Old 16th February 2021, 21:16   #1  |  Link
For Fun
Aegisub doesn't read characters?
İt doesn't read "-" it replaces with á€"
How can ı make it read "-" ?
I'm getting this error "error loading file, one or more characters in the input string were not valid characters in the given input encoding"
For Fun is offline   Reply With Quote
Old 18th February 2021, 01:56   #2  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
İ <- out of curiosity: which codepage are you using ?
You might want to convert your subtitle encoding to UTF-8:
notepad++ will do that for you.
Aegisub will ask on opening and suggest two or more interpretations, you decide.
Old 28th February 2021, 13:47   #3  |  Link
For Fun
Thank you for your help that is what I figured out later.
aegisub, subtitle
