8th October 2014, 06:04 | #101 | Link |
I have an odd problem, no matter how big or small I resize the gMKVExtract window the description next to the action buttons overlap almost making them unreadable.
SONY 75" Full array 200Hz LED TV Yamaha A1070 amp Zidoo UHD3000, Popcorn Hour A-500 BeyonWiz PVR T3 & V2 (Enigma2 clone) Chromecast Pioneer Bluray BDP-150-K Windows 7 Ultimate QNAP NAS TS851 |
8th October 2014, 10:26 | #103 | Link |
Hi gp2, regarding to the GUI issue, I guess r56 on SF is supposed to fix the issue, but if my build attempt succeeds, the problem is still there.
And I'm sorry that I should have mentioned that I am on Windows 7 with classic theme. In my tests, there's no such problem in the typical Win 7 aero theme (before or after r56). Win XP (classic theme and default Lunar theme) is also affected. Hope the info helps. |
8th October 2014, 11:12 | #104 | Link | |
The image is here The version of gMKV is the latest and my operating system is Windows 7 Ultimate 32 bit I've had this problem for quite sometime with all the updates of gMKV and all the Windows updates Thanks
SONY 75" Full array 200Hz LED TV Yamaha A1070 amp Zidoo UHD3000, Popcorn Hour A-500 BeyonWiz PVR T3 & V2 (Enigma2 clone) Chromecast Pioneer Bluray BDP-150-K Windows 7 Ultimate QNAP NAS TS851 Last edited by netmask; 8th October 2014 at 11:45. |
8th October 2014, 20:19 | #105 | Link | |
gMKVExtractGUI author
@netmask The larger font scheme you are using is messing with the control sizes and location. I switched to DPI AutoScaleMode, but I don't know if it will fix your problem, since it seems it's a known .NET issue (http://stackoverflow.com/a/3043006) I'll try to reposition the controls in order to prevent this from happening, in case the DPI AutoScale mode doesn't work. |
8th October 2014, 21:32 | #106 | Link | |
SONY 75" Full array 200Hz LED TV Yamaha A1070 amp Zidoo UHD3000, Popcorn Hour A-500 BeyonWiz PVR T3 & V2 (Enigma2 clone) Chromecast Pioneer Bluray BDP-150-K Windows 7 Ultimate QNAP NAS TS851 Last edited by netmask; 8th October 2014 at 23:25. |
9th October 2014, 05:03 | #107 | Link |
r60 is still no good.
Here's a screenshot, after opening and resizing the log window: update: The problem is partially fixed. With 1.5.5, the track list part is also affected. r56 and r60 are similar, only the file info part is affected. Last edited by bin_ch; 9th October 2014 at 05:11. |
9th October 2014, 06:45 | #108 | Link |
Oh, I see. I didn't understand that you were also experiencing issues with the info text. I did make some changes with it, but it performed really smooth in Window 8.1.
I guess I'll change back that control too and try to find a more robust solution for the flickering. Thanks a lot for testing and feedback! |
12th October 2014, 18:23 | #109 | Link |
New version is out (v1.6) and I'm so excited about it!
It introduces a new job mode and a new Job Manager form, basically this is how I imagined a batch mode should work. I'm really looking forward to hearing (actually reading) your feedback and your suggestions about it! http://sourceforge.net/projects/gmkv....0.7z/download |
12th October 2014, 22:19 | #110 | Link |
Looking good, no overlap of description now. Will do some extraction tests later today.... many thanks
17th October 2014, 00:33 | #112 | Link |
Regarding to the batch mode, do you have plans to implement a feature that can open multiple files at once? (Or batch add jobs to the queue)
That would be useful when people want to extract something from a series of files with similar track combination. |
17th October 2014, 06:46 | #113 | Link | |
So in order to keep the GUI simple, I bypassed the idea. However, I haven't fully abandoned it, I just can't seem to find a nice formula for it. Any ideas on the subject would be extremely useful! |
11th November 2014, 04:03 | #114 | Link |
Hi gpower2,
I found two bug (maybe) 1st. First open the log, then open a *.mkv file, and finally open log again. You will see nothing in the log form(unless you click the 'Refresh' button). 2nd. When you load a job from files , you can not add jobs to the manager anymore. Talk about my idea.(I don't have an account of sourceforge.net. ISP limited. So maybe it looks messy...) For the first one , I think it does better after adding an activated event. Code:
private void frmLog_Activated(object sender, EventArgs e) { try { txtLog.Text = MKVLogger.LogText; txtLog.Focus(); txtLog.Select(txtLog.Text.Length ,0); txtLog.ScrollToCaret(); } catch (Exception ex) { Debug.WriteLine(ex); } } Code:
//frmJobManager.cs line 381 //grdJobs.DataSource = new BindingList<gMKVJobInfo>(jobList); grdJobs.DataSource = _JobList = new BindingList<MKVJobInfo>(jobList); grdJobs.Refresh(); Anyway, this gMKVExtractGUI is very helpful and I very like it. very much! Best Regards. Last edited by kongfl888; 12th November 2014 at 02:05. |
17th November 2014, 00:35 | #116 | Link | |
Files and their tracks could be listed individually and the desired track to be extracted from each selected, then batch extracted without needing to add individual jobs to a queue first. MKVCleaver also has another method for batch extracting tracks where you can simply select "audio track 1" etc in the right pane. One area where that could probably be improved is after selecting a track in batch mode every file could have it's "audio track 1" selected, but the user could check the individual files and deselect a track and/or select a different one if desired. I'll confess I find not being able to open multiple files simultaneously a bit inconvenient at times. Quite often I'll highlight a bunch of them in Windows Explorer, right click and SendTo MKVCleaver. Being able to do the same with gMKVExtractGUI would be nice. Currently it's one file at a time from the SendTo menu. Anyway, thanks for the new version! |
18th November 2014, 07:40 | #118 | Link | ||
Yes, you can right click on the track list and you will see a context menu with many selection options. |
18th November 2014, 10:23 | #119 | Link | ||
Anyway.... my idea would be to have a pane which lists multiple files, and under each file would be a list of it's tracks. There'd be a way to select "video" or "audio 1" or "subtitle track 1" etc which would automatically check the appropriate track for each file. If you select "audio 1" for example, the first audio track for each file is checked, but before starting the batch extraction job there'd be the opportunity to change the selection manually. For file number three I might want to de-select audio 1 and select audio 2 instead. That sort of thing. |
extractor, gmkvextractgui, matroska, mkv, mkv extract, mkvextract, mkvextractgui |
