Old 7th January 2013, 14:55   #12041  |  Link
LigH
LigH's Avatar
From the archive:
Originally Posted by johnman View Post
dg providem me with v1.9
THX for that DSPguru
but i have read the documentation from the azid files and the author (midas) wants me to add splash screens, and some other things which i personally dont really like.
The azid.dll could possibly be used via the besweet.dll, but I believe that will only shift the issue to another level.
Midas (Azid), DSPguru (BeSweet), DarkAvenger (HeadAC3he) — Hopping from one dead horse to another...
And there is also a package with azid.exe CLI decoders (P3/P4 opt.), but you may try to avoid intermediate files?
New German Gleitz board
Old 7th January 2013, 15:02   #12042  |  Link
Chumbo
Chumbo's Avatar
eac3to v3.27 released
http://madshi.net/eac3to.zip
* fixed: raw processing cut away 16 samples sometimes
I'll probably be gone for a while now.
Thanks again. Hey, before you go, would you update the first post to reflect version 3.27 please?
Chumbo
Chumbo is offline   Reply With Quote
Old 7th January 2013, 15:14   #12043  |  Link
madshi
Originally Posted by LigH View Post
From the archive:
Midas (Azid), DSPguru (BeSweet), DarkAvenger (HeadAC3he) Hopping from one dead horse to another...
Doesn't matter anymore, anyway. See v3.26 release notes.
Old 8th January 2013, 19:05   #12044  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
does new version still need MSVCP71.dll in system folder?
http://forum.doom9.org/showthread.ph...04#post1607304
Old 8th January 2013, 20:09   #12045  |  Link
rapscallion
NY Frame of Mind
rapscallion's Avatar
Thanks madshi for new version....however, Nemo 7.1 THD, decode to wavs, still fails lossless check :
[libav] Lossless check failed - expected 00, calculated f4.  <WARNING>
[libav] Lossless check failed - expected 00, calculated 65.  <WARNING>
[libav] Lossless check failed - expected 00, calculated f6.  <WARNING>
[libav] Lossless check failed - expected 00, calculated 88.  <WARNING>
The original audio track has a constant bit depth of 20 bits.
I've never seen the 20 bits depth before, besides this nemo track.
Edit: Correction, the previous libav (ver 3.25) would crash completely, while now it creates the wavs w/the warnings above. This is the same thing when creating flac via ffmpeg, so maybe it's a somehow corrupted stream.
"Talk to me Goose"
rapscallion is offline   Reply With Quote
Old 9th January 2013, 02:56   #12046  |  Link
Overdrive80
Anime addict
Overdrive80's Avatar
Hi, one question... Does eac3to decode to do "slowdown"???
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Nvidia GTX750 2GB DDR5 + SSD Vertex 4 256 GB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite
Overdrive80 is offline   Reply With Quote
Old 9th January 2013, 03:20   #12047  |  Link
tebasuna51
tebasuna51's Avatar
Yes, slowdown-resample work over uncompressed audio data then eac3to must decode compressed audio before.
Old 11th January 2013, 09:54   #12048  |  Link
Furiousflea
Is there still a need to remap channels when decoding DTS 6.1 tracks with Arcsoft decoder with latest eac3to.
The changelog is ambiguous if that has been fixed or do we still need to specify a channel layout?
Furiousflea is offline   Reply With Quote
Old 11th January 2013, 10:38   #12049  |  Link
tebasuna51
tebasuna51's Avatar
Decode was always fine, only when you use -down6 was wrong.
And fixed now.
Old 12th January 2013, 08:49   #12050  |  Link
dansrfe
So I recently bought a bluray which has 16-bit, 96Khz TrueHD and 24-bit, 48Khz DTS-HD/MA audio tracks. My question is: if space is not an issue and playback will always involve decoding to PCM via arcsoft's decoder or the like, which track should I keep in the mkv encode?
Also, as a side question, if I will always play back from my computer then is it better to encode lossless audio from DTS-HD/MA or TrueHD to FLAC and maintain the original file's bit-depth and sample rate or should I just keep the original DTS-HD-MA/TrueHD file?
Old 12th January 2013, 10:11   #12051  |  Link
Furiousflea
And fixed now.
Thanks for explaining that, much appreciated.
Old 12th January 2013, 11:55   #12052  |  Link
tebasuna51
tebasuna51's Avatar
Seems than standard human ear can distinguise until 20 bit precission audio but not much over 20 KHz frequency (samplerate 40 KHz).
If your PC can send to receiver, through HDMI, PCM multichannel audio (decoded from FLAC or DTS-HD-MA/TrueHD) then the quality is always the same. Flac files have less size.
There are external players (PopCorn, Xtreamer, ...) than can send also Flac decoded to PCM multichannel.
Old 12th January 2013, 16:56   #12053  |  Link
messi magician
I seem to be experiencing strange problems with some of my blu ray rips when converting Dts-HD Master to AC3 640 using eac3to
When playing back the m2ts files using Arcsoft player the audio says Dolby AC3 along with some odd kbps figures - 31kbps or 129kbps ect
Usually films just say Dolby AC3 in Arcsoft, i've even updated to the new version of Arcsoft and it still displays these odd numbers
When i ripped the Hunger Games which come out as 31kbps the audio sounded quieter compared to some of my other films so i have to turn up the volume a few notches
Checking the files though with mediainfo it shows the track as 640kbps English 48.0 KHz, 16bits, 6 channels, AC3 which is correct
Anyone else experieced this ? is this normal or is this a known problem with eac3to not converting the audio properly ?
I'm using the latest version of eac3to and arcsoft decoder 1.1.0.0
messi magician is offline   Reply With Quote
Old 14th January 2013, 01:06   #12054  |  Link
Snowknight26
tebasuna51's results are fundamentally different. "[libav]" means eac3to got the log message from libav. "[truehd @ ...]" means ffmpeg/libav bypassed eac3to and wrote the log directly to the command line window. Which ffmpeg/libav should not do because eac3to told it to forward all log messages to eac3to instead of writing them to the command line window. So the logging system is broken for you, but not for tebasuna51, nor for me.
Had the same behavior happen on a different system.
With the sample I've PMed you, simply running
eac3to part1.m2ts+part2.m2ts 2: test.flac
is enough to show the issue.
Snowknight26 is offline   Reply With Quote
Old 14th January 2013, 16:26   #12055  |  Link
Vick
@madshi
There is description of *.dtshd file in Annex E. Can you add header (and other chunks) to DTS-MA and DTS-HR file?
If examples of *.dtshd file are necessary, I can generate ones?
Vick is offline   Reply With Quote
Old 14th January 2013, 23:23   #12056  |  Link
rapscallion
NY Frame of Mind
Vick...why would he want him to? If you're talking about *.dtshd files created by DTS-MA suite, that header is only used by authoring houses. For our purposes, we do NOT want the header to be there.
It can be easily removed by demuxing the track/stream via Tsmuxer. The resulting demux will have a *.dts extension, just like on a BD disc.
"Talk to me Goose"
Old 14th January 2013, 23:41   #12057  |  Link
jj666
As a reminder, you still need to have a -21ms delay when removing .dtshd MA suite headers with EAC3TO, this bug didn't get fixed yet.
Cheers,
-jj-
jj666 is offline   Reply With Quote
Old 14th January 2013, 23:46   #12058  |  Link
rapscallion
NY Frame of Mind
@jj, that's why I use Tsmuxer.
"Talk to me Goose"
Old 14th January 2013, 23:55   #12059  |  Link
filler56789
SuperVirus
filler56789's Avatar
I think there are people who would like to decompress the DTS-HD files to .WAVs through the "official" StreamPlayer (simply because ArcSoft's DTSdecoderdll.DLL not always works as it should), and in this case too, the DTS-HD headers are mandatory.
filler56789 is offline   Reply With Quote
Old 15th January 2013, 02:09   #12060  |  Link
robertcollier4
Getting a line of output per second from the Nero encoder? Nero reporting every single second seems to be making eac3to think Nero is stuck. How can we disable Nero AAC encoder from reporting second by second processing?
command line: eac3to S01E01.mkv S01E01-downDpl.aac -downDpl
MKV, 1 video track, 1 audio track, 1:26:26, 24p /1.001
1: h264/AVC, English, 720p (16:9)
2: AC3, English, 5.1 channels, 384kbps, 48kHz, dialnorm: -27dB
[v01] The video track doesn't contain framerate information. <WARNING>
Track 2 is used for destination file "S01E01-downDpl.aac".
[a02] Extracting audio track number 2...
[a02] Removing AC3 dialog normalization...
[a02] Decoding with libav/ffmpeg...
[a02] Downmixing multi channel audio to stereo...
[a02] Reducing depth from 64 to 32 bits...
[a02] Encoding AAC <0.50> with NeroAacEnc...
[a02] Clipping detected, a 2nd pass will be necessary. <WARNING>
[a02] The Nero AAC encoder seems to be stuck... <ERROR>
[a02] [NeroAacEnc] Processed 0 seconds...
[a02] [NeroAacEnc] Processed 1 seconds...
.... (LINES CUT OUT FOR FORUM... THERE IS A LINE PER SECOND) ...
[a02] [NeroAacEnc] Processed 5053 seconds...
[a02] [NeroAacEnc] Processed 5054 seconds...
Aborted at file position 2801484127. <ERROR>
robertcollier4 is offline   Reply With Quote
eac3to
