Old 17th March 2006, 00:17   #161  |  Link
dimzon
BeHappy/MeGUI developer
dimzon's Avatar
Ok, second name for this Effect is Wavesharper
There are big amount of such formulas
http://musicdsp.org/archive.php?classid=4#207
http://www.google.com/search?lr=&ie=...8&q=Waveshaper
and finally found good approximation
http://img217.imageshack.us/img217/1803/testnew6pc.png
yellow is tera
pink is .55 * Math.Atan(6*x)
dimzon is offline   Reply With Quote
Old 18th March 2006, 12:17   #162  |  Link
sasam
Registhreaded User
Hi dimzon,
That's a nice logo for behappy you have, looking like Google...
What do you think about this:
sasam is offline   Reply With Quote
Old 18th March 2006, 12:21   #163  |  Link
tebasuna51
tebasuna51's Avatar
About new Bass_ac3.dll
I don't know if you need make some modification to use with BeHappy, but a simple dll replace produce this wav output:
- Ac3 2.0: ok now
- Ac3 5.0: wrong channelmapping C_SL_FR_FL_SR_e (empty)
- Ac3 5.1: same wrong channelmapping C_SL_FR_FL_SR_e (empty), LFE missing.
I know bass_ac3 is not necessary for BeHappy (you have NicAudio), but bass_aac is really interesting and I hope maresweb developers can help us.
Old 23rd March 2006, 11:43   #164  |  Link
dimzon
dimzon's Avatar
Fine news
BeHappy in TOP 5 @ GotDontNet !
http://www.gotdotnet.com/workspaces/directory.aspx
Congratulations
Old 23rd March 2006, 12:02   #165  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Congratulations to you dimzon and rockaria for very good app
shon3i is offline   Reply With Quote
Old 23rd March 2006, 12:15   #166  |  Link
3dsnar
3dsnar's Avatar
Congrats!!
Keep up the good work!
Aud-X MP3 5.1 Format
3dsnar is offline   Reply With Quote
Old 25th March 2006, 03:51   #167  |  Link
mxms
My appologies, I'm new to this thing but here is what I'm trying to do.
I have a 5.1 AAC file I converted to WAVE in 6 channels. I'm now trying to use BeHappy to conver from WAVE - AC3. Which when I try I get:
Starting job Track2.wav->Track2.ac3
Found Audio Stream
Channels=6, BitsPerSample=16, SampleRate=48000Hz
ffmpeg.exe -i - -y -acodec ac3 -ab 448 "C:\Documents and Settings\Nick\Desktop\ergo2\Track2.ac3"
Error: System.ApplicationException: Can't start encoder: The system cannot find the file specified ---> System.ComponentModel.Win32Exception: The system cannot find the file specified
at System.Diagnostics.Process.StartWithCreateProcess(ProcessStartInfo startInfo)
at System.Diagnostics.Process.Start()
What does it mean "The system cannot find the file specified ---> System.ComponentModel.Win32Exception" and how do I fix it?
What do I need to get this working properly?
mxms is offline   Reply With Quote
Old 25th March 2006, 10:31   #168  |  Link
tebasuna51
tebasuna51's Avatar
Maybe you need the encoder
ffmpeg
uncompressed in BeHappy folder.
Old 29th March 2006, 09:06   #169  |  Link
dimzon
dimzon's Avatar
future plans
future plans
Hi!
Since BeHappy is experimental application I decide to perform some experiments.
I'm planning to perform complete GUI redesign using Inductive UI paradigm
I'm planning to use HTMLayout to create multilanguage skinable UI
I'm planning to use TIScript (JavaScript-like) to provide ability to create more complex and flexible extensions
Old 29th March 2006, 14:53   #170  |  Link
dimzon
dimzon's Avatar
Ok, new GUI layout prototype is here
http://www.mytempdir.com/553286
please, post your comments and suggestions
Old 29th March 2006, 15:25   #171  |  Link
sasam
Registhreaded User
It looks nice, but there is nothing wrong the old one. This one looks like some newbie "1click encoder".
In the old one we can see all in one screen and in the new one we have to click on the task to open it.
New users would probably love the new interface but I don't know about experienced...
Old 29th March 2006, 15:38   #172  |  Link
3dsnar
3dsnar's Avatar
I like it.
Very good for new users indeed.
Experienced users know already how to use it,
so it should not discourage them to continue using this app.
Old 29th March 2006, 15:43   #173  |  Link
dimzon
dimzon's Avatar
As I said before I'm planning to make BeHappy skinable - there will be special skin wich will look & feel mostly like current BeHappy
Unfortunally I'm not a designer so I need feedback & suggestions.
Please, post here Your ideas, draft design and sketches - everything are welcome
Let's create ultimate easy-to-use interface together.
Old 29th March 2006, 16:32   #174  |  Link
sasam
Registhreaded User
Here is a fast sketch I made... What do you think?
Old 29th March 2006, 16:36   #175  |  Link
dimzon
dimzon's Avatar
Thanx for participation.
Unfortunally Queue is too narrow - there are many columns in Queue list. I believe we must make Queue 100% width...
And do not forget - we need some place for progress bar and log...
Old 29th March 2006, 16:50   #176  |  Link
sasam
Registhreaded User
Maybe you could put expand button or something :
Users don't have to see all columns...(Only when they click expand button) As you said it is supposed to be for easy using.
Old 29th March 2006, 16:53   #177  |  Link
dimzon
dimzon's Avatar
Hmmm... Looks better.
So let's wait a little, maybe somebody provide another sketches...
Old 29th March 2006, 17:19   #178  |  Link
dimzon
dimzon's Avatar
Just addition - current BeHappy implementation opens Decoder/DSP/Encoder configuration in modal dialog
In new UI layout I want to place it @ main form to avoid ModalDialogs
Old 29th March 2006, 17:57   #179  |  Link
dimzon
dimzon's Avatar
Queue
Old 29th March 2006, 18:39   #180  |  Link
stax76
stax76's Avatar
How about a side bar like in so many MS UIs (e.g. 'Windows Movie Maker'), this gives you much more room.
behappy
