21st December 2007, 00:02 | #2122 | Link |
Well... is this necessary?
Oh, i forgot to mention it before. I used nero decoder, cause the libav produced the "famous" error again. As you said earlier, it must be the only flaw to the code. |
21st December 2007, 00:17 | #2123 | Link |
Yes and no. Of course an intelligent human can easily see that double decoding is kind of superfluous. But trying to duplicate this with a computer program is not always that straightforward. Sure I could do it, but it would make the code a lot more complicated. So I implemented a simpler solution which sometimes results in double decoding. On the positive side, due to the simpler code there's less potential for bugs.
21st December 2007, 02:55 | #2125 | Link |
can you tell in how far codes or routines from other programs (for example evodemux or h264tsto or haali filters) were used regarding .evo joining & de- and remuxing? would be useful in case we get errors, so we might know which program(s) would produce a similar error in that case and dont have to try each other tool then.
21st December 2007, 06:11 | #2126 | Link |
Another one to report. I ran the -test switch to see it in action and note the results for the Nero Audio Decoder. Please let me know what other info I can provide:
eac3tov2 feature_1.evo+feature_2.evo -test Nero Audio Decoder (Nero 7 or older) is not working correctly Sonic Audio Decoder (4.3.0.169) works fine Haali Media Splitter (2007-11-18) is installed Surcode DTS Encoder (1.0.23.0) is installed MkvToolnix (v2.1.0) is installed EVO/VOB, 2 video tracks, 4 audio tracks, 1:29:31 1: Joined EVO/VOB file 2: VC-1 3: VC-1 4: E-AC3, 5.1 channels, 384kbit/s, 48khz, dialnorm: -27dB, -8ms 5: TrueHD, 5.1 channels, 48khz, dialnorm: -24dB, -1ms 6: E-AC3, 2.0 channels, 192kbit/s, 48khz, dialnorm: -27dB, -8ms 7: E-AC3, 2.0 channels, 192kbit/s, 48khz, dialnorm: -27dB, -27ms btw, EVOdemux confirms the two video streams and 4 audio streams, so I'm not sure why the Nero stuff is missing 1 video and the remaining audio stream. Please let me know what else I can do to help with this one. May I request a wish list item please. In addition to the video codec, i.e., "VC-1" above as an example, is there a way to provide a few more pieces of info? Something like "VC-1, 1920x1080, 23.976, pulldown" and pulldown would only be there if the video has the pulldown flag. If it's doable. [EDIT] Well, 5 seconds after I posted this, I tried something else. I renamed eac3tov2.exe to recode.exe and reran the line above and what do you know? Code:
Nero Audio Decoder (Nero 7 or older) works fine Sonic Audio Decoder (4.3.0.169) works fine Haali Media Splitter (2007-11-18) is installed Surcode DTS Encoder (1.0.23.0) is installed MkvToolnix (v2.1.0) is installed EVO/VOB, 2 video tracks, 4 audio tracks, 1:29:31 1: Joined EVO/VOB file 2: VC-1 3: VC-1 4: E-AC3, 5.1 channels, 384kbit/s, 48khz, dialnorm: -27dB, -8ms 5: TrueHD, 5.1 channels, 48khz, dialnorm: -24dB, -1ms 6: E-AC3, 2.0 channels, 192kbit/s, 48khz, dialnorm: -27dB, -8ms 7: E-AC3, 2.0 channels, 192kbit/s, 48khz, dialnorm: -27dB, -27ms
Chumbo Last edited by Chumbo; 21st December 2007 at 06:17. |
21st December 2007, 06:27 | #2127 | Link | |
Sample of Eagles HD-DVD EVO to verify LPCM problem
Its about 96MB. Plays fine in PowerDVD. Extracting the LPCM audio track results in corrupted audio file. Hope you have time to take a look. Thanks ahead! |
21st December 2007, 09:28 | #2128 | Link |
Samples of 24bit Blu-ray LPCM which crash eac3to v2.10.
All files were demuxed with xport and they seem to be OK when converted to wav with sox/wavewizard. 24bit.2.0ch.Blu-ray.LPCM.sample1 http://www.sendspace.com/file/tnbe4v 24bit.2.0ch.Blu-ray.LPCM.sample2 http://www.sendspace.com/file/ett8j3 24bit.2.0ch.Blu-ray.LPCM.sample3 http://www.sendspace.com/file/5ncjkr 24bit.5.1ch.Blu-ray.LPCM http://www.sendspace.com/file/64lsvl Thank you madshi for your great effort! |
21st December 2007, 09:46 | #2130 | Link |
Ehm, normally Nero's decoder only works if you rename the exe to "recode.exe". However, eac3to has implemented a hack around this by also allowing "eac3to.exe". Renaming "eac3to.exe" to "eac3tov2.exe" disables this hack. Please don't rename "eac3to.exe".
21st December 2007, 09:48 | #2131 | Link | |
FWIW, I've yesterday converted three h264 HD DVD movies (Shooter, Transformers and Hunt for Red October) with the new eac3to and all three movies converted perfectly (apart from the one remaining libav TrueHD decoder bug). The final MKV files work great and also seeking works great. So I'm feeling safe to say that with the latest Haali filters remuxing h264 HD DVD movies works very well. So no need to demux the h264 video track to a raw file and mux it to MKV by dropping it into mkvtoolnix, anymore. eac3to uses the Haali filters instead which seem now up to the task, as far as I can say so far. I still have some problems with rewriting timestamps with Equilibrium, but I think that's not Haali's fault, but a bug in mkvtoolnix. |
21st December 2007, 10:02 | #2133 | Link | |
21st December 2007, 10:28 | #2134 | Link | |
The PCM track seems to be corrupt. Haali's splitter doesn't even offer to demux it. Sonic's splitter crashes when trying to demux it. Nero's filter demuxes the track, but it's no valid PCM data. eac3to demuxes it, too, but it's also not valid PCM data. Maybe EvoDemux corrupted the EVO while rebuilding? Please try eac3to on the original EVO files. |
21st December 2007, 12:22 | #2139 | Link |
E:\Program Files\eac3to>eac3to 101.evo f:\1.flac
EVO/VOB, 1 video track, 4 audio tracks, 1:11:52 1: VC-1 2: E-AC3, 5.1 channels, 448kbit/s, 48khz, dialnorm: -27dB, 2002ms 3: TrueHD, 5.1 channels, 48khz, dialnorm: -24dB, 2002ms 4: E-AC3, 5.1 channels, 448kbit/s, 48khz, dialnorm: -27dB, 2002ms 5: E-AC3, 5.1 channels, 448kbit/s, 48khz, dialnorm: -27dB, 2002ms Track 3 is used for destination file "1.flac". Demuxing 2nd audio track... Removing dialog normalization... Encoding FLAC... Creating/writing file "f:\1.24bit.flac"... This audio track contains only 16 bit of information. The zero bytes were successfully removed. Done. also, the new eac3to version seems to report dialnorm -24db for all truehd tracks (both in evo and demuxed) while the old ones reported -27db (even for the same tracks) |
21st December 2007, 12:31 | #2140 | Link |
Hmmmm... The delay really doesn't seem to be applied. So is the FLAC track out of sync by 2 seconds?
It would be very helpful, if you could upload a little sample of the EVO file. Maybe 50MB, if possible? Ah - thanks for reporting! That's a bug, will be fixed in next build. |
eac3to |
