11th December 2019, 01:21 | #17981 | Link | |
Grumpy Old Man.
Not poorly done, just doin' it my way !!! Live every day like it's your last, because one day, it will be !! (M$B) |
11th December 2019, 05:55 | #17982 | Link |
Grumpy Old Man.
Frustrating Encoding lockup's
I have had a pretty frustrating couple of days with the problem that is shown in the screen shots (attached).
https://www.mediafire.com/file/dxboz...blems.rar/file I have a job encoding as it should, using a couple of servers, and it gets to a random point, and everything just stops (as far as the Encoding Client is concerned), if you check cpu usage, and TCP traffic, etc, it's still encoding in the background, but no progress is shown, it's completes the chunk that it was on, (when it locked up), then it stops, will not start another chunk. The abort function does not work, you have to "kill" it with processhacker or similar, then once RB is finally shutdown...if you start that same job again, nothing starts I know a video capture would have been preferable, but I had nothing set up on the pc to do that. So the pic's (in order) shows that the Client is stalled, but the Server is still processing, in the 2nd pic it shows that Client is still the same, but the Server has now finished. Then 3rd pic is restarting the job...and that's where it stays. This has happened on 2 different pc's, and different jobs, all freshly loaded using the very latest RB version.
11th December 2019, 11:47 | #17983 | Link |
Can you move encoding client window or IT is locked with not responding message in title?
11th December 2019, 12:40 | #17984 | Link |
Grumpy Old Man.
Not 100% what you mean, but I don't think I tried to move it, but I'm pretty sure you couldn't minimize it, close it, so maybe if I had of tried to move it, it wouldn't have....I don't recall any message displayed.
11th December 2019, 15:24 | #17985 | Link |
I have a feature request.
The file currently encoding has an eta which is really useful. I would also like to know the estimated file size. I realise that it may not be 100% accurate and that the predicted size will change during the encode but it would be useful none the less. |
11th December 2019, 15:24 | #17986 | Link | |
Error: The file 'D:\Temp\RipBot264temp\job2\video.265' could not be opened for reading: open file error. Probably related to the new code that is combing chunks during the encoding job. |
11th December 2019, 15:39 | #17987 | Link | |
fK |
11th December 2019, 15:45 | #17988 | Link | |
11th December 2019, 15:50 | #17989 | Link |
I will prepare debug version for you guys. I will need approximately 1 hour.
11th December 2019, 15:51 | #17990 | Link | |
11th December 2019, 17:00 | #17991 | Link |
Use this debug version -> https://www.mediafire.com/file/e4w9w...lient.exe/file
and then post content of Debug.txt when encodingclient.exe hangs.
12th December 2019, 00:15 | #17992 | Link | |
http://ix.io/24aS |
12th December 2019, 00:22 | #17993 | Link | |
12th December 2019, 06:12 | #17994 | Link | |
Grumpy Old Man.
Anyways... I got around to doing a test with the same movie I had problems with yesterday, and it's funny you're sitting there waiting for it to f*** up, and it did , and it didn't get as far, this time. Please check out the attached screenshots & debug.txt's. https://www.mediafire.com/file/8g4ya...Debug.rar/file Firstly (attempt 1) I just tried to see what yesterdays stalled job would do the the debug client (not a lot) Then I reloaded the job, (attempt 2) and it all started OK (a bit slow on the uptake due to using MD2 custom filter) Anyway, to my untrained eye, there doesn't appear to be any errors, (as per Ryushin's post), it just simply stopped, however the server I had helping, completed the 4 chunks it had left to do, then it stopped, without issue. But once an Abort was initiated, the window was locked in position (if that means anything), it didn't Abort, so back to ProcessHacker to do the job.
12th December 2019, 12:12 | #17995 | Link |
At least i know that code resonsible for combining chunks works as intended. I will prepare debug2 with more loging in other parts of the code.
12th December 2019, 12:37 | #17996 | Link | |
Grumpy Old Man.
So, will keep an eye out for debug2, and give it a run. Are the screen shots helpful ?? Is there any other info you might need ??
12th December 2019, 12:58 | #17997 | Link | |
http://ix.io/24cD |
12th December 2019, 13:03 | #17998 | Link | |
Grumpy Old Man.
Did it work with the Abort function ??
12th December 2019, 13:19 | #18000 | Link | |
Grumpy Old Man.
Well, another interesting challenge for Atak.
