20th March 2010, 23:32 | #7201 | Link |
Been using Ripbot quite successfully for the last month and then all of a sudden it thinks I don't have ffdshow installed. I've tried uninstalling and reinstalling ffdshow several times without any luck. I finally setup Windows from scratch and reinstalled and Ripbot still doesn't think I have ffdshow installed. Any ideas what I can try to fix this?
20th March 2010, 23:47 | #7202 | Link |
21st March 2010, 00:08 | #7204 | Link |
21st March 2010, 00:11 | #7205 | Link |
hey Atak, fixed my previous problem with a new re-install of all programs...but currently encountered something different, hopefully you have some ideas...
I have been converting a list of movies and after one of them finished I decided to take a break and let my PC cool off by shutting it down for a while...been using it non-stop for almost three days. Anyways, I still had like 6 movies in the queue, but after the re-start they do not show up anymore?? The "keep jobs que" is still checked (I never change this setting), and I still have the jobs in the TEMP folder, so I don't know what happened?? Is it possible to load the TEMP files back into ripbot without having to go through the whole analyze process again?? Any help is appreciated! TEMP folder: Ripbot queue: Last edited by crackinhedz; 21st March 2010 at 00:13. |
21st March 2010, 00:13 | #7206 | Link |
edit ripbot264.ini
StoreTempFilesin=C
21st March 2010, 00:35 | #7208 | Link |
what do you see in ripbot264.ini?
21st March 2010, 01:06 | #7209 | Link | |
21st March 2010, 01:09 | #7210 | Link |
what do you see at the bottom?
21st March 2010, 01:16 | #7212 | Link |
what does last line of .ini show?
21st March 2010, 01:28 | #7214 | Link |
if 0 = off and 1 = on. what does this say to you?
21st March 2010, 12:37 | #7217 | Link |
hey atak,
i really like ripbot, i'm using the x64 under w7 64 and it works perfectly and also the encoding speed is quite good. thanks for that... even though, one question... is it possible to pause and resume the encoding work? cheers, jefe |
21st March 2010, 17:12 | #7218 | Link |
I've only got a figure of 1.33:1, no options for 1.85 or 1.78 which was what confused me. I'm taking an mpg2 file (720*576) which is a vertically-squeezed anamorphic image, and want to make it 16:9 (1024*576) so Ripbot doesn't automatically appear to bring up 1.78:1 as any kind of an option. How do I bring up those options manually, please?
Last edited by Guest; 21st March 2010 at 17:36. Reason: rule 4: removed ad hominems |
21st March 2010, 20:42 | #7219 | Link |
Hey Atak,
I just downloaded RipBot264 1.15.1 which requires ffdshow r3300+ but, at http://sourceforge.net/projects/ffdshow-tryout/files/ I only see the generic win32 build at rev3299; am I able to use any of the other ffdshow builds with 1.15.1? Thanks!
- Intel i7 930,ASRock x58,6GB G.Skill RAM,WD VelociRaptor,(2x)WD Black 2TB,(2x)EVGA GTX470 - (2x)Intel Xeon 5450,Intel 5000-sumthin' MOBO,12GB Unbuffered Kingston RAM,PNY Quadro FX 580,WD Black 1TB |
21st March 2010, 22:42 | #7220 | Link |
