Old 27th March 2011, 19:44   #11041  |  Link
Snowknight26
eac3to doesn't seem to handle TrueHD frame changes at the moment. A sample file I have switches from 6 channels to 2 channels within the first few hundred KB, but when it does, eac3to returns "a03 libav Restart header sync incorrect (got 0x14be)" then fails while ffmpeg decodes it properly. Any chance supporting this?
Snowknight26 is offline   Reply With Quote
Old 27th March 2011, 19:46   #11042  |  Link
Sharc
....Here the parameter -24.000 does nothing.
Out of curiosity: Isn't the effect similiar to avisynth's AssumeFPS(xx) vs ChangeFPS(yy)?
I mean -24.000 would set the new audio playback speed and change the original duration, while -changeTo24.000 would keep the original duration?
Old 27th March 2011, 20:27   #11043  |  Link
Undead Sega
Hi guys, sorry if this may have been brought up before, but I was wondering if it is possible to do either slowdown or speedup whilst preserving the pitch?
For example: '23.796 to 25' pitch preserving/correction? and vice-versa with different framerates?
Undead Sega is offline   Reply With Quote
Old 27th March 2011, 23:56   #11044  |  Link
Thunderbolt8
not unless you post the sample
Old 28th March 2011, 01:25   #11045  |  Link
Sharc
I am not sure how it goes with eac3to. However, it's certainly possible via avisynth (timestretch) and more easily via BeSweet/BeLight (GUI) for example.
Old 28th March 2011, 04:03   #11046  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by krosswindz View Post
dvd video (23.976fps) runtime is: 10619286 ms
blu-ray video (24fps) runtime is: 10631458 ms
Then
dvd video have 10619286 x 23.976 = 254608 frames
bd video have 10631458 x 24 = 255155 frames
The bd video have 547 more frames (~23 seconds) than dvd video. Isn't the same video and you need a big edit to use the audio.
Old 28th March 2011, 04:10   #11047  |  Link
krosswindz
Then
I noticed the difference in runtime, what is weird is the main movie is the same for both Blu-ray and DVD. There is difference in the title and credits of the movie in terms of additional information. I thought adding suitable delay to sync the audio should work. For some reason it just goes out of sync progressively. When I compare the runtimes of the converted audio from the original audio the original audio is ~1.001 * converted audio runtime. I guess I need to see what else is different to fix it.
krosswindz is offline   Reply With Quote
Old 28th March 2011, 13:47   #11048  |  Link
tebasuna51
tebasuna51's Avatar
Audio don't have reference to video fps, then a pair of fps like -24.000 -changeTo23.976 only means enlarge the audio duration by (24/(24/1.001)) = 1.001
Some defaults can work, for instance:
-slowdown is equivalent to -25.000 -changeTo23.976
-speedup is equivalent to -23.976 -changeTo25.000
But I like always put the fps pair and don't assume any fps for audio.
The fps equivalent parameter for audio is samplerate:
48 KHz means 48000 audio samples per second, like 24 fps means 24 video frames per second.
Nope with soft included in eac3to
... it's certainly possible via avisynth (timestretch) and more easily via BeSweet/BeLight (GUI) for example.
Yes.
(but with BeSweet try only with stereo files)
Old 28th March 2011, 13:55   #11049  |  Link
tebasuna51
tebasuna51's Avatar
There is difference in the title and credits of the movie in terms of additional information...
Then try only with a initial delay, with the original DVD audio or with the stretched (1/1.001) DVD audio.
No problem with end credits the audio can be short than video.
Old 28th March 2011, 20:37   #11050  |  Link
Sharc
Thanks for clarification.
Does such pair of fps preserve or change the pitch?
Old 28th March 2011, 22:03   #11051  |  Link
Chouonsoku
I'm having an issue with a DTS-HD MA 6.1 audio track from Ghost in the Shell 2: Innocence's Absolute Edition. The disc has a TrueHD 6.1 and a DTS-HD MA 6.1 track, and I can compress the TrueHD to FLAC, extract the DD5.1-EX core and also extract the DTS-ES 6.1 core, but when I compress the DTS-MA HD track to FLAC, it ends up being around 2.5 GB (vs. the DTS-MA HD's 1.8 GB) and the output file is also stretched somewhat. The original runtime of the film is 1hr 39m, however the FLAC of the DTS track reports it's 1hr 53m long, and during playback the audio is there, but it's distorted and stretched. No warnings or errors are reported by eac3to, and again all other tracks playback fine.
Originally Posted by eac3to
eac3to v3.24
command line: eac3to 1) 1:chapters.txt 2:innocence.h264 3: japanese.ac3 -core 3:japanese-truehd.flac 4:japanese.dts -core 4:japanese-dts.flac 7:english.sup
M2TS, 1 video track, 2 audio tracks, 3 subtitle tracks, 1:39:06, 24p /1.001
1: Chapters, 20 chapters
2: h264/AVC, 1080p24 /1.001 (16:9)
3: TrueHD/AC3, Japanese, 6.1 channels, 48kHz
(embedded: AC3 EX, 5.1 channels, 640kbps, 48kHz)
4: DTS Master Audio, Japanese, 6.1 channels, 16 bits, 48kHz
(core: DTS-ES, 6.1 channels, 16 bits, 1509kbps, 48kHz)
5: Subtitle (PGS), Japanese
6: Subtitle (PGS), Japanese
7: Subtitle (PGS), English
Creating file "chapters.txt"...
[a04] Extracting audio track number 4...
[v02] Extracting video track number 2...
[a03] Extracting audio track number 3...
[a04] Extracting DTS core...
[s07] Extracting subtitle track number 7...
[a04] Remapping channels...
[a03] Extracting TrueHD stream...
[a04] Patching bitdepth to 24 bits...
[a03] Decoding with libav/ffmpeg...
[a03] Extracting AC3 stream...
[a04] Decoding with ArcSoft DTS Decoder...
[a03] Remapping channels...
[a04] Encoding FLAC with libFlac...
[a03] Encoding FLAC with libFlac...
[a04] Creating file "japanese.dts"...
[v02] Creating file "innocence.h264"...
[a04] Creating file "japanese-dts.flac"...
[a03] Creating file "japanese-truehd.flac"...
[a03] Creating file "japanese.ac3"...
[s07] Creating file "english.sup"...
[a03] The original audio track has a constant bit depth of 16 bits.
[a04] The original audio track has a constant bit depth of 16 bits.
[a03] Superfluous zero bytes detected, will be stripped in 2nd pass.
[a03] Starting 2nd pass...
[a03] Decoding FLAC...
[a03] Reducing depth from 24 to 16 bits...
[a03] The processed audio track has a constant bit depth of 16 bits.
Video track 2 contains 142560 frames.
Subtitle track 7 contains 814 captions.
eac3to processing took 34 minutes, 53 seconds.
Done.
Chouonsoku is offline   Reply With Quote
Old 29th March 2011, 00:31   #11052  |  Link
Snowknight26
Most likely an issue with the ArcSoft DTS decoder. What version is it?
Old 29th March 2011, 07:46   #11053  |  Link
sneaker_ger
Change.
Old 3rd April 2011, 05:36   #11054  |  Link
TDiTP_
Stupid question. Why eac3to need MkvToolNix?
TDiTP_ is offline   Reply With Quote
Old 3rd April 2011, 06:17   #11055  |  Link
Mark_A_W
3 eyed CRT supporter
Hi all
Quick question..
What is the command line to upconvert a 6.1 TrueHD track to 7.1 FLAC (with centre rear doubled to L back and R back)?
There's a trilogy coming out soon (finally..) with 6.1 sound
Mark_A_W is offline   Reply With Quote
Old 3rd April 2011, 07:26   #11056  |  Link
TDiTP_
-double7
But this command does work incorrect, you need to add -0,1,2,3,5,6,4:
eac3to input output -double7 -0,1,2,3,5,6,4
Old 8th April 2011, 01:00   #11057  |  Link
Chouonsoku
Originally Posted by eac3to -test
eac3to (v3.24) is up to date
Nero Audio Decoder (Nero 7) works fine
ArcSoft DTS Decoder (1.1.0.8) works fine
Sonic Audio Decoder (4.3.0.169) works fine
Haali Matroska Muxer (2011-03-03) is up to date
Nero AAC Encoder (1.5.4.0) is up to date
Surcode DTS Encoder doesn't seem to be installed
http://www.surcode.com
MkvToolnix (4.6.0.0, release version) is up to date
Is there a newer version?
Edit: Something I just noticed though, eac3to reports the track as being 16-bit however the bits aren't stripped in the second pass like they are for the TrueHD track. I'm testing decoding with Sonic Audio Decoder now to see if that works, although I'd rather not use it.
Edit 2: Sonic decoded it fine, same exact bitrate as the TrueHD (figured). Plays back fine and has the correct length. Still don't know why ArcSoft is having a problem with it.
Old 8th April 2011, 09:10   #11058  |  Link
TDiTP_
For decode track 4:
you need ArcSoft DTS Decoder 1.1.0.0 (you can find it here). Versions 1.1.0.7 and 1.1.0.8 can't decode DTS-ES 6.1 properly, it's known bug.
Sonic can't decode DTS-ES 6.1 properly too. BC-channel is empty always.
Old 8th April 2011, 11:49   #11059  |  Link
Mark_A_W
What about 1.1.0.5? Can that do 6.1?
Old 8th April 2011, 11:56   #11060  |  Link
TDiTP_
i don't know. If you give me this version, i can test it.
eac3to
