Old 4th May 2018, 15:55   #50641  |  Link
oldpainlesskodi
Originally Posted by x7007 View Post
What about the LG OLED TV's ? B6 , C6
for HDR you need to choose Game Console/HDMI instead PC Input , And choose HDR Standard Picture mode
what is GL ?
Sorry I don't have an LG.
I have no idea what GL means.
Sapphire RX 5700 XT (19.9.2) Ryzen 7 3700x, PRIME X570-Pro, Win 10 x64 (1903), Silverstone LC13B-E, Onkyo TX-NR686, Samsung UE55KS8000, Mission M35i speakers, Kodi Dsplayer 17.6 X64
oldpainlesskodi is offline   Reply With Quote
Old 4th May 2018, 16:20   #50642  |  Link
GL=good luck
Old 4th May 2018, 17:06   #50643  |  Link
x7007
So which mode should I use ?
Windows HDR Enabled + Madvr 10bit + HDR Passthrough + TV GameConsole/HDMI Input + Full Windowed or FSE ?
Windows HDR Disable + " + " " + " " + Full Windowed or FSE ?
Because Windows HDR gives 8 bit + Dithering in Windowed and maybe FSE I think, and MadVR gives 8 bit when Full Windowed mode.
So which is the best choice ?
Would I notice any quality differences between 8bit Windows HDR and Madvr 8 bit Nvidia ? and also differences in MadvR 10 bit FSE ?
x7007 is offline   Reply With Quote
Old 4th May 2018, 17:30   #50644  |  Link
Warner306
It is unknown what Windows does to the image, but the images should be identical between the two.
The best set up is to use the Nvidia private API (passthrough - send metadata), so you don't have to toggle HDR on and off. This is clearly most convenient.
To get 10-bit passthrough, you must enable fullscreen exclusive mode until there is a fix a the driver level for banding with 10-bit HDR passthrough when set to windowed mode. SDR playback is unaffected by this bug.
Old 4th May 2018, 17:31   #50645  |  Link
oldpainlesskodi
Windows HDR Disable + " + " " + " " + FSE
Edit - looks like Warner306 and I commented at the same time
Old 4th May 2018, 17:36   #50646  |  Link
x7007
Ok thanks . FSE is so annoying, takes ages until the images start to play when going in FSE. out is ok
Old 4th May 2018, 18:54   #50647  |  Link
truexfan81
truexfan81's Avatar
whats going on here?
evga 1050ti fw latest nvidia driver, windows 10 1803 madvr 0.92.10
any idea whats going on here?
thanks
truexfan81 is offline   Reply With Quote
Old 4th May 2018, 18:55   #50648  |  Link
Asmodian
Try small buffers, I like 6 for GPU buffers and 4 fames presented in advance. I have noticed that smaller buffers perform better than giant ones.
Also, it looks like you are not using the default flush and wait options? Put those back to the defaults.
Can you actually see any difference with 10 bit compared to 8 bit? I simply use 8 bit all the time, 10 bit is very unimportant for madVR's video out. Dithering FTW.
madVR options explained
Old 4th May 2018, 19:04   #50649  |  Link
truexfan81
truexfan81's Avatar
edit: I got it, had to add another profile for my image enhancements to turn them off for 50/60fps videos.
Old 4th May 2018, 19:31   #50650  |  Link
Asmodian
The reason this wasn't immediately obvious when looking at the OSD was because you turned off all the "wait" options in the "when and how shall the GPU be flushed:" section of windowed mode, "after the last render step" should be one of the wait options so madVR can report rendering times.
Old 4th May 2018, 21:45   #50651  |  Link
Ver Greeneyes
I'm having the same issue, I think Windows 10 1803 changed something that broke windowed mode. Using FSE mode is the only workaround I've found.
Old 4th May 2018, 23:00   #50652  |  Link
iakoboss7
iakoboss7's Avatar
hello, anyone noticed reduced average rendering time with the new windows 10 update?
in files where i got ~10ms now i get ~5ms. playback is perfect as always.
am i the only one? i didnt find any mention in the last 10 pages.
rx 480 with latest drivers.
also about the low (0-1) queues many have (alongside dropped frames), the culprit is freesync.
when i disable it everything is fine. its not windows fault. this started with the last madvr versions.
also reclock doesnt work that well at the same time...
iakoboss7 is offline   Reply With Quote
Old 4th May 2018, 23:48   #50653  |  Link
Betroz
Is this for real?
Betroz's Avatar
Not for me. I have this problem, and it's not that. I use an old plasma TV from Panasonic, so no freesync there
Also the queues fill up nicely with an older version av MadVr with NNEDI3 128 settings. Even with queue size of 24.
My HTPC : i7 6900K @ 4.2 | nVidia GTX 1080Ti | TV : Samsung 75Q9FN QLED
Betroz is offline   Reply With Quote
Old 4th May 2018, 23:54   #50654  |  Link
cyberscott
what is GL ?
I own a LG C6. I can play HDR videos perfectly fine with the C6 set to PC Input. I can also play HDR compatible PC games in the same mode.
I mainly use my C6 as a big monitor.
cyberscott is offline   Reply With Quote
Old 5th May 2018, 00:05   #50655  |  Link
FDisk80
Originally Posted by Magik Mark View Post
How about custom refresh rate?
Sent from my iPhone using Tapatalk
Nope, still busted with 397.55.
madVR gives this error when trying to apply custom timings.
FDisk80 is offline   Reply With Quote
Old 5th May 2018, 00:22   #50656  |  Link
Manni
Is this still with 1080p?
Do you also get this error if you select EDID/CTA? That's the only option that works for me with my JVC PJ, and it gives me 1+ hour of drop free playback (with 4K/UHD though, I haven't tested 1080p). I haven't tried the latest driver, but it worked with all the former ones (which you reported as not working as well).
Win10 Pro x64 b1903 MCE
i7 3770K@4.0Ghz 16Gb@2.18Ghz EVGA GTX 1080 Ti SC2 11Gb@2GHz 436.48 RGB Full 8bits
MPC-BE/LAV/MadVR/jRiver/MyMovies V5.25
Denon X8500H>HD Fury Maestro>JVC RS2000
Manni is online now   Reply With Quote
Old 5th May 2018, 00:25   #50657  |  Link
Ver Greeneyes
Hmm, good point. I checked the repository of old versions and the last version in which the queues fill is v0.91.5. In v0.91.6 and newer the queues no longer fill.
However, even in v0.91.5 the queues only fill up to 5-7/15 for me. I'm also fairly sure the regression itself is caused by the update to Windows 10, even if older versions of madVR managed to avoid it.
Edit: Aha, NGU seems to be the culprit somehow. v0.91.6 introduced NGU Anti-Alias, which I was using for chroma upscaling. If I enable NGU for chroma upscaling in v0.91.5 the queues stop filling, even if I select the "low" quality option which gives me an average rendering time of 4.5ms.
Edit2: Yes, going back to v0.92.14 if I set chroma upscaling to Bicubic60 I get 5-7/15 like in v0.91.5. If I use super-xbr I get 2-4/15 (even though the rendering time is practically unchanged at 3.5ms) and if I select NGU I get 0-2/15 and it starts dropping frames. Is it running into some sort of windowed mode GPU memory usage limit or something??
Old 5th May 2018, 01:24   #50658  |  Link
Asmodian
You can use HDR in PC mode but, on the C7 at least, the gamut coverage is much worse. Home theater or similar offers better HDR rendering but also uses 4:2:2 color subsampling.
Old 5th May 2018, 01:29   #50659  |  Link
mlauzon
I keep hearing about MadVR, but have no idea how to use it, can someone ELI5 please & thank you..?!
Michael
mlauzon is offline   Reply With Quote
Old 5th May 2018, 01:34   #50660  |  Link
FDisk80
Yes, this is a 1080P HDTV.
I can't even apply EDID/CTA, the test button is grayed out because those are already the timing that are being used by default when switching to 1080P@23hz mode.
But it's not optimal. Those timings result in 23.977hz and there is a frame repeat every 2 or 3 minutes.
