5th February 2011, 00:09 | #10961 | Link |
Given both tracks are lossless, can you hear a difference?
The way I'd do it would be to demux both tracks with EAC3TO, demux to .WAVs and waveform compare in Audition to verify either an initial +/- delay and/or cuts necessary to sync. Cheers, -jj- |
5th February 2011, 01:21 | #10962 | Link |
NY Frame of Mind
Thanks, good suggestion jj.
Difference? I'm not sure, maybe it's just psycological but one track is ~1576 kps, 16 bit, while the other is ~ 3700 kbps, 24 bit. Hard to believe that the first one is truly lossless, but I guess when I demux to wavs I'll see. I've been playing around with the track sync in VLC and +900 ms puts it just about spot on, even when I slow down playback. But if I can get it exact in Audition, I'll give it a shot. Edit : pm sent
"Talk to me Goose" Last edited by rapscallion; 6th February 2011 at 16:43. |
7th February 2011, 12:50 | #10963 | Link |
User of free A/V tools
I usually open both video sources via Avisynth -> StackHorizontal(a,b) and time/scene shifts can be immediately seen. I then cut/append blank frames as necessary while leaving audio track untouched.
8th February 2011, 07:47 | #10965 | Link |
Well, then it's about time to start learning
9th February 2011, 23:07 | #10966 | Link |
NY Frame of Mind
I apologize again for the OT of this subject.
Thanks for the info kypec. Already use #'s 1 & 2. I've heard of VirtualDub but never used it because it doesn't support *.m2ts video sources, which is the subject of my op.
"Talk to me Goose" |
10th February 2011, 01:51 | #10967 | Link | |
Unavailable
Watches pelcome Last edited by Midzuki; 10th February 2011 at 02:01. Reason: spelling |
10th February 2011, 06:52 | #10968 | Link | |
AVS supports FFMS2 plugin, right? Finally, FFMS2 supports M2TS & TS streams (maybe not frame-accurate when seeking though), or you can try DGDecNV if you have compatible nVidia GPU which is frame-accurate with all supported file formats. |
10th February 2011, 16:27 | #10969 | Link |
Eac3to reports: "Haali Matroska Muxer (2010-11-07) is installed, There's a new version (2010-11-21) available". However, I have installed the latest 21/11/2010 version from http://haali.su/mkv/.
12th February 2011, 14:51 | #10970 | Link |
How to setup MPC-HC with ffdshow, avisynth, reclock and more - Ezoden.com Last edited by jeremy33; 13th February 2011 at 16:32. |
14th February 2011, 01:11 | #10971 | Link |
DVD-Guides.com Author
sorry to "hack" this thread, but it is kind of eac3to related. It reports I have ArcSoft: Code:
[a03] Extracting audio track number 3... [a03] Decoding with ArcSoft DTS Decoder... [a03] Encoding AC3 <448kbps> with libAften... [a03] Creating file "D:\Movies\xxxx\1_3_audio.ac3"... [a03] The original audio track has a constant bit depth of 24 bits. Video track 2 contains 141706 frames. eac3to processing took 11 minutes, 7 seconds. Done.
DVD-Guides.com - your source for video guides |
16th February 2011, 16:28 | #10972 | Link |
I don't know if this is a bug of eac3to or not, my current version is 3.17
In some sources I get this error log message : eac3to v3.17 command line: "C:\eac3to\eac3to.exe" C:\SAMPLE~2\CTU-X2~1.MKV 1:"C:\AAA_TE~1\dolby_ac3_1.ac3" -448 -down6 ------------------------------------------------------------------------------ MKV, 1 video track, 1 audio track, 0:01:05, 24p /1.001 1: h264/AVC, English, 720p24 /1.001 2: AC3, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB, 2ms This video conversion is not supported. <ERROR> That's correct because I'm trying to reencode stream nș 1 that eac3to identifies as VIDEO H264, of course that is not supported The problem is that Mediainfo and MKVToolnix identifies the streams as 1 = audio and 2 = video, i.e., the streams order are different Here is the log of mkvinfo of that sample movie : + EBML head |+ Doc type: matroska |+ Doc type version: 1 |+ Doc type read version: 1 + Segment, size 28039868 |+ Seek head (subentries will be |+ EbmlVoid (size: 4027) |+ Segment information | + Timecode scale: 1000000 | + Muxing application: libebml | + Writing application: mkvmerg 7 09:35:09 | + Duration: 64.610s (00:01:04. | + Date: Fri Feb 22 04:21:20 20 | + Segment UID: 0x66 0x07 0x99 7 0xfe 0xd0 0xd0 |+ Segment tracks | + A track | + Track number: 1 | + Track UID: 376306038 | + Track type: audio | + Enabled: 1 | + Default flag: 1 | + Forced flag: 0 | + Lacing flag: 1 | + MinCache: 0 | + Timecode scale: 1 | + Max BlockAddition ID: 0 | + Codec ID: A_AC3 | + Codec decode all: 1 | + Default duration: 32.000ms | + Language: und | + Audio track | + Sampling frequency: 48000 | + Channels: 6 | + A track | + Track number: 2 | + Track UID: 1 | + Track type: video | + Enabled: 1 | + Default flag: 1 | + Forced flag: 0 | + Lacing flag: 0 | + MinCache: 1 | + Timecode scale: 1 | + Max BlockAddition ID: 0 | + Codec ID: V_MPEG4/ISO/AVC | + Codec decode all: 1 | + CodecPrivate, length 39 (h. | + Default duration: 41.708ms | + Language: eng | + Video track | + Pixel width: 1280 | + Pixel height: 720 | + Interlaced: 0 | + Display width: 16 | + Display height: 9 |+ EbmlVoid (size: 1024) |+ Cluster |
16th February 2011, 16:51 | #10973 | Link |
I guess eac3to always uses the same order (chapter,video,audio,subtitles) regardless of what the track order in the container is. If eac3to lists the audio as track 2 then that's what you'll have to use in your command line.
16th February 2011, 17:19 | #10975 | Link |
First run:
eac3to v3.17 command line: "C:\eac3to\eac3to.exe" C:\SAMPLE~2\CTU-X2~1.MKV ------------------------------------------------------------------------------ MKV, 1 video track, 1 audio track, 0:01:05, 24p /1.001 1: h264/AVC, English, 720p24 /1.001 2: AC3, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB, 2ms and analize the log.
18th February 2011, 20:09 | #10976 | Link | |
Pajas Mentales...
18th February 2011, 21:14 | #10977 | Link | |
18th February 2011, 21:57 | #10978 | Link |
Unavailable
@ madshi (feature request) :
why not make eac3to look for mkvtoolnix in the folders covered by the "PATH" envinronment-variable? In the same way it looks for neroaacenc.exe. I am sure I'm not the only one who uses mmg.exe without the help from an "installer". |
19th February 2011, 06:56 | #10979 | Link |
extraction problem?
Hi
I'm trying to extract DTS-HD audio from a m2ts file so that I can mux it with my compressed video stream (MKV). Using MediaInfo, the original m2ts file displays this for audio Code:
Audio #1 ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : DTS Format/Info : Digital Theater Systems Format profile : MA / Core Muxing mode : Stream extension Codec ID : 134 Duration : 50mn 23s Bit rate mode : Variable Bit rate : 3 688 Kbps / 1 510 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 24 bits Compression mode : Lossless / Lossy Language : English Code:
Audio Format : DTS Format/Info : Digital Theater Systems Format profile : MA / Core Duration : 1h 47mn Bit rate mode : Variable Bit rate : 1 747 Kbps / 1 510 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 24 bits Compression mode : Lossless / Lossy Code:
eac3to.exe C:\makin.m2ts 2: C:\test.dts M2TS, 1 video track, 4 audio tracks, 6 subtitle tracks, 0:50:23, 24p /1.001 1: VC-1, 1080p24 /1.001 (16:9) 2: DTS Master Audio, English, 5.1 channels, 24 bits, 48kHz (core: DTS, 5.1 channels, 24 bits, 1509kbps, 48kHz) 3: AC3, French, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB 4: AC3, Spanish, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB 5: AC3, Portuguese, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB 6: Subtitle (PGS), English 7: Subtitle (PGS), French 8: Subtitle (PGS), Spanish a02 Extracting audio track number 2... a02 Creating file "C:\test.dts" Code:
eac3to.exe C:\makin.m2ts 2: C:\test.dts M2TS, 1 video track, 4 audio tracks, 6 subtitle tracks, 0:50:23, 24p /1.001 1: VC-1, 1080p24 /1.001 (16:9) 2: DTS Master Audio, English, 5.1 channels, 24 bits, 48kHz (core: DTS, 5.1 channels, 24 bits, 1509kbps, 48kHz) 3: AC3, French, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB 4: AC3, Spanish, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB 5: AC3, Portuguese, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB 6: Subtitle (PGS), English 7: Subtitle (PGS), French 8: Subtitle (PGS), Spanish a02 Extracting audio track number 2... a02 Decoding with ArcSoft DTS Decoder... a02 Encoding FLAC with libFlac... a02 Creating file "test.flac"... Last edited by ketchup318; 19th February 2011 at 18:36. |
19th February 2011, 11:10 | #10980 | Link | |
As for the bitrate discrepancy, perhaps Mediainfo isn't reporting it correctly. As you know the length and size of your demuxed file you can work out the actual bitrate and check against what Mediainfo says. 1747Kbps sounds very low for a 6 channel, 24 bit lossless track. EDIT: nurbs beat me to it! |
eac3to |
