13th January 2012, 18:37 | #14561 | Link |
There is a massive leak of system handles when using ffdshow in combination with Haali renderer.
tested builds: r4174 = working r4183 = freeze r4207 = leak
MPC-HC 2.2.1 |
14th January 2012, 02:30 | #14562 | Link | |
14th January 2012, 05:59 | #14563 | Link | |
// EDIT fixed at rev 4247. Please confirm. Last edited by haruhiko_yamagata; 14th January 2012 at 08:26. |
14th January 2012, 19:05 | #14564 | Link |
Fix confirmed.
MPC-HC 2.2.1 |
14th January 2012, 21:15 | #14566 | Link |
No.
But you can use this link to quickly see the latest revision: http://ffdshow-tryout.svn.sourceforg...?view=revision There is a Next/Previous button to skip through revisions, so you easily check the latest few.
MPC-HC 2.2.1 |
14th January 2012, 23:46 | #14567 | Link | |
If useful I could post a wireshark of the video stream for when the video is degrading. Thanks again, David |
15th January 2012, 00:16 | #14568 | Link | ||
Because, with the latest FFDShow and LAV Filters versions, the aac audio stream of this particular video is still incorrectly being decoded here, I was wondering if it could be a WinXP-only issue. Could everyone on WinXP 32bit see if the audio-track of this video is properly decoded with libavcodec please?
My hobby website |
15th January 2012, 00:22 | #14569 | Link |
I can confirm that it works on Win7 at least. However, i don't think that the decoder actually behaves differently on XP vs 7, that would be quite odd. Windows XP however has some issues with float audio, maybe thats the issue, because avcodec decodes to that? Could try turning off float in ffdshow/LAV, and see if that helps?
15th January 2012, 00:40 | #14570 | Link | |
>>^^__^^<<
15th January 2012, 00:52 | #14571 | Link | |
But perhaps I also need a compatible upper stream filter to reproduce. Thanks. |
15th January 2012, 01:27 | #14572 | Link |
I've never touched float. Output is always integer here, in case of FFDShow as well as LAV Audio.
I don't use Haali. At least LAV Filters or MPC-HC's internal MP4 Splitter doesn't make a difference.
My hobby website |
15th January 2012, 05:11 | #14573 | Link | |
15th January 2012, 07:37 | #14574 | Link | |
Off course the credit goes to nevcairiel. |
15th January 2012, 14:54 | #14575 | Link | |
16th January 2012, 03:59 | #14577 | Link |
I experience corruption with Quick Sync enabled along with ffdshow raw with this sample. I experience no problems with any other decoder or with raw disabled.
20MB sample below. http://www.mediafire.com/?0s68s1yjojkj9wc |
16th January 2012, 21:43 | #14579 | Link |
That's really weird. I'm also running WinXP SP3, but the decoded audio is completely distorted no matter the source filter or output settings.
AAC(libavcodec)_decode-error.tak to be precise (the first 25 seconds of Standard720x576_1MBit.mp4 its distorted audio stream recorded as stereomix with Audacity the way I hear it). I can't believe it's a soundcarddriver- or dependency-issue, or is it? I've also tested Standard720x576_1MBit.mp4 on a family member's Win7 laptop. All fine with libavcodec. [edit]Having music in the background (foobar or even MPC-HC) while playing Standard720x576_1MBit.mp4 also badly affects the music.[/edit]
My hobby website Last edited by Reino; 16th January 2012 at 22:15. |
