Old 12th July 2011, 14:26   #11121  |  Link
nurbs
Works like Nero. You need a "-" (without the quotation marks) where you normally put the input file and most likely also "-ignorelength".
nurbs is offline
Old 14th July 2011, 20:51   #11122  |  Link
leeperry
Kid for Today
simple question please: I get a checksum error on the BD of "The Nightmare Before Xmas":
M2TS, 1 video track, 6 audio tracks, 17 subtitle tracks, 1:16:38, 24p /1.001
1: VC-1, 1080p24 /1.001 (16:9)
2: TrueHD/AC3, 7.1 channels, 48kHz
   (embedded: AC3, 5.1 channels, 640kbps, 48kHz)
[a02] Encoding FLAC with libFlac...
[a02] Creating file "e:\xmas\audio.flac"...
[a02] [libav] Substream 1 parity check failed  <WARNING>
[a02] [libav] Substream 1 checksum failed  <WARNING>
[a02] [libav] Lossless check failed - expected c0, calculated 6  <WARNING>
Anything I can do
leeperry is offline
Old 14th July 2011, 21:08   #11123  |  Link
starmanj
Is there a tool to automate MLP creation using Surcode with eac3to? Like the old Wavewizard did for DTS files?
starmanj is offline
Old 14th July 2011, 22:02   #11124  |  Link
tebasuna51
tebasuna51's Avatar
Anything I can do
Is only a WARNING, the flac is OK?
tebasuna51 is offline
Old 17th July 2011, 18:22   #11125  |  Link
lostclusters
I have been attempting to back my BluRay LotR EE discs. My Flac encoded audio is distorted and out of sync. I have not had this trouble with any of my other discs. I use EAC3TO and HdBrStreamExtractor as a gui. I have the TMT codecs loaded and my log show them being used. Has anyone else seen this issue and what can be done about it?
lostclusters is offline
Old 17th July 2011, 19:09   #11126  |  Link
tebasuna51
tebasuna51's Avatar
There are two problems with DTS-MA 6.1 (like included in BluRay LotR EE discs).
- You need ArcSoft Decoder v1.1.0.0, other like v1.1.0.7 make wrong 6.1 decodes.
- If you downmix DTS-MA 6.1 to 5.1 with eac3to the surround channeles are wrong mixed.
Old 18th July 2011, 01:07   #11127  |  Link
lostclusters
What's the best way to ensure the correct version of that codec? When the discs are played (w/TMT3) they play fine.
Old 18th July 2011, 12:34   #11128  |  Link
quartex
piranha (REAL 3D + 2D)
I created the iso using anydvd HD, then using clownBD I'm trying to backup the 2D form
There are two tracks
1) 00005.mpls, 00007.m2ts, 1:28:20
- Chapters, 12 chapters
- h264/AVC, 1080p24 /1.001 (16:9)
- DTS Master Audio, Italian, multi-channel, 48kHz
- DTS Master Audio, English, multi-channel, 48kHz
2) 00004.mpls, 00005.m2ts, 1:28:20
- h264/AVC (left eye), 1080p24 /1.001 (16:9)
- h264/AVC (right eye), 1080p24 /1.001 (16:9)
so I selected the 00004.mpls and then the left eye stream with DTS Master Audio, Italian and italian subtitles
eac3to is logging plenty of "The source file seems to be damaged - discontinuity" and cannot demux
It doesn't seem a bad rip because I can demux 00005.mpls without any errors.
Any ideas?
quartex is offline
Old 18th July 2011, 13:01   #11129  |  Link
phate89
hi..
edit:the first question was stupid.. there is a specific function for delay without using edit...
And a second question.. is there a way to do multiple edits? it's boring to have to create 4 files to do 4 edits..
phate89 is offline
Old 18th July 2011, 18:21   #11130  |  Link
kalston
Thanks!
I was wondering why my ripped LotR EE mkvs had this horrible sound. It's working perfectly now.
kalston is offline
Old 18th July 2011, 21:25   #11131  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by phate89 View Post
hi..
1) Yes, include only the delay: -640ms or +640ms
2) No, sorry.
Old 19th July 2011, 01:42   #11132  |  Link
lostclusters
How do I get the version number from the codec?
Old 19th July 2011, 02:07   #11133  |  Link
Midzuki
Unavailable
Midzuki's Avatar
Open Windows Explorer, right-click on the file dtsdecoderdll.dll, select "Properties".
Midzuki is offline
Old 19th July 2011, 02:31   #11134  |  Link
lostclusters
Tyvm!
Old 19th July 2011, 02:40   #11135  |  Link
robpdotcom
Which version of TMT included v1.1.0.0?
Windows 7 x64
i7 870
16GB RAM
AMD 6870
robpdotcom is offline
Old 19th July 2011, 02:48   #11136  |  Link
NanoBot
...- If you downmix DTS-MA 6.1 to 5.1 with eac3to the surround channeles are wrong mixed.
since this is exactly what I want do do ( 6.1 DTS-MA -> 5.1 Flac ), could you please give me a hint what's going wrong when downmixing with eac3to and version 1.1.0.0 of the dll ? My idea to circumvent the problem would be to decode the 6.1 DTS-MA to 7 seperate wave-files, to do the downmix to 5.1 manually in a correct way using audacity and then to reencode the wavs to a 5.1 Flac.
Thx in advance, Nanobot
NanoBot is offline
Old 19th July 2011, 03:37   #11137  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by NanoBot View Post
...since this is exactly what I want do do ( 6.1 DTS-MA -> 5.1 Flac ), could you please give me a hint what's going wrong when downmixing with eac3to and version 1.1.0.0 of the dll ?...
In this thread: http://forum.doom9.org/showthread.ph...10#post1465610
Now eac3to make the downmix 6.1 -> 5.1 with:
SurroundL = Cs + 0.7071xRs
SurroundR = Ls + 0.7071xRs
And must be:
SurroundL = Ls + 0.7071xCs
SurroundR = Rs + 0.7071xCs
Yes, you can decode the 6.1 like wav's and make the mux manually.
Old 20th July 2011, 01:47   #11138  |  Link
NanoBot
for the link and the information, that is accurately the info I was looking for.
Nevertheless, I would suspect that this downmix matrix for the surround channels might result in levels above 0dB for Ls and Rs ? Or are the levels for Ls, Cs and Rs in a 6.1 DTS-MA file are already limited to values where Ls + 0.7071 x Cs and Rs + 0.7071 x Cs can't exeed a level of 0dB ?
If my concern is true, would it be ok just to normalize those two channels after the downmix, or do you have a recommendation how to avoid this probable problem ?
C.U. Nanobot
NanoBot is offline
Old 20th July 2011, 02:50   #11139  |  Link
tebasuna51
tebasuna51's Avatar
Yes, we always need normalize after a downmix.
eac3to normalize the 6 channels automatically.
Old 20th July 2011, 16:21   #11140  |  Link
musinsky
is there any way to set "not standard" stretch ?!
For example, how with eac3to make stretch 25.002 -> 23.976 ?
musinsky is offline
eac3to
