15th February 2016, 09:39 | #3261 | Link |
What exactly is the changed condition to enable 2-pass CRF? If I read the patches correctly: Use a VBV maximum bitrate in the 1st pass, so you can either let x265 calculate the optimal RF with VBV constraints to achieve a target size (in VBR mode), or use a specified RF with VBV constraints regardless of a target size (in VBV-CRF mode)?
__ New build with changed 2-pass VBV-CRF conditions: x265 1.9+15-425b583f25db (GCC 5.3.0) Last edited by LigH; 15th February 2016 at 10:26. |
15th February 2016, 16:42 | #3262 | Link | |
I hope that you find better fix. |
15th February 2016, 21:57 | #3263 | Link |
I apologize for not following up on this much earlier, but this is a basic rundown of the issues when cross-compiling x265-yuuki currently:
input-filters.diff doesn't cleanly apply because the amount of fuzz got too large. CMake has to be run twice to even detect that -DENABLE_LAVF has been turned on and get the locations for the libs. This is due to the position of the ENABLE_LAVF block in CMakeLists.txt coming before the ENABLE_CLI block, but requiring the CLI is enabled. If the ENABLE_LAVF block is moved to a position after the CLI is turned on, or if the CLI requirement is removed from the ENABLE_LAVF block, then it can detect the libs on the first try (although it seemed to cause other issues during building or linking). There are problems linking against FFmpeg's private libs, especially when all of them are built static. zlib, bzip2, lzma, and iconv are all autodetected and used if present when FFmpeg is configured, and these cause errors on link with the lavf module because the libs haven't been properly added to the linker list by cmake. To say nothing of when more expansive configurations with more external libs are present, or for other options that are enabled by default (like what's brought in if the user doesn't explicitly use --disable-network). If the user explicitly disables these four libraries and the network support when building FFmpeg, then x265 can link to them just fine, but otherwise it requires the user to manually append the list of linker libs to the failed link command, and this then breaks the ability of ninja to do a proper install, even though the .exe is okay. FFmpeg API usage needs to be updated. PIX_FMT_* needs to be changed to AV_PIX_FMT_* to allow compilation to proceed successfully, and even though it's just a warning, uses of deprecated functions should be updated to non-deprecated ones (which x264 recently fixed for the lavf module there): Code:
[78/88] Building CXX object CMakeFiles/cli.dir/input/lavf.cpp.obj /home/qyot27/x265-build/x265-yuuki/source/input/lavf.cpp: In member function 'bool x265::LavfInput::readPicture(x265_picture&, x265::InputFileInfo*)': /home/qyot27/x265-build/x265-yuuki/source/input/lavf.cpp:108:13: warning: 'void av_free_packet(AVPacket*)' is deprecated [-Wdeprecated-declarations] av_free_packet(&pkt); ^ In file included from /usr/i686-w64-mingw32/include/libavformat/avformat.h:318:0, from /home/qyot27/x265-build/x265-yuuki/source/input/lavf.h:12, from /home/qyot27/x265-build/x265-yuuki/source/input/lavf.cpp:29: /usr/i686-w64-mingw32/include/libavcodec/avcodec.h:4040:6: note: declared here void av_free_packet(AVPacket *pkt); ^ /home/qyot27/x265-build/x265-yuuki/source/input/lavf.cpp:108:13: warning: 'void av_free_packet(AVPacket*)' is deprecated [-Wdeprecated-declarations] av_free_packet(&pkt); ^ In file included from /usr/i686-w64-mingw32/include/libavformat/avformat.h:318:0, from /home/qyot27/x265-build/x265-yuuki/source/input/lavf.h:12, from /home/qyot27/x265-build/x265-yuuki/source/input/lavf.cpp:29: /usr/i686-w64-mingw32/include/libavcodec/avcodec.h:4040:6: note: declared here void av_free_packet(AVPacket *pkt); ^ /home/qyot27/x265-build/x265-yuuki/source/input/lavf.cpp:108:32: warning: 'void av_free_packet(AVPacket*)' is deprecated [-Wdeprecated-declarations] av_free_packet(&pkt); ^ In file included from /usr/i686-w64-mingw32/include/libavformat/avformat.h:318:0, from /home/qyot27/x265-build/x265-yuuki/source/input/lavf.h:12, from /home/qyot27/x265-build/x265-yuuki/source/input/lavf.cpp:29: /usr/i686-w64-mingw32/include/libavcodec/avcodec.h:4040:6: note: declared here void av_free_packet(AVPacket *pkt); ^ [88/88] Linking CXX executable x265.exe [8bit:$] *.mkv as input is too limiting (other containers and secondary extensions like *.m2ts, *.ts, *.mpg, *.ogv, *.webm, *.vob and several others are also found commonly enough to be nice to open). The easiest solution would be to simply make the block into an else and the return statement, so anything that's not y4m or a pipe gets handled by lavf (and presumably lavf would error out in the case that it can't open the file, although this probably needs more error-proofing in input/lavf.cpp unless it already does emit a clean error and not a crash). The zimg filter also fails to build because of an error in zimgfilter.h: Code:
[86/88] Building CXX object CMakeFiles/cli.dir/filters/filters.cpp.obj FAILED: /usr/bin/i686-w64-mingw32-g++ -DENABLE_LAVF -DENABLE_LSMASH -DENABLE_MKV -DENABLE_ZIMG -DEXPORT_C_API=1 -DHAVE_INT_TYPES_H=1 -DHIGH_BIT_DEPTH=0 -DX265_ARCH_X86=1 -DX265_DEPTH=8 -DX265_NS=x265 -D_WIN32_WINNT=_WIN32_WINNT_WINXP -D_WIN32_WINNT_WIN7=0x0601 -D__STDC_LIMIT_MACROS=1 -mfpmath=sse -march=pentium3 -msse -mtune=pentium3 -O3 -DNDEBUG -I/home/qyot27/x265-build/x265-yuuki/source/. -I/home/qyot27/x265-build/x265-yuuki/source/common -I/home/qyot27/x265-build/x265-yuuki/source/encoder -I. -Wall -Wextra -Wshadow -std=gnu++98 -march=i686 -Wno-array-bounds -ffast-math -mstackrealign -fno-exceptions -MMD -MT CMakeFiles/cli.dir/filters/filters.cpp.obj -MF CMakeFiles/cli.dir/filters/filters.cpp.obj.d -o CMakeFiles/cli.dir/filters/filters.cpp.obj -c /home/qyot27/x265-build/x265-yuuki/source/filters/filters.cpp In file included from /home/qyot27/x265-build/x265-yuuki/source/filters/filters.cpp:27:0: /home/qyot27/x265-build/x265-yuuki/source/filters/zimgfilter.h:56:5: error: 'zimg_resize_context' does not name a type zimg_resize_context* resizeCtx[3]; ^ /home/qyot27/x265-build/x265-yuuki/source/filters/zimgfilter.h:57:5: error: 'zimg_depth_context' does not name a type zimg_depth_context* depthCtx; ^ [86/88] Building CXX object CMakeFiles/cli.dir/x265.cpp.obj ninja: build stopped: subcommand failed. noise thrown and the above errors still apply. For reference, this is the set of instructions I'm following: Code:
FFmpeg: git clone git://source.ffmpeg.org/ffmpeg.git && \ cd ffmpeg && \ ./configure --prefix=/usr/i686-w64-mingw32 --cross-prefix=i686-w64-mingw32- \ --enable-gpl --enable-version3 --disable-w32threads --enable-avresample \ --disable-encoders --disable-muxers --disable-doc --disable-debug \ --disable-devices --disable-avdevice --enable-avisynth --cpu=pentium3 \ --extra-cflags="-mfpmath=sse -march=pentium3 -msse -mtune=pentium3" \ --target-os=mingw32 --arch=x86 && \ make -j$(nproc) && \ sudo checkinstall --pkgname=ffmpeg-minimal-mingw --pkgversion="$(git \ rev-list --count HEAD)-g$(git rev-parse --short HEAD)-$(date --rfc-3339=date | \ sed 's/-//g')-git" --backup=no --deldoc=yes --delspec=yes --deldesc=yes \ --strip=yes --fstrans=no --default Add --disable-network --disable-zlib --disable-bz2 --disable-lzma to keep FFmpeg from calling in private libs, otherwise, see pkg-config note at the end. mkdir -p ~/x265-build/12bit ~/x265-build/10bit ~/x265-build/8bit && \ cd ~/x265-build && \ hg qclone https://bitbucket.org/msg7086/x265-yuuki && \ cd x265-yuuki && \ hg qpush -a && \ Condense the ifdef ENABLE_LAVF block in source/input/input.cpp to: #ifdef ENABLE_LAVF else return new LavfInput(info); #endif Correct uses of PIX_FMT_* to AV_PIX_FMT_* sed -i 's/case PIX_FMT/case AV_PIX_FMT/g' source/input/lavf.cpp cd ../12bit && \ cmake ../x265-yuuki/source -G "Ninja" -DCMAKE_INSTALL_PREFIX="$HOME/x265_build/x265-12bit" \ -DCMAKE_TOOLCHAIN_FILE="/usr/i686-w64-mingw32/toolchain-i686-w64-mingw32.cmake" \ -DCMAKE_CXX_FLAGS="-mfpmath=sse -march=pentium3 -msse -mtune=pentium3" \ -DHIGH_BIT_DEPTH:bool=on -DMAIN12:bool=on -DENABLE_SHARED:bool=off \ -DENABLE_ASSEMBLY:bool=off -DEXPORT_C_API:bool=off -DENABLE_CLI:bool=off \ [-DWINXP_SUPPORT:bool=on] && \ ninja && \ sudo checkinstall --pkgname=x265-main12-mingw --pkgversion="$(grep X265_VERSION \ build.ninja | sed 's/X265_VERSION=/\t/' | cut -f2 | sed 's/ /\t/g' | cut -f1)-$(date \ --rfc-3339=date | sed 's/-//g')-hg" --backup=no --deldoc=yes --delspec=yes \ --deldesc=yes --strip=yes --fstrans=no --default cp libx265.a /usr/i686-w64-mingw32/lib/libx265_main12.a && \ mv *.deb ~/mingw_debs # Build 10-bit: cd ../10bit && \ cmake ../x265-yuuki/source -G "Ninja" -DCMAKE_INSTALL_PREFIX="$HOME/x265_build/x265-10bit" \ -DCMAKE_TOOLCHAIN_FILE="/usr/i686-w64-mingw32/toolchain-i686-w64-mingw32.cmake" \ -DCMAKE_CXX_FLAGS="-mfpmath=sse -march=pentium3 -msse -mtune=pentium3" \ -DHIGH_BIT_DEPTH:bool=on -DENABLE_SHARED:bool=off -DENABLE_ASSEMBLY:bool=off \ -DEXPORT_C_API:bool=off -DENABLE_CLI:bool=off [-DWINXP_SUPPORT:bool=on] && \ ninja && \ sudo checkinstall --pkgname=x265-main10-mingw --pkgversion="$(grep X265_VERSION \ build.ninja | sed 's/X265_VERSION=/\t/' | cut -f2 | sed 's/ /\t/g' | cut -f1)-$(date \ --rfc-3339=date | sed 's/-//g')-hg" --backup=no --deldoc=yes --delspec=yes \ --deldesc=yes --strip=yes --fstrans=no --default cp libx265.a /usr/i686-w64-mingw32/lib/libx265_main10.a && \ mv *.deb ~/mingw_debs # Only the .a files from 12-bit and 10-bit are installed to the system, # to reduce the chances of conflicts. # Build 8-bit: cd ../8bit && \ cmake ../x265-yuuki/source -G "Ninja" -DCMAKE_INSTALL_PREFIX="/usr/i686-w64-mingw32" \ -DCMAKE_PREFIX_PATH="/usr/i686-w64-mingw32" \ -DCMAKE_TOOLCHAIN_FILE="/usr/i686-w64-mingw32/toolchain-i686-w64-mingw32.cmake" \ -DCMAKE_CXX_FLAGS="-mfpmath=sse -march=pentium3 -msse -mtune=pentium3" \ -DENABLE_SHARED:bool=off -DEXTRA_LINK_FLAGS=-L. -DLINKED_10BIT:bool=on -DLINKED_12BIT:bool=on \ -DEXTRA_LIB="/usr/i686-w64-mingw32/lib/libx265_main10.a;/usr/i686-w64-mingw32/lib/libx265_main12.a" \ -DENABLE_LSMASH:bool=on -DENABLE_MKV:bool=on -DENABLE_LAVF:bool=on [-DWINXP_SUPPORT:bool=on] && \ cmake ../x265-yuuki/source -G "Ninja" -DCMAKE_INSTALL_PREFIX="/usr/i686-w64-mingw32" \ -DCMAKE_PREFIX_PATH="/usr/i686-w64-mingw32" \ -DCMAKE_TOOLCHAIN_FILE="/usr/i686-w64-mingw32/toolchain-i686-w64-mingw32.cmake" \ -DCMAKE_CXX_FLAGS="-mfpmath=sse -march=pentium3 -msse -mtune=pentium3" \ -DENABLE_SHARED:bool=off -DEXTRA_LINK_FLAGS=-L. -DLINKED_10BIT:bool=on -DLINKED_12BIT:bool=on \ -DEXTRA_LIB="/usr/i686-w64-mingw32/lib/libx265_main10.a;/usr/i686-w64-mingw32/lib/libx265_main12.a" \ -DENABLE_LSMASH:bool=on -DENABLE_MKV:bool=on -DENABLE_LAVF:bool=on [-DWINXP_SUPPORT:bool=on] && \ ninja && \ sed -i 's/lx265/lx265 -lx265_main10 -lx265_main12/' x265.pc && \ sudo checkinstall --pkgname=x265-mingw --pkgversion="$(grep X265_VERSION \ build.ninja | sed 's/X265_VERSION=/\t/' | cut -f2 | sed 's/ /\t/g' | cut -f1)-$(date \ --rfc-3339=date | sed 's/-//g')-hg" --backup=no --deldoc=yes --delspec=yes \ --deldesc=yes --strip=yes --fstrans=no --default ninja install && \ mv *.deb ~/mingw_debs CMake step needs to be run twice so FFmpeg is detected, but it only gets detected if it's installed to the system mingw-w64 area. Then, if the zlib/bz2/lzma/iconv libs and network support are still enabled, it fails to link. This can be fixed by appending the output of: PKG_CONFIG_PATH=/usr/i686-w64-mingw32/lib/pkgconfig pkg-config --cflags --libs --static libavcodec libavformat libswscale to the failed link command*. After this, the install step doesn't work, but x265.exe does. *which, if following the FFmpeg instructs at the beginning, should be something like: -I/usr/i686-w64-mingw32/include -lavcodec -lws2_32 -liconv -lm -llzma -lbz2 -lz -lpsapi -ladvapi32 -lshell32 -lswresample -lavutil -lavformat -pthread -lswscale -L/usr/i686-w64-mingw32/lib sudo apt-get purge ffmpeg-minimal-mingw (this needs to be purged to prevent it interfering with future ffmpeg or mpv builds) Last edited by qyot27; 16th February 2016 at 16:51. |
16th February 2016, 14:56 | #3264 | Link | |
結城有紀
Please note that I have moved my repo to Github due to some personal reason. And if you can provide some fixes, feel free to send a PR for me. The zimg referenced is a pretty old version, mainly due to when I built this patch, it was still in 1.x . If you somehow port it to 2.x, please send a PR. I don't have much time to look into it for the moment. My builds on Linux (and was successful) are compiled against: zimg 1.1.1 ffmpeg 2.8.5-1+b1 (debian 9 sys pkg) l-smash rev1384
Projects x265 - Yuuki-Asuna-mod Download / GitHub TS - ADTS AAC Splitter | LATM AAC Splitter | BS4K-ASS Neo AviSynth+ filters - F3KDB | FFT3D | DFTTest | MiniDeen | Temporal Median Last edited by MeteorRain; 16th February 2016 at 15:01. |
18th February 2016, 06:34 | #3265 | Link | ||||||
結城有紀
18th February 2016, 17:30 | #3266 | Link | |||
I'll test to see if the fix I'd implemented is irrelevant now. Quote:
18th February 2016, 19:24 | #3267 | Link | ||
I've opened a pull request with two patches to address these points:
23rd February 2016, 00:10 | #3269 | Link |
2pass problem
Trying to encode a standard test sequence (BasketballDrill) using 2-pass and the latest 1.9 build ( as well as earlier builds), the 2nd pass creates a bitrate just a fraction of the requested..
My parameters are the same as I am using for x264: Code:
x265 BasketballDrill_832x480_50.yuv --input-res 832x480 --frames 100 --preset slow --fps 50 -o bits --keyint 100 --bitrate 1000 --pass 1 x265 BasketballDrill_832x480_50.yuv --input-res 832x480 --frames 100 --preset slow --fps 50 -o bits --keyint 100 --bitrate 1000 --pass 2 1:encoded 100 frames in 2.94s (33.99 fps), 891.82 kb/s, Avg QP:36.8 2:encoded 100 frames in 3.46s (28.86 fps), 109.70 kb/s, Avg QP:51.00 There must be something basic I am missing..? |
23rd February 2016, 04:13 | #3270 | Link | |
I would expect the 2nd pass rate control to be a whole lot better than the 1st for such a short clip. If there's even a second of black leader, that'd throw everything off. |
23rd February 2016, 04:51 | #3271 | Link |
It's a commonly used test sequence for standards development, including HEVC, so there's no black leader..
x264 encodes the same 100 frames with the exact same parameters like this: 1:encoded 100 frames, 237.53 fps, 885.64 kb/s 2:encoded 100 frames, 73.05 fps, 1045.64 kb/s Something is not working right. x265 seems to clamp to QP to max 51. I may check if libx265 in ffmpeg works any better. |
23rd February 2016, 08:47 | #3272 | Link |
It would probably be useful to see the complete console output and maybe even a CSV log (level 1 or 2) of this second pass. There must be a reason why the target bitrate is apparently not relevant for x265 in the 2nd pass.
_ BTW: For a more efficient command line, you may like to convert raw YUV to Y4M; this may be possible with y4mtools, MJPGTools (Linux), AviSynth with RawSource26 and avs2pipemod, or ffmpeg (-f yuv4mpegpipe). Last edited by LigH; 23rd February 2016 at 09:06. |
24th February 2016, 01:48 | #3273 | Link |
I re-created the same results with a compressed version (x264 crf 10) available here. if anyone else wants to try.
I converted this to Y4M using ffmpeg. Then ran the same two commands (adjusted to remove size and fps). The output in the 2nd pass is at the bottom. It's likely that "Error: 2pass curve failed to converge" may be causing the problem, but I don't know how to set parameters to avoid it. If I try higher bitrates, e.g 2000kbps, the error above is gone, but it still misses the mark completely (1795 kbps 1st pass / 789 kbps 2nd pass). Similarly, 2nd pass for for 4000 and 8000 kbps is much much worse than 1st pass, with a lower bitrate that requested. P.S. I am using raw YUV due to some tools in my toolchain do not yet support Y4M. ==== y4m [info]: 832x480 fps 50/1 i420p8 sar 1:1 frames 0 - 99 of 100 raw [info]: output file: bit x265 [info]: HEVC encoder version 1.9+32-c2228fb8151d x265 [info]: build info [Windows][GCC 5.3.0][64 bit] 8bit x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX x265 [info]: Main profile, Level-3.1 (Main tier) x265 [info]: Thread pool created using 4 threads x265 [info]: frame threads / pool features : 2 / wpp(8 rows) x265 [warning]: Source height < 720p; disabling lookahead-slices x265 [warning]: Error: 2pass curve failed to converge x265 [warning]: target: 1000.00 kbit/s, expected: 1140.97 kbit/s, avg QP: 68.7127 x265 [warning]: try increasing target bitrate x265 [info]: Coding QT: max CU size, min CU size : 64 / 8 x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra x265 [info]: ME / range / subpel / merge : star / 57 / 3 / 3 x265 [info]: Keyframe min / max / scenecut : 10 / 100 / 40 x265 [info]: Lookahead / bframes / badapt : 25 / 4 / 2 x265 [info]: b-pyramid / weightp / weightb : 1 / 1 / 0 x265 [info]: References / ref-limit cu / depth : 4 / 1 / 1 x265 [info]: AQ: mode / str / qg-size / cu-tree : 1 / 1.0 / 32 / 1 x265 [info]: Rate Control / qCompress : ABR-1000 kbps / 0.60 x265 [info]: tools: rect limit-modes rd=4 psy-rd=2.00 rdoq=2 psy-rdoq=1.00 x265 [info]: tools: signhide tmvp strong-intra-smoothing deblock sao stats-read [1.0%] 1/100 frames, 5.75 fps, 738.00 kb/s, eta 0:00:17 [10.0%] 10/100 frames, 22.52 fps, 166.76 kb/s, eta 0:00:03 [19.0%] 19/100 frames, 26.32 fps, 137.94 kb/s, eta 0:00:03 [27.0%] 27/100 frames, 27.69 fps, 129.30 kb/s, eta 0:00:02 [35.0%] 35/100 frames, 27.91 fps, 125.79 kb/s, eta 0:00:02 [43.0%] 43/100 frames, 28.33 fps, 125.13 kb/s, eta 0:00:02 [51.0%] 51/100 frames, 28.70 fps, 124.24 kb/s, eta 0:00:01 [59.0%] 59/100 frames, 28.99 fps, 122.76 kb/s, eta 0:00:01 [67.0%] 67/100 frames, 29.13 fps, 122.07 kb/s, eta 0:00:01 [75.0%] 75/100 frames, 29.41 fps, 121.13 kb/s, eta 0:00:00 [84.0%] 84/100 frames, 29.72 fps, 118.84 kb/s, eta 0:00:00 [92.0%] 92/100 frames, 29.89 fps, 117.43 kb/s, eta 0:00:00 x265 [info]: frame I: 1, Avg QP:51.00 kb/s: 308.80 x265 [info]: frame P: 24, Avg QP:51.00 kb/s: 183.78 x265 [info]: frame B: 75, Avg QP:51.00 kb/s: 83.48 x265 [info]: Weighted P-Frames: Y:0.0% UV:0.0% x265 [info]: consecutive B-frames: 8.0% 0.0% 4.0% 60.0% 28.0% encoded 100 frames in 3.29s (30.40 fps), 109.80 kb/s, Avg QP:51.00 |
24th February 2016, 10:54 | #3274 | Link |
x265 [warning]: Error: 2pass curve failed to converge x265 [warning]: target: 1000.00 kbit/s, expected: 1140.97 kbit/s, avg QP: 68.7127 x265 [warning]: try increasing target bitrate BTW: Is this BasketballDrill_832x480_50.yuv downladable somewhere? It's not in Derf's collection, unfortunately. __ Trying similar parameters with a smaller file on an AMD Phenom-II X4, everything works well. I believe a common reason for 2-pass issues was that a statistics file created in a 1st pas was not read correctly or misinterpreted... For now I have no better idea. __ I can confirm this behaviour, using a CRF10 AVC-in-MKV source of BasketballDrill (uploaded a copy to my archive). Furthermore, for different other sources, 2-pass VBR misses the target bitrate, the result has about 75-80%. I will notify the x265 Developers mailing list about this case. __ I was able to narrow it down between a few archived builds: This issue was introduced between versions 1.8+167-e951ab673b1c and 1.8+201-769081eb5f4c. Last edited by LigH; 24th February 2016 at 13:51. |
24th February 2016, 17:11 | #3275 | Link |
Hum, funny stuff.
I received BasketballDrill_832x480_50.yuv again from staff of the Uni Hannover. It has originally 501 frames. Running them, the bitrate calculation converges. So I have to wonder if the reason behind this issue is indeed that you encode only 100 frames with a keyframe distance of 100 frames. Indeed: Adding "--frames 100 --keyint 100" to the command line provokes the miscalculation. |
24th February 2016, 18:46 | #3276 | Link |
@LigH: Thanks for the help! However, I still cannot get it to work properly, and I am little confused by a couple of your answers.
When I use all 501 frames, it somewhat improves, but 2nd pass is still much worse than 1st pass: 1: encoded 501 frames in 14.57s (34.38 fps), 1029.45 kb/s, Avg QP:35.94 2: encoded 501 frames in 31.30s (16.00 fps), 711.98 kb/s, Avg QP:38.16 When I encode the shortened 100 frames version (Y4M) with neither --frames, nor --keyint, the resulting bitrate is no better than with those parameters. So it seems 2 pass does not work on short clips at all. I tried other clips (100 frames) and the problem is the same. >> Furthermore, for different other sources, 2-pass VBR misses the target bitrate, the result has about 75-80%. OK. That's what I am seeing as well, for longer sequences and other bitrates. See 1st paragraph. It seems 1-pass is the only option for now. >> Trying similar parameters with a smaller file on an AMD Phenom-II X4, everything works well. Is this also the case for the command line parameters and clip in question (posted above)? How about the 75-80% 2nd pass issue in general? (Yeah, these test sequences are hard to track down without the right connections...) Last edited by n808; 24th February 2016 at 18:50. |
24th February 2016, 20:18 | #3277 | Link |
Remember, I found that this issue was introduced during a specific period of development. Now we have to give the developers some time to discover which change exactly caused it, so they can later fix it... But I hope I could help good enough to find the reason quickly now.
I believe the extreme result of being unable to converge always happens when you have only one GOP; when (what I guess may be the reason) the statistics of the first GOP are accidentally skipped, then everything is skipped because that was only one. The default keyframe interval is already more than 100 frames, so encoding only 100 frames will provoke it already without explicitly limiting the keyframe interval to only 100 frames, which could have been e.g. 250 or 300 frames without this parameter. |
24th February 2016, 20:31 | #3278 | Link | |
Here's what I think is the conclusion:
24th February 2016, 21:09 | #3279 | Link |
x265-1.8+167:
i:\speed\2p>ffmpeg -i b.mkv -v warning -f yuv4mpegpipe - | x265-18+167 --y4m - -p slow --bitrate 1000 --keyint 100 -o w2.hevc -- pass 2 y4m [info]: 832x480 fps 50/1 i420p8 sar 1:1 unknown frame count raw [info]: output file: w2.hevc x265 [info]: HEVC encoder version 1.8+167-e951ab673b1c x265 [info]: build info [Windows][MSVC 1900][64 bit] 10bit x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX x265 [info]: Main 10 profile, Level-3.1 (Main tier) x265 [info]: Thread pool created using 4 threads x265 [info]: frame threads / pool features : 2 / wpp(8 rows) x265 [warning]: Source height < 720p; disabling lookahead-slices x265 [info]: Coding QT: max CU size, min CU size : 64 / 8 x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra x265 [info]: ME / range / subpel / merge : star / 57 / 3 / 3 x265 [info]: Keyframe min / max / scenecut : 10 / 100 / 40 x265 [info]: Lookahead / bframes / badapt : 25 / 4 / 2 x265 [info]: b-pyramid / weightp / weightb : 1 / 1 / 0 x265 [info]: References / ref-limit cu / depth : 3 / 0 / 0 x265 [info]: AQ: mode / str / qg-size / cu-tree : 1 / 1.0 / 32 / 1 x265 [info]: Rate Control / qCompress : ABR-1000 kbps / 0.60 x265 [info]: tools: rect rd=4 psy-rd=0.30 rdoq=2 psy-rdoq=1.00 signhide tmvp x265 [info]: tools: strong-intra-smoothing deblock sao stats-read x265 [info]: frame I: 1, Avg QP:27.14 kb/s: 9306.40 x265 [info]: frame P: 24, Avg QP:30.98 kb/s: 2060.87 x265 [info]: frame B: 75, Avg QP:36.53 kb/s: 467.95 x265 [info]: Weighted P-Frames: Y:0.0% UV:0.0% x265 [info]: consecutive B-frames: 8.0% 0.0% 4.0% 60.0% 28.0% encoded 100 frames in 11.99s (8.34 fps), 938.64 kb/s, Avg QP:35.10 Code:
i:\speed\2p>ffmpeg -i b.mkv -v warning -f yuv4mpegpipe - | x265-18+168 --y4m - -p slow --bitrate 1000 --keyint 100 -o w2.hevc -- pass 2 y4m [info]: 832x480 fps 50/1 i420p8 sar 1:1 unknown frame count raw [info]: output file: w2.hevc x265 [info]: HEVC encoder version 1.8+168-73cc1cd4c7fc x265 [info]: build info [Windows][MSVC 1900][64 bit] 10bit x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX x265 [info]: Main 10 profile, Level-3.1 (Main tier) x265 [info]: Thread pool created using 4 threads x265 [info]: frame threads / pool features : 2 / wpp(8 rows) x265 [warning]: Source height < 720p; disabling lookahead-slices x265 [warning]: Error: 2pass curve failed to converge x265 [warning]: target: 1000.00 kbit/s, expected: 1133.83 kbit/s, avg QP: 68.7129 x265 [warning]: try increasing target bitrate x265 [info]: Coding QT: max CU size, min CU size : 64 / 8 x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra x265 [info]: ME / range / subpel / merge : star / 57 / 3 / 3 x265 [info]: Keyframe min / max / scenecut : 10 / 100 / 40 x265 [info]: Lookahead / bframes / badapt : 25 / 4 / 2 x265 [info]: b-pyramid / weightp / weightb : 1 / 1 / 0 x265 [info]: References / ref-limit cu / depth : 3 / 0 / 0 x265 [info]: AQ: mode / str / qg-size / cu-tree : 1 / 1.0 / 32 / 1 x265 [info]: Rate Control / qCompress : ABR-1000 kbps / 0.60 x265 [info]: tools: rect rd=4 psy-rd=0.30 rdoq=2 psy-rdoq=1.00 signhide tmvp x265 [info]: tools: strong-intra-smoothing deblock sao stats-read x265 [info]: frame I: 1, Avg QP:51.00 kb/s: 358.00 x265 [info]: frame P: 24, Avg QP:51.00 kb/s: 194.60 x265 [info]: frame B: 75, Avg QP:51.00 kb/s: 88.01 x265 [info]: Weighted P-Frames: Y:0.0% UV:0.0% x265 [info]: consecutive B-frames: 8.0% 0.0% 4.0% 60.0% 28.0% encoded 100 frames in 5.98s (16.71 fps), 116.29 kb/s, Avg QP:51.00 |
