13th January 2016, 18:02 | #35281 | Link |
Ok, so 0.92.2 gives me 3D. I have to look at the results later as it looks.....off to me. I don't know how to explain this other than the 3D looks like it's IN the TV rather than coming out of it. Is it possible the images got swapped?
13th January 2016, 18:58 | #35282 | Link |
Its not exactly well defined which 3D view is for the left and right eye. I have not seen any metadata in the MakeMKV files to indicate that, but maybe it only writes it when its non-standard?
Which disc did you rip, and can you try another? If another works, maybe upload the first ~50mb of the "wrong" MKV somewhere? (use a binary splitter like DGSplit or so)
13th January 2016, 19:00 | #35283 | Link |
I'll try again with a different disc. I used The Croods for testing. It'll probably be tomorrow before I can get back to testing with another disc.
13th January 2016, 19:54 | #35284 | Link |
thx madshi for your quick fixes!
I tried 0.90.2 but with no success. 3D is not working. MadVR crahes when trying to load a 3DMVC Mkv file. Changed my desktop resolution to 1080p on my 4k oled, and activated 3D on my Win10 (64) bit, but same crash on start. How can I provide you an error log?
Intel i5 6600, 16 GB DDR4, AMD Vega RX56 8 GB, Windows 10 x64, Kodi DS Player 17.6, MadVR (x64), LAV Filters (x64), XySubfilter .746 (x64) LG 4K OLED (65C8D), Denon X-4200 AVR, Dali Zensor 5.1 Set |
13th January 2016, 20:13 | #35285 | Link | ||
Please read the bottom part of the v0.90.2 announcement post and let me know what your Ctrl+J OSD says. |
13th January 2016, 20:38 | #35286 | Link | |
I would hope MakeMKV writes it somewhere, but I didn't see anything in my files, hence the idea if its only written on views that are not left/base, right/extension.
13th January 2016, 20:42 | #35287 | Link | |
and I'm wondering why windowed mode is on. normally I watch in exclusive mode.
13th January 2016, 21:37 | #35289 | Link | |
13th January 2016, 22:12 | #35290 | Link |
Okay, I uninstalled KCP and installed the latest x64 builds of MPC-BE, LAV and MadVR (and xysubfilter).
I do get 3D, but the depth isn't correct. It looks fine on a close-up, but as soon as you get foreground / background it's wrong. It's very obvious in Gravity, especially when they are rotating around each other in chapter 2. It might be the AMD bug though, as this is exactly what I experienced with stereoplayer. Other than that, I get lots of dropped frames & glitches if I select any error diffusion option for dithering. Ordered or random is much better. Would need a 3D Boolean to fine-tune a specific profile. I hope wrong depth isn't related to the AMD bug, but it would be interesting to try to see if those complaining of this have an AMD GPU.
Win11 Pro x64 b23H2 Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33 madVR/LAV/jRiver/MyMovies/CMC Denon X8500HA>HD Fury VRRoom>TCL 55C805K Last edited by Manni; 13th January 2016 at 22:14. |
13th January 2016, 22:13 | #35291 | Link |
Sorry for the offtopic; I'm wondering if there's any reason to update to Windos 10. I'm on a old rig(xeon x3220 ,8Gb RAM ,GTX 960 ,W 7 64bit). I'm using a 2 display configuration. MPC-HC 64 with madVR for one display and MPC-BE(LAV 32) 32bit ,with madVR and reclock for the 2nd display. I'm not interested(yet) in 3D playback. Is there any video playback quality inprovment if I upgrade to W 10?
Thanks |
13th January 2016, 22:14 | #35292 | Link |
Posts: n/a
madshi (kind of weird to type your name as the first word in a sentence without capitalizing it...),
For me, there some builds released every so often that require full and complete settings reset to defaults or otherwise there are skipped frames, presentation glitches, and such. Is that normal? Do you advice resetting settings to default for each new build? I performed a fresh format and a clean Windows 10 Pro x64 1511-10586 install. That actually got rid of a previous problem I had, where after pausing videos, there would be double-image at the top of the screen or there would be severe stuttering. |
13th January 2016, 22:24 | #35293 | Link |
Thanks for 0.90.2. Summary of issues for me:
1. NNED13 is reporting in CTRL J as jinc ar 2. 3D is working well on the single MVC mux I did. I intend to do allot more testing with other 3d blurays cos Im concerned about the point made in this thread with makemkv loosing important 3d config data in the mux with left/right eye formats and so on. 3. I continue to have crashes when changing modes automatically between 2d and 3d, and I continue to have crashes when playing 2d content in a 2d desktop when having 3d stereoscopic mode enabled in the nvidia driver settings. I have now resolved my windows component store corruption. Clearly nvidia has problems in their code, the error dumps point to NV dlls as the cause. In the meantime the workaround is to manually swap between 3d and 2d desktop modes as needed, and manually enable or disable the 3d stereoscopic tick box. |
13th January 2016, 23:36 | #35296 | Link |
Many thanks mate. Reinstalling the nvidia drivers now enables NNED13 correctly. Seems the combination of the dism repairs to fix windows component store corruption and the new hotfix driver from nvidia caused it to get into some trouble. All fixed top suggestion thanks again.
13th January 2016, 23:51 | #35297 | Link | |||||
Oh well, then I don't know why it's not working for you. It seems to be a problem with the GPU drivers (?). You could try reinstalling those, or try a different version.
14th January 2016, 00:29 | #35299 | Link | |
- Is it only AMD users who complain about this re 3D with LAV+MadVR? - Has any AMD owner managed to get 3D to work with LAV+MadVR without the perspective/eye reverse AMD Bug? - If any AMD user managed to get 3D to work properly, are they using Catalyst or Crimson drivers?
Win11 Pro x64 b23H2 Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33 madVR/LAV/jRiver/MyMovies/CMC Denon X8500HA>HD Fury VRRoom>TCL 55C805K |
14th January 2016, 00:44 | #35300 | Link |
madVR doesn't activate the correct interlacing mode (film) for PAL sample and switches to 50 Hz with default deinterlacing settings (+ LAV's YADIF disabled + ReClock's PAL speed down enabled).
Windows 8.1 x64 Magically yours Raistlin |
