16th August 2008, 16:16 | #5781 | Link | |
16th August 2008, 17:18 | #5782 | Link | |
too much lurking
Has anyone here tried working with Harold And Kumar Escape From Guantanamo Bay? It's a nightmare! There are over a dozen title sets to choose from. Apparently there is a feature in this disk that interactively allows you to change the plot at different scenes.
High-Def Digest: http://bluray.highdefdigest.com/1173...marescape.html Quote:
Edit: I think that this movie actually can't be backed up without keeping the entire disk intact. It seems as though every title set has these "dude, change the movie" screens in them where the movie is paused for several moments allotting the viewer the time to decide if they in fact want to change the movie. Nightmare. Last edited by saint-francis; 16th August 2008 at 17:26. |
16th August 2008, 18:04 | #5783 | Link |
Something strange - I downloaded the latest version of eac3to last night form the link on the first page, and my antivirus (ZoneAlarm Security Suite) is now saying that there is something fishy with the hooksurcode.dll and there is an infection (Backdoor.Win32.Hupigon.dgde) so I cant extract the contents of the rar file without it quarantining the hooksurcode.dll file
Has anyone else found this? I've never had a problem before and I seriously doubt this is something Madshi has done Kind of annoying though having to close ZoneAlarm Anyway - big thanks to Madshi, eac3to just keeps getting better and better |
16th August 2008, 18:25 | #5784 | Link |
Kaspersky flags that also. IIRC, ZoneAlarm includes Kaspersky as its AV. I haven't updated my eac3to in a few weeks, so it must be a new addition to the av definitions file.
I added that file (without the path) to my trusted zone. I CAN TRUST IT, RIGHT??!!! |
16th August 2008, 18:39 | #5787 | Link | ||
My target is mkv (h264/vc1) & dts & flac but I can't get vc1 from m2ts into the mkv correctly. They all result in stuttering, stalling and an inability to seek or fast forward. Quote:
BTW, what splitter/decoder are you using? I test my files with gabest & haali splitters, mplayer-hc, coreavc and the microsoft decoders. Nothing works. |
16th August 2008, 18:48 | #5788 | Link |
too much lurking
Nod is one of the more sophisticated AV tools. If you must use one nod is a good choice. Symantec seems to be good too. Many of them just throw up false positives when they encounter something they don't understand.
16th August 2008, 18:58 | #5789 | Link |
I ask out of fear that something will happen to prevent future updates and improvements. DvdDecrypter was killed by industry, tsMuxer looks abandoned by roman for now, and mommyman has just quit DVDAExplorer. The last was opensourced, so I've got hope that it can be finalized by someone else. Also some developers need a break, have children, go into the military, etc., and if it is open source someone else can pick it up.
Your expertise and time have made eac3to the most valuable program that I use, and I appreciate all that you do. I won't bring this up again. |
16th August 2008, 20:03 | #5790 | Link | |
But eac3to is unlikely to have the same fate as DVDecrypter, because it doesn't actually get movies from your disc, it doesn't strip any drm. eac3to is in the clear, the same way as the burning engine of DVDecryper was in the clear and went on after DVDecrypter got shut down and is now ImgBurn. On the subject of ImgBurn, that app is awesome enough that I haven't bothered installing the bundled pile of garbage that is Nero suit. So madshi, how should we interpret that note about ArcSoft ac3 and TrueHD decoders? It says "not yet", but will it be supported? Is there any quality concern you have with ArcSoft's Dolby support (like range compression/etc) or something else? Now that I've got arcsoft going, I'm kind of eager to get it to be my all-in-one decoder.
Geforce GTX 260 Windows 7, 64bit, Core i7 MPC-HC, Foobar2000 Last edited by lexor; 16th August 2008 at 20:32. |
16th August 2008, 20:30 | #5791 | Link |
too much lurking
Look at MeGUI. Doom9 started it and now it's still pretty well maintained by other people and he isn't involved with it's development at all as far as I can tell. If some OSS is really desired and the developer stops working on it, from time to time others do take it on. FFDShow is another great example.
16th August 2008, 21:43 | #5792 | Link |
too much lurking
I found the proper, plain old normal movie in the Harold and Kumar BD. It's title set # 10 for anyone who comes after me. And yes, I remuxed the 9 previous title sets before I finally figured it out. Took me about 4 hours. :shakeshead:
16th August 2008, 21:58 | #5793 | Link | ||
Ok, I could add an undocumented option which outputs one extra line with a progress number for each percent increase. That should make it easy for you to grab the progress.
I've not much motivation to support the ArcSoft TrueHD decoder since the free libav TrueHD decoder seems to work perfectly. I might support the ArcSoft (E-)AC3 decoder sooner or later. But adding support for the ArcSoft decoders is rather painful compared to e.g. Nero. That's why I'm only supporting the most important one (DTS) right now. |
16th August 2008, 22:34 | #5794 | Link | |
17th August 2008, 04:00 | #5795 | Link |
@Madshi
1. If the Source File has audio delay in it // will it be automatically applied in Output?? 2. I was testing a sample "hxxp://www.sendspace.com/file/cr48oe". When i demux Video Stream, it's 107,163,504 and when mux it to MKV container with Eac3to it's 107,136,569. Meaning it's 26,935 byte less than original raw stream. Can you please guide where i'm not getting. Regards, Sehgal Last edited by sehgal.v7; 17th August 2008 at 04:47. |
18th August 2008, 03:12 | #5797 | Link |
What are the requirements for eac3to to detect a folder as a Blu-ray? I know for HD DVDs its VPLST000.XPL (and then HVA00001.VTI), but that doesn't really apply here.
Edit: Nevermind now, Process Monitor has the answer. Last edited by Snowknight26; 18th August 2008 at 03:19. |
18th August 2008, 15:56 | #5799 | Link | |
What would that be good for? TsMuxer doesn't properly mux TrueHD tracks, anyway. |
eac3to |
