Old 11th July 2018, 11:43   #6181  |  Link
RainyDog
Originally Posted by LigH View Post
Just in the same command line.
x265 --preset ... --no-slow-firstpass --ref 4 --rd 3 ...
First the "meta options" which change several parameters at once, then atomic options which override these changes.
Thanks LigH.
Yeah I do that anyway as I always make quite a few tweaks to the standard presets. But what if I want to specify --rd 3 only for the fast 1st pass but use --rd 5 for the slow 2nd pass?
My thoughts are that --rd 3 will provide a much more suitable analysis than --rd 2 for the 1st pass and use psy-rdoq.
RainyDog is offline   Reply With Quote
Old 11th July 2018, 11:51   #6182  |  Link
LigH
LigH's Avatar
Just do it; compare --rd 2 / 3 / 5 in 1st pass (and always 5 in last) among each other, tell us if you see any difference. I doubt. You will be sure afterwards.
New German Gleitz board
Old 11th July 2018, 13:37   #6183  |  Link
RainyDog
Well, I would... If I knew how to specify the --rd level and ref's in the 1st pass. That's what I was hoping you could tell me
Would it be :-
x265 --preset slow --no-slow-firstpass --pass 1 --ref 4 --rd 3(or 5) --pass 2... followed by the remainder of my manually set options.
Old 11th July 2018, 13:45   #6184  |  Link
LigH
LigH's Avatar
No. You have to complete the 1st pass before you run the 2nd.
So first, run
x265 --preset slow --pass 1 --no-slow-firstpass --ref 4 --rd 3 ...
until it finished, to produce mainly a statistics file (if it writes also a video file, then this is surely not yet optimally encoded). Then run
x265 --preset slow --pass 2 --ref 4 --rd 5 ...
and now you have your resulting video file.
Old 11th July 2018, 15:46   #6185  |  Link
IgorC
An interesting article about compression/performance ratio of x265's presets
http://x265.org/performance-energy-c...analysis-x265/
IgorC is offline   Reply With Quote
Old 11th July 2018, 21:28   #6186  |  Link
benwaggoner
So first, run
--dynamic-rd could also be an interesting feature to use in tuning quality/speed. In theory it would allow for faster encoding for easy parts of the video, only switching to higher subme etcetera for the harder bits.
Ben Waggoner
My Compression Book
Old 12th July 2018, 12:19   #6187  |  Link
jd17
Thank you for posting this.
I feel quite confirmed in my personal findings, i.e. --preset slow being the sweetspot for great quality at a still reasonable encoding speed, since the jump to slower is already immense, while the benefit to quality is practically non-existent in my eyes.
jd17 is offline   Reply With Quote
Old 12th July 2018, 12:43   #6188  |  Link
Boulder
Pig on the wing
Boulder's Avatar
There's also at least the value of --max-merge being raised in the slower presets which (at least in my opinion) affect by degrading quality. It will smooth things more --> lower bitrate.
Old 12th July 2018, 16:15   #6189  |  Link
benwaggoner
The key thing about a first pass is that it has to maintain roughly proportional rate control and similar frame/slice type decisions. If it is just 15% less efficient, no biggie. But if it’s efficiency gap varies a lot throughout the clip, than it just isn’t an accurate initial effort to refine.
So a no-slow-firstpass should focus on features that don’t have highly variable impact based on content. Things looking different is probably a good proxy for that, so if you see max-merge changing the character of the encore significantly, you’d probably want to have it st the same value in both passes.
Ben Waggoner
My Compression Book
Old 13th July 2018, 17:34   #6190  |  Link
imhh11
Hi, thanks to all the developers.
UHD-BD are encoded at level 5.1 but when I select that level, I get this warning.
Should I ignore the warning or just use 5.0 which isn't uhdbd compliant ?
Also, is there anything in my setting that I should modify in order to retain grain better?
Thank you and sorry for my English
imhh11 is offline   Reply With Quote
Old 13th July 2018, 17:54   #6191  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Better grain retention = add --no-sao and --no-strong-intra-smoothing.
Old 13th July 2018, 19:52   #6192  |  Link
imhh11
thanks, I'll try that.
EDIT. Wow its working well . still not perfect but way better than before.
http://screenshotcomparison.com/comparison/116849
http://screenshotcomparison.com/comparison/116846
http://screenshotcomparison.com/comparison/116847
and never mind about my first question, added --vbv-bufsize 160000 --vbv-maxrate 160000 and no more warning.
Old 14th July 2018, 00:56   #6193  |  Link
Capella Systems
We have implemented this in our transcoding software (Cambria FTC) on top of x265 and it works quite well - a lot of videos are mostly easy to encode and the 80/20 rule is in our favor here.
Capella Systems is offline   Reply With Quote
Old 14th July 2018, 09:56   #6194  |  Link
RainyDog
But doesn't --dynamic-rd only affect the RD level and only become applicable when VBV rate control is enabled?
Increases the RD level at points where quality drops due to VBV rate control enforcement. The number of CUs for which the RD is reconfigured is determined based on the strength. Strength 1 gives the best FPS, strength 4 gives the best SSIM. Strength 0 switches this feature off. Default: 0.
Effective for RD levels 4 and below.
Old 14th July 2018, 09:58   #6195  |  Link
Boulder
Pig on the wing
Boulder's Avatar
If you are going to watch the result on a PC or a modern HTPC/media player, I think you can safely skip specifying the decoder level and leave the VBV buffer things out. They can only lower the quality of the result.
For better quality including grain retention, I also recommend testing raising qcomp. Try values between 0.6 and 0.8. The bitrate will rise as well though.
Old 14th July 2018, 17:56   #6196  |  Link
imhh11
yes, I'm watching it on an HTPC /gtx1070.
Thank you so much for your recommendations, I'm already blown away by the difference.
Old 14th July 2018, 22:50   #6197  |  Link
uneedme
Hello Dudes,
I have tried to encode a video...
From 5 mins and on, the quality is getting worse and worse steadily(it is like auto crf downgrade). and then I split the source video into pieces and encoded them again. Every outputs are good then.
with the same params, I dont know why......
I suspect "--psy-rd 3.2" is the cause or it is a bug?......Or some wrong commands-combinations cause the chaos...
Cheers.
--crf 18.6 -m 2 --me 1 --rd 5 --rc-lookahead 120 --merange 114 --bframes 6 --ref 6 --min-keyint 23 --keyint 240 --max-merge 5 --tu-intra-depth 3 --tu-inter-depth 2 --aq-motion --qg-size 16 --no-sao --no-strong-intra-smoothing --psy-rd 3.2 --scenecut 80 --deblock -1:3 --aq-mode 2 --qcomp 0.8 --aq-strength 0.8 --colorprim bt709 --colormatrix bt709 --transfer bt709 --input-res 1862x768 --fps 24000/1001 --input-depth 10 -D 10 -o "1" --rc-grain --input -
uneedme is offline   Reply With Quote
Old 14th July 2018, 23:19   #6198  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
remove --aq-motion and try again
Old 20th July 2018, 15:36   #6199  |  Link
LigH
LigH's Avatar
x265 2.8+47-e2759ae31c36
several fixes related to HDR10+ LLC JSON and dependencies between effects of options
Old 20th July 2018, 15:40   #6200  |  Link
alex1399
I've got some 60fps video materials with wrongly encoded frame-rate which has lots of duplicated frames.
Encoding those video tends to exceed the bits per second budget.
1. remove duplicated frame
2. increase qcomp
3. set tu-inter-depth=4:tu-intra-depth=4
The 1. and 2. don't perform well, those "still" frames seems to compromised by the poorly unstable sampling rate and ghosting artifacts.
The 3. is interesting.
Instead, how to set x265 parameters to act just like a corrected frame-rate video but farther Intra-coded (I) frames and high level hierarchy Bi-directional predicted (B) frames?
alex1399 is offline   Reply With Quote
