MPC-HC from inside Kodi it took ALOT longer to actually be able to play it. Up to the verge of me thinking it just wouldn't load/work. For some reason it pulled in ALOT more data before even being able to play. (Noticed this when I was looking at Task Manager when doing the troubleshooting) So thanks for the help and advices |
24th July 2017, 21:50 | #44427 | Link |
New Nvidia drivers (384.94) have a HDR fix for windows 10.
Now its possible to activate the HDR and advanced color slider when using Nvidia colour settings even when set as RGB full 8-Bit. They seem to have fixed the Nvidia HDR API. When starting a HDR file with the windows option disabled the screen does switch to HDR so that suggests working Nvidia API. The problem is when going into full screen exclusive mode HDR turns off! When going back to windowed HDR is still off only restarting file enables HDR again. Disabling exclusive mode allows windowed and fullscreen HDR playback. |
24th July 2017, 23:55 | #44428 | Link | |
25th July 2017, 12:27 | #44429 | Link | |
Are you cropping black bars for wider than 16/9 content though? That would change things a bit I guess, though I'd still use NGU chroma upscaling. But for the for extra upscaling needed I'd rely on Jinc. Last edited by kalston; 25th July 2017 at 14:48. |
25th July 2017, 14:40 | #44430 | Link | |
Soul Seeker
25th July 2017, 16:59 | #44431 | Link | |
As for the drivers Nvidia HDR mode hasn't worked in the last two driver sets one of which predates the madvr update. Edit- The Microsoft HDR toggle isn't working in RGB mode but does work using Nvidia 422 colour mode which didn't work in previous drivers. I needed to change to default colour settings for it to work. So they have changed something Last edited by Sideeffect; 25th July 2017 at 17:15. |
25th July 2017, 21:36 | #44432 | Link | |
25th July 2017, 22:49 | #44434 | Link | |
This, specifically, has worked for me since 382.19. HDR is kind of all over the place, though, so maybe this driver did fix something on your system. <shrug> |
26th July 2017, 14:33 | #44435 | Link |
What does it means
H264 , 8 bit 4:2:0 -> NV12 , 8 bit 4:2:0 ? It usually was NV12 , 8 bit without conversion or something with h264. I downgraded from 384.72,94 . when watching 1080p MKV Bluray rip movies ? I'm using drivers 382.53 |
27th July 2017, 14:18 | #44438 | Link |
Anyone who uses TV + Potplayer or MPC-HC with madVR as Exclusive Full screen and you use 60 Hz , do you have the problem that it changes the refresh rate to 59.94 while it does it there is long black blink ? it happened on both my Tv's Philips 7007 LED and now with OLED LG55C6 , is there anyway to fix it ? why when going full screen in the program causing it to change refresh rate ? how can I set it to use 60 Hz ?
Thanks |
27th July 2017, 17:44 | #44439 | Link | |
I could solve this using Custom Resolution Utility (CRU) and removing unused resolutions or using an extension block to make it report like it's connected using DVI and thus avoiding this problem, however you must do this every time you update GPU drivers. I ended up connecting my monitors using DVI but that might not be possible for you. |
