14th January 2009, 10:25 | #7841 | Link | ||
That's a bug, but it has no negative effect.
14th January 2009, 15:44 | #7842 | Link |
When muxing raw h264 stream to mkv using eac3to it doesn't appear to include the "muxing mode" information in the container. Verified using mediainfo. I understand this isn't anything important, just thought I'd pass it along.
For example: Raw h264 stream to mkv using mkvmerge: Code:
Video Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 3 frames Muxing mode : Container profile=Unknown@4.1 Codec ID : V_MPEG4/ISO/AVC Duration : 1mn 59s Bit rate : 3 182 Kbps Nominal bit rate : 3 324 Kbps Width : 1 280 pixels Height : 688 pixels Display aspect ratio : 1.860 Frame rate : 23.976 fps Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.151 Writing library : x264 core 65 r1074M b6bb3d4 Code:
Video Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 3 frames Muxing mode : Container profile=Unknown@0.0 Codec ID : V_MPEG4/ISO/AVC Duration : 1mn 59s Bit rate : 3 181 Kbps Nominal bit rate : 3 324 Kbps Width : 1 280 pixels Height : 688 pixels Display aspect ratio : 1.860 Frame rate : 23.976 fps Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.151 Writing library : x264 core 65 r1074M b6bb3d4 |
14th January 2009, 15:45 | #7843 | Link | |
I have an HDDVD with an EAC3 track that has a delay of -1001ms. When I processed it (which was a few months ago, so an older version of eac3to, don't remember which), it said it took care of the delay, yet there is still a delay, just not -1001ms. I have not been able to tell exactly how much, but through trial and error, I have narrowed it down to somewhere around 100ms. Could you please add a feature which always adds the correct delay amount to either the file name and/or the log, regardless of if it was processed or not? Even if eac3to was able to process the file correctly to a 0ms delay, that would still be helpful to see. |
14th January 2009, 15:51 | #7844 | Link | |
I think I read somewhere that about 16ms is as close as anyone can determine a/v sync, could be even bigger, anyone know what the number is? |
14th January 2009, 15:57 | #7845 | Link | |
Chumbo |
14th January 2009, 16:08 | #7846 | Link | ||||||
A normal human can see a delay mismatch of maybe 30-50ms if he's really good. Many people only see a mismatch of 100ms or bigger. The best eac3to can do with bitstream audio is half an audio frame, which in the worst case is a raster of 16ms correction for AC3 tracks. All other audio tracks have smaller audio frames than that. So 16ms mismatch is worst case. And as I said, if you ask eac3to to decode/transcode audio, delay can be corrected in 1/48 ms steps. Quote:
14th January 2009, 16:48 | #7847 | Link | |
I am one of those people who are extremely sensitive to audio delays. Last edited by Nullity; 14th January 2009 at 16:56. |
14th January 2009, 19:13 | #7851 | Link | |
(Sorry, if you already answered that to any of your previous posts) |
14th January 2009, 19:26 | #7852 | Link |
What's the best way to redo 1088 mkvs I made long time ago with gdsmux? I wanna get rid of that gray line. Demux with mkvextractgui, then mux to mkv with eac3to, or mux to ts with tsmuxer and back to mkv with eac3to? or other?
14th January 2009, 20:01 | #7853 | Link | ||
eac3to |
