Old 9th August 2010, 22:20   #3381  |  Link
detmek
Originally Posted by rack04 View Post
x264_x86_r1688M_Filtering
System:     MINGW
asm:        yes
avs:        yes
lavf:       yes
ffms:       yes
gpac:       yes
pthread:    yes
filters:    resize crop select_every hqdn3d yadif pad
debug:      no
gprof:      no
PIC:        no
shared:     no
visualize:  no
bit depth:  8
Patches:
Hi. I tried using this build but I get this warrning:
ffms [info]: 720x304p 1:1 @ 24/1 fps (vfr)
pad [info]: expanding frame to 720x480, picture starting at (0,88)
x264 [info]: using SAR=1/1
x264 [info]: using cpu capabilities: MMX2 SSE2Slow SlowCTZ
x264 [info]: profile Baseline, level 3.0
x264 [warning]: non-strictly-monotonic pts at frame 1 (0 <= 0)
x264 [warning]: non-strictly-monotonic pts at frame 2 (0 <= 1)
x264 [warning]: non-strictly-monotonic pts at frame 3 (0 <= 2)
x264 [warning]: too many nonmonotonic pts warnings, suppressing further ones
x264 [warning]: 3015 suppressed nonmonotonic pts warnings
x264 [info]: frame I:13    Avg QP:17.54  size: 19819
x264 [info]: frame P:3006  Avg QP:19.32  size:  5262
x264 [info]: mb I  I16..4: 100.0%  0.0%  0.0%
x264 [info]: mb P  I16..4:  8.4%  0.0%  0.0%  P16..4: 28.3%  0.0%  0.0%  0.0%  0.0%    skip:63.3%
x264 [info]: coded y,uvDC,uvAC intra: 23.0% 35.5% 11.9% inter: 15.2% 14.1% 2.4%
x264 [info]: i16 v,h,dc,p: 45% 28% 14% 13%
x264 [info]: i8c dc,h,v,p: 52% 25% 14%  8%
x264 [info]: kb/s:1022.40
encoded 3019 frames, 72.20 fps, 1022.44 kb/s
Command line is
--vf pad:0,88,0,88/ --preset ultrafast -o testpad.mp4 D3.avi
D3.avi is:
General
Complete name                    : C:\ft\D3.avi
Format                           : AVI
Format/Info                      : Audio Video Interleave
File size                        : 151 MiB
Duration                         : 2mn 5s
Overall bit rate                 : 10.1 Mbps
Writing library                  : VirtualDub build 32817/release
Video
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format profile                   : High 4:4:4 Predictive@L3.0
Format settings, CABAC           : Yes
Format settings, ReFrames        : 2 frames
Codec ID                         : H264
Duration                         : 2mn 5s
Bit rate                         : 10.1 Mbps
Width                            : 720 pixels
Height                           : 304 pixels
Display aspect ratio             : 2.35:1
Frame rate                       : 24.000 fps
Resolution                       : 8 bits
Colorimetry                      : 4:2:0
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 1.921
Stream size                      : 151 MiB (100%)
Writing library                  : x264 core 102 r1666bm d058f37
Encoding settings                : cabac=1 / ref=2 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=4 / psy=0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=0 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=0 / weightp=1 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc=cqp / mbtree=0 / qp=0
I found some posts but those are about resize filter problem, but my OS is WinXP Pro SP3 32-bit and I don't use Avisynth, as x264 log shows. Same problem with --preset medium. I did not have problems with resize filter, only with padding.
Tested again. No warrnings if I add --force-cfr to command line. VFR is the problem, I think.
detmek is offline   Reply With Quote
Old 10th August 2010, 15:19   #3382  |  Link
rack04
Originally Posted by moosekaka View Post
hi, is the pad filtering patch available on 64bit x264 build? or is it somehow difficult to implement on 64 bit? thanks
No it is not available.
rack04 is offline   Reply With Quote
Old 16th August 2010, 14:55   #3383  |  Link
JEEB
もこたんインしたお!
JEEB's Avatar
And another update to my build script, L-SMASH straight from the git repo :3
Yes, it looks ugly and very much like a hack, but works and seems to be the official way to install git L-SMASH at the moment. If anyone has a better version, please do share <3.
x264 r1698 64bit unpatched:
download ; hash
  • built on Aug 16 2010, gcc: 4.4.4 (x86_64.generic.Komisar)
  • fprofiled, 8bit
________________________________________________________________________________
x264 r1698 32bit
download
  • built on Aug 16 2010, gcc: 4.4.4 (x86.generic.Komisar)
  • fprofiled, 8bit
x264 r1698 64bit
download
  • fprofiled, 8bit
patched with:
Flabbergasted and not really getting what I did? Read the build script, it should be more understandable ^^;. Seems to be working, though.
[I'm human, no debug]
JEEB is offline   Reply With Quote
Old 16th August 2010, 20:30   #3384  |  Link
julius666
julius666's Avatar
JEEB: Could you upload the files (the compiled binaries at least) to a file-sharing site like mediafire? For some reason I can't reach your webpage from Hungary just through a proxy.
julius666 is offline   Reply With Quote
Old 16th August 2010, 23:30   #3385  |  Link
mariush
I've put them here on the mplayer's mirror i host:
http://mplayer.savedonthe.net/x264/x..._unpatched.exe
http://mplayer.savedonthe.net/x264/x264_1698_32.7z
http://mplayer.savedonthe.net/x264/x264_1698_64.7z
... in the order they appear in the post
mariush is offline   Reply With Quote
Old 17th August 2010, 09:55   #3386  |  Link
julius666
julius666's Avatar
Thank you, that works
Old 17th August 2010, 22:24   #3387  |  Link
rack04
Toolchain:
  • GCC Version 4.5.1 Experimental Release SVN rev. 162774, 2010.07.31
  • Pthreads 2.9.0.0 Static
  • Yasm 1.1.0 r2361
LAVF/FFMS Build:
x264 Build:
  • x264_x86_r1698M
    Platform:   X86
    System:     MINGW
    asm:        yes
    avs:        yes
    lavf:       yes
    ffms:       yes
    audio:      yes (raw)
    gpac:       yes
    pthread:    yes
    debug:      no
    gprof:      no
    PIC:        no
    shared:     no
    visualize:  no
    bit depth:  8
Patches:
Old 19th August 2010, 09:34   #3388  |  Link
qyot27
qyot27's Avatar
x264_r1698-allbits.7z
x264=r1698 [8-, 9-, and 10-bit]
FFMS2=r325
FFmpeg=r24829
Patches:
http://vfrmaniac.fushizen.eu/OtherSt.../mp4muxer.diff
Flags:
-march=pentium3
  • Cross-compiled on Ubuntu 10.04, GCC 4.4.5 prerelease (again, something I doubt but can't verify)
  • AAC encoding requires Quicktime to be installed. The version shipped with iTunes is sufficient, although I assume you need Quicktime 7.3 or higher; if you can use iTunes to access the Store, chances are it's a right version of Quicktime.
Old 20th August 2010, 17:17   #3389  |  Link
RainyDog
Originally Posted by outlaw.78 View Post
x264 0.100.1659 x86 & x64
gcc 4.5.1 20100623 prerelease
ffmpeg svn 23787
swscale svn 31559
ffms2 svn 312
pthreads 2.9.0.0 static
x264 0.100.1659 amdfam10,fprofiled,LTO
Outlaw, will you be doing anymore of your amdfam builds? Cheers.
RainyDog is offline   Reply With Quote
Old 22nd August 2010, 05:56   #3390  |  Link
qyot27
qyot27's Avatar
With all the talk about licensing going on elsewhere in this section, I've made the decision to drop the builds I've made. Instead, I'll post the steps I took for the audio encoding one in the meanwhile (since the LAGS+OC build was a pain in the neck to get working right, and I'd have to constantly recheck the steps involved):
1. Sign up for a free account on Apple Developer Connection (sadly, there's no way around this part) and download the Quicktime 7.3 SDK for Windows.
2. Install the SDK normally.
3. Copy the contents of C:\Program Files\Quicktime SDK to a directory on msys' root called /qtsdk. Alternately, you could just install to said location right away, but you need to remember to rename the directory so there aren't any spaces in the path name.
4. When configuring x264, use --qtsdk=/qtsdk. It should recognize it and under Audio should respond with yes (raw, qtaac, qtaac_he).
4a. Cross-compiling on Linux is possible, but requires the .lib files in /qtsdk/Libraries to be renamed/copied/symlinked to have upper-case (.LIB, not .lib) extensions - case sensitivity causes configure to fail otherwise. Windows doesn't have this problem.
Old 22nd August 2010, 07:02   #3391  |  Link
bob0r
Pain and suffering
bob0r's Avatar
You should not be scared by the money makers.
If it wasn't for "us" xvid and x264 would never grown so popular. We did all the hard work, and now companies make money of it.
If you are afraid of hosting stuff, you can always host it on x264.nl.
bob0r is offline   Reply With Quote
Old 22nd August 2010, 07:28   #3392  |  Link
qyot27
qyot27's Avatar
Well, at least in my own case, those two builds were mainly for esoteric features/purposes, and my ability to churn them out with regularity was already a problem because of how old my comp is. The tide of progress on all the parts inside them would have made it a moot point in relatively short order anyhow. It already somewhat did to the r1688 build with Lagarith and Ordered Chapters. The Quicktime stuff is a regular part of the L-SMASH patch now, it's just a matter of whether one chooses to supplement said patch with AAC encoding or not by downloading the SDK from Apple.
It would be far more convenient for me to document what I did to get there, because this flare-up still points out that source code is apparently different from binaries; I'm comfortable with being told what to do with source code, or to rely on existing pipelines to get a hold of things, I've just re-evaluated whether I myself want to or have the time/ability to be part of said pipelines. Binaries may be more convenient for an average user without knowledge of compiling software, but the methodology to get different results is more valuable to those that feel confident with compiling it themselves - not to mention most of them would get through the process faster than I could simply due to better underlying hardware. Waiting 1h45m-2h or so just for a complete cycle of ffmpeg->ffms2->x264->ffmpeg is getting to be too much for me anyhow. That should seriously take me a half hour (or less!), not 3-4x that. Discounting, of course, any extra time racked up due to stuff causing builds to fail mid-way through and start the process over again trying to troubleshoot it.
Old 29th August 2010, 09:03   #3393  |  Link
jpsdr
@rack04 : Do you intend to make a 32/64 bit with fade_compensation patch of the last version ?
Old 31st August 2010, 20:43   #3394  |  Link
easyfab
Can someone make a build for LAVF/ffmpeg SVN but with all audio codec enable ( aac,lame,vorbis ... ) because I want to try to build "x264 audio" and I don't know how to build ffmpeg correctly under mingw/msys. ( A guide for ffmpeg under mingw/msys can also be good)
easyfab is offline   Reply With Quote
Old 1st September 2010, 06:45   #3395  |  Link
lucassp
I'm also looking for a recent Mac build of x264 with ffms/lavf. Or at least a build tutorial. Thanks
[Intel] Core i5 8500|[ASUS] ROG STRIX Z390-I GAMING|[Noctua] NH-U12S|[GSkill] DDR4 2400 2x16GB|[MSI] RTX2060 Super Gaming X|[Samsung] 970 Pro 512Gb|[Seasonic] Focus SGX 650|[NZXT] H400|[LG] 27GL850
lucassp is offline   Reply With Quote
Old 1st September 2010, 08:25   #3396  |  Link
qyot27
qyot27's Avatar
For OSX,
A) install Xcode - it's on the OSX install disc or through Apple Developer Connection.
B) Install MacPorts (by following Parts 1 & 2 from http://davidbaumgold.com/tutorials/wine-mac/ - although if you want to go on to install wine feel free to).
C) Use MacPorts to install subversion, git-core, yasm, nasm, texi2html, automake, autoconf, libtool, pkg-config (might already be installed through Xcode...I can never seem to remember this), and I think that's it.
svn checkout svn://svn.ffmpeg.org/ffmpeg/trunk ffmpeg
svn checkout http://ffmpegsource.googlecode.com/svn/trunk/ ffms2
git clone git://git.videolan.org/x264.git
cd ffmpeg
./configure --prefix=$HOME/ffms2_build --enable-gpl --enable-version3 --enable-postproc --disable-encoders \
--disable-muxers --disable-debug --disable-network --disable-hwaccels --disable-indevs --disable-outdevs \
--extra-cflags="-march=pentium3"
make
make install
cd ../ffms2
./configure --prefix=$HOME/ffms2_build PKG_CONFIG_PATH=$HOME/ffms2_build/lib/pkgconfig
make
make install
cd ../x264
wget http://vfrmaniac.fushizen.eu/OtherSt.../mp4muxer.diff
patch -p1 < mp4muxer.diff
PKG_CONFIG_PATH=$HOME/ffms2_build/lib/pkgconfig ./configure --extra-cflags="-march=pentium3"
make
make install
make distclean
PKG_CONFIG_PATH=$HOME/ffms2_build/lib/pkgconfig ./configure --prefix=$HOME/x264-9bit \
--extra-cflags="-march=pentium3" --bit-depth=9
make
make install
make distclean
PKG_CONFIG_PATH=$HOME/ffms2_build/lib/pkgconfig ./configure --prefix=$HOME/x264-10bit \
--extra-cflags="-march=pentium3" --bit-depth=10
make
make install
All -march=pentium3 parts should be changed to the processor you actually have; refer to GCC's documentation for that list...-march=native could also be used if you'd rather not take the time to target your cpu explicitly and let GCC autodetect it.
The MSYS/MinGW instructions are pretty much identical to those - the only place they differ are that ffmpeg requires two additional options: --enable-memalign-hack and -U__STRICT_ANSI__ needs to be added to the cflags, like --extra-cflags"-U__STRICT_ANSI__ -march=pentium3".
EDIT: I forgot...I have read reports that ffmpeg won't build under Snow Leopard unless --disable-asm and --arch=x86_64 are also given. I'm not entirely sure because I can't remember if I've ever built without those options, so be aware of that as well.
Old 4th September 2010, 07:56   #3397  |  Link
jpsdr
@jeeb : I've tested your x64 patched 1703 version, with the following command line :
@echo off
SET E_SRC=%6%1.avs
SET E_DST=%3%1.264
SET CHAPTERS=%6%5
SET STAT_FILE=%6%1.stats
SET TUNING=%4
SET LOG_FILE_1=%6%1_log_1.txt
SET LOG_FILE_2=%6%1_log_2.txt
REM Set of max bitrate (ici le bitrate max)
set MAX_BR=40000
REM Set of Buffer (ici le buffer)
set BUF_BR=30000
REM 1ère passe
x264_x64.exe --profile "high" --preset "placebo" --tune %TUNING% --pass 1 --bitrate %2 --stats %STAT_FILE% --level "4.1" --qpmin 0 --vbv-maxrate %MAX_BR% --vbv-bufsize %BUF_BR% --keyint 24 --min-keyint 2 --mvrange 511 --ref 4 --bframe 3 --slices 4 --b-pyramid "strict" --open-gop "bluray" --fade-compensate 0.7 --subme 9 --trellis 1 --me "umh" --aq-mode 2 --aud --nal-hrd "vbr" --colorprim "bt709" --transfer "bt709" --colormatrix "bt709" --videoformat "ntsc" --sar 1:1 --qpfile %CHAPTERS% --threads 0 --thread-input --output NUL %E_SRC% 2> %LOG_FILE_1%
REM 2ème passe
x264_x64.exe --profile "high" --preset "placebo" --tune %TUNING% --pass 2 --bitrate %2 --stats %STAT_FILE% --level "4.1" --qpmin 0 --vbv-maxrate %MAX_BR% --vbv-bufsize %BUF_BR% --keyint 24 --min-keyint 2 --mvrange 511 --ref 4 --bframe 3 --slices 4 --b-pyramid "strict" --open-gop "bluray" --fade-compensate 0.7 --aq-mode 2 --aud --nal-hrd "vbr" --colorprim "bt709" --transfer "bt709" --colormatrix "bt709" --videoformat "ntsc" --sar 1:1 --qpfile %CHAPTERS% --threads 0 --thread-input --output %E_DST% %E_SRC% 2> %LOG_FILE_2%
My avisynth script is only AVISource("File.avi"), where avi is Lagarith YV12 without audio.
2 problems :
- It displays avs errors about audio... First time i'm having this kind of message, specialy when output is raw h264...
- It never finish the 1st pass... Process is some kind of locked, i've one thread (ie one CPU) at 100%, log of 1st pass seems completed, but still used/locked by the process, and there is no log of 2nd pass, which mean 2nd pass is not starting.
Reproductible at 100%, even with a small file of few frames.
Old 5th September 2010, 01:52   #3398  |  Link
livetolove92
This is my settings
x264.exe --profile high --level 4.1 --pass 1 --preset veryslow --bitrate 1900 --stats ".stats" --min-keyint 24 --thread-input --threads 6 --deblock -3:-3 --deadzone-inter 21 --deadzone-intra 11 --qcomp 0.6 --bframes 4 --b-adapt 2 --direct auto --b-bias 0 --scenecut 40 --keyint 250 --ref 6 --rc-lookahead 00 --aq-mode 1 --aq-strength 0.7 --merange 24 --me umh --subme 7 --no-dct-decimate --mixed-refs --partitions all --trellis 2 --psy-rd 0.8:0.1 --ipratio 1.4 --pbratio 1.3 --no-fast-pskip --output NUL "F:\Worker\x.avs"
x264.exe --profile high --level 4.1 --pass 2 --preset veryslow --bitrate 1900 --stats ".stats" --min-keyint 24 --thread-input --threads 6 --deblock -3:-3 --deadzone-inter 21 --deadzone-intra 11 --qcomp 0.6 --bframes 4 --direct auto --b-bias 0 --scenecut 40 --keyint 250 --ref 6 --rc-lookahead 00 --aq-mode 1 --aq-strength 0.7 --merange 24 --me umh --subme 7 --no-dct-decimate --mixed-refs --partitions all --trellis 2 --psy-rd 0.8:0.1 --ipratio 1.4 --pbratio 1.3 --no-fast-pskip --output "x.mkv" "F:\Worker\x.avs" 2>log.txt
And this my avs
LoadCPlugin("F:\Encode software\megui-core_0_3_4_15_x64\tools\ffms\ffms2.dll")
ffmpegsource2("H:\US\X.mkv")
Spline36Resize(960,406) # Spline36 (Neutral)
This my log
avs [info]: 960x406p 0:0 @ 24000/1001 fps (cfr)
x264 [warning]: lookaheadless mb-tree requires intra refresh or infinite keyint
x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2
x264 [error]: ratecontrol_init: can't open stats file
x264 [error]: x264_encoder_open failed
I use the latest x264, ffms2, megui, avisynth for x64.
I can't create the .stats file. x264 crash immediately when i run the bat.
livetolove92 is offline   Reply With Quote
Old 5th September 2010, 10:18   #3399  |  Link
jpsdr
@jeeb
I've tested your x64 1713 patched build, still the same issue i've described in post #3397
Old 5th September 2010, 13:31   #3400  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
Originally Posted by jpsdr View Post
@jeeb
have you even tried the unpatched x64 build to see if it also exhibits the issues?
iirc JEEB is using the still-being-developed audio support patch which would explain the audio warning...
custom x264 builds & patches | F@H | My Specs
kemuri-_9 is offline   Reply With Quote
h.264, x264, x264 builds, x264 patches, x264 unofficial builds
