6th December 2008, 13:52 | #3341 | Link | |
As for audio ripping, I suggest you just use eac3to yourself to rip the audio first, and mux it back in later with tsMuxeR. Also, what does eac3to itself say about a delay in ms?
Gorgeous, delicious, deculture! |
6th December 2008, 18:48 | #3342 | Link |
asarian, Thanks. I will try that. Maybe I can use my encoded .mk4 file and demux it and convert the DTS audio to AC3 and remux it. Is that what you mean? I did try taking my mk4 file and demuxing the audio and video. Then used DaudioK to convert the DTS to ac3 5.1 and then nused tsMuxeR to mux them back together again. But when I tried to play the muxed file, it would not play. I will try with eac3to this time.
I am playing the video back on a dual core AMD 4600+, with SLI 8800 GT video cards and a sound blaster X-FI fatal1ty. So the speed of the playback PC is not an issue. |
7th December 2008, 00:49 | #3344 | Link |
OK, I tried converting the audio from DTS to AC3 and then used that audio file and the demuxed video file with ripbot. Same thing happens. The audio is about 3 seconds ahead of the video when I play it back. depressing....
7th December 2008, 02:22 | #3345 | Link | |
First of all, I gotta wonder, if you play a m2ts file from the Blu-Ray STREAM directory directly, are matters still in sync? If so, you could use tsMuxeR to cut a small piece out of it (say the first minute or so), and share it on mediafire or something, so we can have a look at it. A 4-5 seconds delay really is an eternity, audio-wise. Usually we're talking milliseconds, of course. On a very old tsMuxeR version sometimes I would get a ridiculous delay value, like -16000000ms or some such, but that sorta thing is ancient history. So, if you use a recent tsMuxeR (like 1.8.8), that sort of thing should no longer occur.
7th December 2008, 02:33 | #3346 | Link | |
No, seriously, what you suggest doesn't make a lot of sense. RipBot reencodes; that's what x264 does. If you just want to 'copy' a video stream, then you're basically merely remuxing, and have no need for RipBot.
7th December 2008, 02:36 | #3347 | Link |
Backing up Blu-Ray movies w/RipBot almost 4mos now
Done about 50 so far== 34 BD9 / 16 BD-R my Routine == 1920x1080p 24fps/NO Subtitles/5.1 DTS/DD (COPY ORIGINAL XX) or Aften AC3 640kbs/2-PASS Started out doing the math... but RipBot interActive DropBoxes are so GOOD i now use them exclusively w/2-PASS method: Check LockSizeTotalBox--HighLite and Enter 8150 (BD9= 8.5g DL) or 24000 (BD-R= 25g) UnCheck LockSizeTotalBox--HighLite KBPS Adj#s until TotalBox =~ 8150-8170 or 24050-24100 OverHead is averaging 3-3.5% = BD-R and 4% = BD9 (DVD+R DL) |
7th December 2008, 03:39 | #3348 | Link |
I used ripbot264 to rip a few blu-rays and it worked really well.
Only trouble is it took ages for 2-pass encoding. something like 20 hours, is that normal? first pass was about 8.7fps and second pass was a slow 2.4fps!! I used the stock settings 1080 no resize, ac3 5.1 audio.On the ps3profile level 4.0 setting. 8mb/s video rate setting The only extra setting I used was auto crop. Is there anyway I can speed up encoding time while keeping video quality in check? I have a core 2 duo e6400@2.2 (I normally run it at 3.0 but the encoding was making the cpu too hot running at 100% all the time so had to use stock speed) 3gb ddr2 800 ram vista |
7th December 2008, 04:19 | #3349 | Link | |
For example, if I am encoding a 2 hour BD to a DVD-9 in 1920 x ____, I will get, on average, about 24fps for the 1st Pass and about 8 fps on the 2nd pass. This is with a Q6700 (4 CPU x 2.66 GHz) on a 780i Mobo and 4 GB of 1066 RAM and a single WD 1TB Caviar Black HDD...running Vista. I usually have it running overnight and while I am at work (encoding 2 BDs), and both are done when I get home; so, let's say that ends up being about a 18-20 hour timeframe. It takes a while for sure! |
7th December 2008, 04:43 | #3350 | Link | |
Gorgeous, delicious, deculture! Last edited by asarian; 7th December 2008 at 04:58. Reason: Typo |
7th December 2008, 06:33 | #3352 | Link | |
7th December 2008, 08:49 | #3354 | Link |
Deinterlacing
Hi. Is there a way inside the gui to check what dgindex found as field order before one does the deinterlacing choice ?
I manually checked a file in dgindex and chose upper field first as the deinterlace method.. but the quality really sucked on the progressive output.. Lots of jaggies.. Anyone got an idea how to improve this ? best regards TE |
7th December 2008, 09:22 | #3355 | Link | |
CUT times in HALF BluRay encodes BD9 = 8-10 hrs (2-Pass) BD-R = 15-20hrs |
7th December 2008, 12:25 | #3356 | Link |
I need help with profiles. Is there anyone with a good X264 knowledge that can help out I would be very greatfull.
I own both the Tvix 6500 (2 of them) and a Popcorn hour A100 that I use to play back my BD rips of my BD discs. With Ripbot 1.10.8 I was able to create a profile that worked good with both the tvix and the popcorn. Code:
[x264settings] DeblockingStrength=0 DeblockingSensitivity=0 AdaptQuant=1 MotionEstimationAlgorithm=3 - UMH SubpixelRefinement=6 - RD on I/P frames I4X4=1 P4X4=0 P8X8=1 B8X8=1 AdaptDCT=1 I8X8=1 NumberOfRFrames=3 mixedRFrames=1 TrellisQuant=1 CABAC=1 NumberOfBFrames=3 AdaptBFrames=1 BPyramid=0 WeightBPrediction=1 HRD=1 BufferSize=24000 MaxBitrate=24000 Level=level 4.0 If I use MeGUI with the x264_dp_ PD-PS3-Xbox360 profile I get a good encode that works with the tvix but damn if I am capable of translating that profile to Ripbots. I have now done 8 encodes with different settings and they all reboot my tvix boxes. So any other tvix owner out here that has solved this problem or a x264 guru that can assist? My latest try in Ripbot looks like this : Code:
--level 4.0 --vbv-bufsize 20000 --vbv-maxrate 20000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 2 --weightb --direct auto --subme 6 --trellis 1 --partitions p8x8,b8x8,i4x4,i8x8 --8x8dct --me hex --threads auto --thread-input --progress --no-psnr --no-ssim |
7th December 2008, 16:48 | #3357 | Link | |
--level 4.0 --vbv-bufsize 20000 --vbv-maxrate 20000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 2 --weightb --direct auto --subme 6 --trellis 1 --partitions p8x8,b8x8,i4x4,i8x8 --8x8dct --me hex --threads auto --thread-input --progress --no-psnr --no-ssim --aud --nal-hrd
7th December 2008, 16:57 | #3358 | Link |
"--aud --nal-hrd" are in the current profile that Paddy97 said didn't work, so I think the culprit may be "--partitions all" that is in the current ripbot profile that may impair compatibility with certain devices (p4x4), as that is missing from the MeGUI profiles for blu-ray and AVCHD
7th December 2008, 17:23 | #3359 | Link | |
But didn't he also put in "--partitions p8x8,b8x8,i4x4,i8x8", specifically excluding p4x4? Also, I noticed that when I open RipBot's x264 settings menu, and immediately close it (without changing anything), that "job1_EncodeVideoPass1.cmd" retains my "me tesa" setting, which RipBot otherwise overrides to "me esa". So, doing the same open/close trick might cause Paddy97 to keep his "--partitions p8x8,b8x8,i4x4,i8x8" too (examining job1_EncodeVideoPass1.cmd afterwards would be a good idea).
7th December 2008, 17:37 | #3360 | Link |
Yes the settings you posted above should work asarian, you used the modifed profile that Paddy97 gave (without p4x4) and added --aud --nal-hrd (and his modifed profile likely wouldn't work without those additions on some devices)
I was just commenting on the differences between the standard profiles and why they might / or might not work |
