1st February 2018, 18:37 | #48761 | Link |
anyone else getting block corruption when skipping through a movie using D3D11? May just affect AMD RX models though or just me. I have had this issue before and quite badly, early driver versions for my RX480 had this problem for months before getting fixed.
No issues with copy back though which is why i'm still using that. |
1st February 2018, 19:21 | #48764 | Link |
You want D3D11 DXVA if you use DXVA at all. madVR needs decoded video to start with but it likes software decoding or copyback more than native. None of those PopPlayer options mention native or copyback, I don't know what PotPlayer is doing.
madVR options explained |
1st February 2018, 20:56 | #48765 | Link | |
Suspended for forum rule violations
Using a Nvidia GeForce GTX 960 4GB on 2 2560x1440 displays and a Panasonic TV 1080p 1920x1060. Windows 7. I'll try these new settings and see what results I get. -------------------------- From PotPlayer settings: Filters --> Use Built-in DXVA Video Decoder Manage Filters --> Built-in codec/DXVA settings --> Hardware acceleration (DXVA) settings --> Use DXVA --> Use D3D11 DXVA first DXVA2 Copyback: D3D9: Auto -------------------------- |
1st February 2018, 22:16 | #48766 | Link | ||
Anyone explain why DXVA copy-back loses tons of frames and has pretty bad stutter with 4k (frame rate is correct)? Last edited by -Hitman-; 1st February 2018 at 22:19. |
1st February 2018, 22:35 | #48768 | Link |
[QUOTE=-Hitman-;1832532]Hi, I've found a serious banding issue (scenes with white clouds show a pink posterization/banding effect) with UHD HDR movies, /QUOTE]
No banding here for me, ive checked that particular scene on both the full HDR remux and the SDr conversion that are knocking about on torrents, neither shows anything in that scene for me. Was this defo a full remux you were viewing?, are you passing HDR through to your TV or converting in MAVR? WIn10 RX550 copyback or D3D11 4k 4:2:0 - havent tried 4:4:4 full RGB. |
1st February 2018, 23:24 | #48769 | Link |
Copyback needs to copy the entire raw video data from GPU memory space to CPU memory space and Intel's iGPUs don't have very much memory bandwidth, 10 bit 4Kp60 is 14.93 Gbps (~1.9GB/s). 128 bit (dual channel) DDR4 2400 is only around 35 GB/s. Even the 2GB 1050 has 112 GB/s and PCIe 3.0 x16 has 15.8 GB/s.
madVR options explained Last edited by Asmodian; 1st February 2018 at 23:40. |
2nd February 2018, 00:56 | #48771 | Link |
I am not sure AMD is free from problems, but I think you are correct when using with 8-bit video. Also, the poster had an Nvidia GPU and the quote was from a reply to someone with an Intel GPU probably playing 10-bit HEVC.
madVR options explained Last edited by Asmodian; 2nd February 2018 at 01:06. |
2nd February 2018, 15:45 | #48775 | Link |
Hi madshi, I have a question about a note in the config GUI: next to "measure each frame's peak luminance" for HDR, it says: "(Does not work with DXVA scaling / decoding)". Is that still valid?
I'm using DXVA11 Native decoding for 2160p, and if I enable ShowRenderSteps, it does show a step 'measure peak luminance'. Who's right, the config GUI or the OSD?
HTPC: Windows 10 22H2, MediaPortal 1, LAV Filters/ReClock/madVR. DVB-C TV, Panasonic GT60, Denon 2310, Core 2 Duo E7400 oc'd, GeForce 1050 Ti 536.40 |
2nd February 2018, 19:27 | #48778 | Link | ||
Yes, well below 5% on most cores.
3rd February 2018, 04:45 | #48779 | Link |
Is the method to using madVR to take a screenshot dependent on the media player? I'm using Alt + I (which is the default shortcut) on mpc-be, is this the correct way?
I have a 4k HDR REC. 2020 file and saving 200% view as png crashes. It works with bmp. Saving 300% view as bmp just maxes out my memory (16GB), then drops to 100MB and madVR crashes saying it can't write to a certain address. Obviously 3x 4k is dumb but should it work? |
3rd February 2018, 15:31 | #48780 | Link |
Hi Madshi,
re: down-converting 4k (10 bit) video to 1080 (10 bit) can you plz comment if your program converts 4k 4.2.0 YUV (10 bit ) to 4k 4.4.4 RGB before downscaling it to 1080 10bit RGB ? (eg doing the RGB conversion first while still in 4k ). the purpose would be to maintain a larger part of the much higher chroma and luma information from the 4k file (@ 4.2.0 YUV in 4k ) in the conversion process to 1080p video (@ 4.4.4 RGB) if yes, do i need to use any specific settings in madvr to ensure this occurs correctly ? (other then setting my ati control panel to output RGB 4.4.4 over the HDMI video output to my display). Last edited by zapatista; 3rd February 2018 at 19:53. Reason: name spelling |
