16th June 2015, 09:40 | #1422 | Link | |
This is a very specific request, only for very users (Episodes can be in a sub-dir and so on), I don't want to add another field in the release of MediaInfo for such specific request. You have to use an external tool (calling MediaInfo library and you manage the Path yourself in your favorite programming language, or something from the command line)
Want to know all about your media files? http://mediaarea.net/MediaInfo |
21st June 2015, 21:20 | #1424 | Link |
契約者
Zenitram
Hi. Currently for audio files with tags that have multiple occurances of the same tag, mediainfo displays them like so: Code:
Composer : FirstTagValueHere / SecondTagValueHere Code:
<?xml version="1.0"?> <!-- <!DOCTYPE Tags SYSTEM "matroskatags.dtd"> --> <Tags> <Tag> <Simple> <Name>TITLE</Name> <String>FirstTagValueHere</String> <TagLanguage>und</TagLanguage> <DefaultLanguage>1</DefaultLanguage> </Simple> <Simple> <Name>TITLE</Name> <String>SecondTagValueHere</String> <-- only this is displayed <TagLanguage>und</TagLanguage> <DefaultLanguage>1</DefaultLanguage> </Simple> </Tag> </Tags> Last edited by Keiyakusha; 21st June 2015 at 21:23. |
23rd June 2015, 09:59 | #1425 | Link |
Not expected. Please provide a sample file + the intended behavior.
23rd June 2015, 12:35 | #1426 | Link | |
契約者
Current output with the latest stable mediainfo release. Note that the ALBUM tag is not shown at all, I just noticed this. Code:
... Overall bit rate : 986 Kbps Track name : 池田綾子 「プリズム (backtracks)」 Encoded date : UTC 2015-06-23 11:17:58 Writing application : mkvmerge v8.0.0 ('Til The Day That I Die') 64bit Writing library : libebml v1.3.1 + libmatroska v1.4.2 TITLE : Prism (backtracks) ARTIST : Ikeda Ayako COMPOSER : Ikeda Ayako DATE_RECORDED : 2007-08-29 PART_NUMBER : 4 PUBLISHER : Sony Music Records TOTAL_PARTS : 5 _STATISTICS_TAGS : BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES ... Code:
... Overall bit rate : 986 Kbps Track name : 池田綾子 「プリズム (backtracks)」 Encoded date : UTC 2015-06-23 11:17:58 Writing application : mkvmerge v8.0.0 ('Til The Day That I Die') 64bit Writing library : libebml v1.3.1 + libmatroska v1.4.2 ALBUM : プリズム/空の欠片 / Prism/Sora no Keppen TITLE : プリズム (backtracks) / Prism (backtracks) ARTIST : 池田綾子 / Ikeda Ayako COMPOSER : 池田綾子 / Ikeda Ayako DATE_RECORDED : 2007-08-29 PART_NUMBER : 4 PUBLISHER : Sony Music Records TOTAL_PARTS : 5 _STATISTICS_TAGS : BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES ... Code:
Overall bit rate : 840 Kbps Album : プリズム/空の欠片 / Prism/Sora no Keppen Album/Performer : 池田綾子 / Ikeda Ayako Part : 1 Part/Total : 2 Track name : プリズム (backtracks) / Prism (backtracks) Track name/Position : 4 Track name/Total : 5 Performer : 池田綾子 / Ikeda Ayako Composer : 池田綾子 / Ikeda Ayako Producer : Sony Music Records Recorded date : 2007-08-29 Last edited by Keiyakusha; 23rd June 2015 at 12:46. |
26th June 2015, 15:38 | #1428 | Link | |
契約者
Accordingly to Matroska specs, 50 means "ALBUM / OPERA / CONCERT" and 30 means "TRACK / SONG" Last edited by Keiyakusha; 26th June 2015 at 15:44. |
29th June 2015, 08:57 | #1430 | Link |
https://yadi.sk/i/wqewWfIphYJoT
MediaInfo don't see any streams in this file. MPC-BE open correct and detect 1 video + 6 audio + 5 subtitles.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
29th June 2015, 09:09 | #1431 | Link | |
Life's clearer in 4K UHD
29th June 2015, 09:35 | #1432 | Link | |
PMT is buggy (CRC is wrong), so ignored (and the PMT is important for the list of streams)
30th June 2015, 02:45 | #1433 | Link | |
Also - this file open ffmpeg/LAVSource.
30th June 2015, 07:47 | #1434 | Link | |
Current policy of MediaInfo: - if there is PAT/PMT content, consider the file as a valid TS file, expecting valid PAT/PMT. Invalid CRC means transmission errors, waiting for the next one. the PAT is valid, so it is normal to wait for a valid PMT -if there is no PAT/PMT, autodect of PES with content. Your file has a problem: it has a valid PAT, and PMT with invalid CRC, you need to fix the muxer, not the analyzer. If you want to have an option (which will not be activated by default because your file is buggy, not the analyzer) for bypassing CRC checks and/or forcing the autotdetect of PES even, please add a feature request) but I prefer to warn: due to the fact your file is buggy, I am not willing to implement this feature for free (but I may accpet a patch). Each developper has his own policy for buggy files. Mine is to not ignore a CRC fail, at least by default.
20th August 2015, 00:21 | #1435 | Link |
Hello.
Latest MediaInfo v0.7.76 x86 crashes on AthlonXP (32 bit - non SSE2 CPU) using WinXP. "External exception C000001D"
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all |
20th August 2015, 00:36 | #1436 | Link |
The trouble with non-SSE2 CPUs started with version 0.7.71, and upon my requests Zenitram corrected this up to version 0.7.74.
http://forum.doom9.org/showthread.ph...37#post1699337 Starting with 0.7.75 the issue came back again, and I am getting a little tired of nagging Zenitram for every new version. Looks like I will stick with 0.7.74 for a while... Cheers manolito |
20th August 2015, 23:50 | #1437 | Link |
It is an easy fix for him. The MSVC2013 project files for ZenLib and Zlib need to be set to SSE. I have checked and the rest is ok.
MPC-HC 2.1.7.2 |
26th August 2015, 20:14 | #1438 | Link | |
Software Developer
MediaInfo v0.7.76 static build: http://sourceforge.net/projects/muld...5.zip/download
2nd September 2015, 22:08 | #1440 | Link |
It seems there was a change which broke a feature of my app and I don't know how to get the old behavior, the code I was using is:
MediaInfo_Option(mi.Handle, "Complete", "1") Return Marshal.PtrToStringUni(MediaInfo_Inform(mi.Handle, 0)) Same version back this was getting parameter names with underscore but now it gets friendly names without underscore, I need to know all parameter names.
