15th June 2007, 08:48 | #302 | Link |
Hi....not sure if this will be useful re MKV direct input...but seems as though it might be of use?.....
http://www.zju.edu.cn/jzus/2006/A06S1/A06S113.pdf Let me know if it helps Kevin Last edited by oldpainless; 15th June 2007 at 09:08. |
15th June 2007, 14:30 | #303 | Link | |
Fixed in 0.0.15. The size issues was due to the fact that I originally had 1:1 correspondance between SCR and PCR. I now create PCRs from SCRs close to the 1/10 of a sec optimal. New version 0.0.15 only contains VOB/EVO -> TS/M2TS/Blu-Ray fixes. Last edited by dmz01; 15th June 2007 at 14:54. |
15th June 2007, 14:53 | #304 | Link | |
Life's clearer in 4K UHD
I've just tried v0.0.15 with the .VOB sample I provided and I'm still obtaining in-correct playtime and bit-rate properties Cheers
15th June 2007, 15:17 | #305 | Link |
Size fix seems to be ok, but I still get problems with audio. In original VOB they are ok (can demux them to elementary stream). In TS they seem to be corrupted somehow, cause when I try to demux them to ES I only get m2v file. Subtitles also don't work for me...
15th June 2007, 15:40 | #306 | Link | |
EDIT: I tried the Manzanita TS Analyzer and it confirmed the length and bit-rate to be correct. I would trust that over your tool. Last edited by dmz01; 15th June 2007 at 15:51. |
15th June 2007, 15:42 | #307 | Link | |
EDIT: I figured out what the audio issue is. Blu-Ray format requires the stream type of the DD audio to be "extended_stream_id" or 0xFD. In the past DD stream type was set to 0xBD or "private_stream_1". Players not compatible with new blu-ray format will most likely not be able to play TS files coming form Blu-Ray or TsRemux. The same applies to the various TS splitters like haali etc. Last edited by dmz01; 15th June 2007 at 16:00. |
15th June 2007, 16:09 | #308 | Link | |
With the "VOB source" MediaInfo reports this: - And with "TSremux 0.0.15" MediaInfo reports this: - From what I can determine MediaInfo appears to be quite accurate with other .TS (captured) sources.... Hope that helps.
15th June 2007, 17:24 | #310 | Link |
Hmmm... that's a good point.
I've been testing TSremux for generating .TS files for use/compatibility with high-def hardware playback devices, like the ones mentioned here. All .TS files are stored on HDD's and served to the afore mentioned devices via an ethernet connection.
15th June 2007, 23:08 | #311 | Link | |
16th June 2007, 11:25 | #312 | Link | |
Kevin |
16th June 2007, 11:47 | #314 | Link |
Thanks for this program, keep up the good work. Still got a problem though, can take an evo file from a HD-dvd, get it to create a bdmv folder from the vc-1 and dd+ stream, plays back fine in powerdvd but plays back slow and jerky off blu-ray disc on a PS3. PS3 reports vc-1 for video, and Dolby digital multi-channel 48khz 112kbps for the audio
16th June 2007, 14:32 | #315 | Link | |
16th June 2007, 15:03 | #316 | Link | |
16th June 2007, 16:01 | #319 | Link |
dmz01, there was talk earlier of adding muxer capabilities to TsRemux. I bumped into a file (AVC) which has DD2.0 audio, but I also have a synched dts audio for the movie. It would be really nice to drop the movie and the dts track into TsRemux, disable the DD2.0 audio and have TsRemux create a muxed .ts with dts audio.
16th June 2007, 17:33 | #320 | Link | |
