10th October 2016, 11:35 | #2281 | Link | |
Professional Code Monkey
10th October 2016, 11:50 | #2282 | Link |
Reported and my 5 sec samples are available.
https://github.com/FFMS/ffms2/issues/273 |
10th October 2016, 15:05 | #2283 | Link | |
10th October 2016, 15:39 | #2284 | Link | |
Anyway, in the latest dev build (on my form or in my pull request of the main MT branch) you can strip alpha from avisynth+ by RemoveAlphaPlane, so it's good if e.g. YUVA444P10 is returned. |
10th October 2016, 15:42 | #2285 | Link | |
I've added alpha support now so just a bit of testing to see if it fixes your clip and then a new build.
10th October 2016, 15:56 | #2286 | Link |
Here's another 2.23 RC!
It adds support for all alpha formats in avs+ as well. TEST HARDERRRRRRRRRRRRR!!!!!!1111
10th October 2016, 16:10 | #2287 | Link |
Great! It shows YUVA444P10.
For the earlier test you mentioned that avisynth's rgb32 was chosen as the nearest matching format, having alpha plane. Since the source was 10 bits, was it intentional choosing RGB32 instead of RGB64? |
10th October 2016, 16:13 | #2288 | Link | |
All possible output formats are in the source here.
18th October 2016, 18:30 | #2289 | Link |
2.23 has been released. Everyone should update since it fixes stuff. Except for you XP users. HAHAHAHAHAHAHAHAHA
18th October 2016, 20:40 | #2291 | Link |
Fixed binaries will be up soon. The x64 version still works though.
18th October 2016, 21:13 | #2292 | Link |
Fixed binaries have been uploaded.
19th October 2016, 01:01 | #2293 | Link | |
Broadcast Encoder
@myrsloik...
19th October 2016, 04:39 | #2295 | Link | |
20th October 2016, 00:38 | #2298 | Link |
Broadcast Encoder
FFMS2 v 2.23 - Windows XP
Link removed Yep, it's working! There are several dlls you'll need to put in your plugin folder because FFMS2 uses some APIs that are not natively available in XP. (you may get some "weird" error at the startup, but it's just a warning, it will load) Dlls are x86 only. Enjoy! Last edited by FranceBB; 20th October 2016 at 07:46. |
20th October 2016, 01:05 | #2299 | Link |
I test the one from https://github.com/FFMS/ffms2/releases with winxp in VM and work!
maybe Myrsloik joking!
See My Avisynth Stuff |
20th October 2016, 01:06 | #2300 | Link |
FFMS2 C-plugin 1140+101
Optimized for Pentium-III and SSE (32-bit) Optimized for Core2 (64-bit) ffmpeg version r82048 git-dfe7e55 Copyright (c) 2000-2016 the FFmpeg developers built with gcc 6.2.0 (GCC) libavutil 55. 32.100 / 55. 32.100 libavcodec 57. 63.103 / 57. 63.103 libavformat 57. 52.100 / 57. 52.100 libavfilter 6. 64.100 / 6. 64.100 libavresample 3. 0. 0 / 3. 0. 0 libswscale 4. 1.100 / 4. 1.100 libswresample 2. 2.100 / 2. 2.100 libpostproc 54. 0.100 / 54. 0.100 32-bit configuration: Code:
--prefix=/home/qyot27/win32_build --cross-prefix=i686-w64-mingw32- --enable-gpl --enable-version3 --disable-w32threads --enable-avresample --disable-encoders --disable-muxers --disable-doc --disable-debug --disable-devices --disable-avdevice --cpu=pentium3 --extra-cflags='-mfpmath=sse -march=pentium3 -msse -mtune=pentium3' --target-os=mingw32 --arch=x86 Code:
--prefix=/home/qyot27/win64_build --cross-prefix=x86_64-w64-mingw32- --enable-gpl --enable-version3 --disable-w32threads --enable-avresample --disable-encoders --disable-muxers --disable-doc --disable-debug --disable-devices --disable-avdevice --cpu=core2 --extra-cflags='-march=core2' --target-os=mingw32 --arch=x86_64 |
