Old 26th February 2018, 20:32   #1  |  Link
musicman
Archiving DVD's problem
Hi I'm going to be archiving DVD's for our Church, and I started with the oldest from 2005, and I noticed certain motions have jaggies. The jaggies don't go across the screen but are limited to where te motion is. I'm using Handbrake and I've tried different presets. It has to be h.264 in a mp4 container. I've experimented with deinterlacing based on some suggestions online but it hasn't fixed it. Is it even something that's fixable? Or is it because it was an old camera recording on an old dvd recorder?
Thanks
musicman is offline   Reply With Quote
Old 26th February 2018, 20:42   #2  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
This is called "interlacing". Or, more specifically, it is what happens when you resize "interlaced" material without deinterlacing it first.
Applying a deinterlacing filter is the right thing to do. But you have to be absolutely sure that you apply the deinterlacing filter on the original "interlaced" material - prior to any resizing.
Once "interlaced" material has been resized without deinterlacing it first, it is pretty much impossible to fix/undo, except by going back to the original unprocessed footage.
If you expect more help, please upload a small(!) and completely unprocessed(!) chunk from your original DVD...
See also: http://100fps.com/
Old 26th February 2018, 20:49   #3  |  Link
musicman
fps
I've began reading the link in your post, is this apply to NTSC? It refers to 25fps, is that what video cameras and VCR's recorded at?
Old 26th February 2018, 20:53   #4  |  Link
LoRd_MuldeR
Software Developer
Actually PAL and NTSC are obsolete analogue TV transmission standards.
In the "digital world" these standards have no meaning, except that a resolution of 720×480 pixels with a framerate of 29.97 is sometimes called "NTSC" for historical reasons. The same goes for "PAL", which refers to 720×576 at 25 fps.
Anyhow, interlacing can be used with "NTSC" as well as "PAL", or even "HD" footage. The frame rate doesn't really matter either. But there always are two "half pictures" stored in each "interlaced" frame.
For example, if you have an "interlaced" stream with 29.97 "interlaced" frames per second, than a "full rate" deinterlacer will output 59.94 progressive frames. Just like a 25 fps "interlaced" stream would result in 50 fps after deinterlacing...
Old 26th February 2018, 21:40   #5  |  Link
Gser
Also you might want to either signal the SD colorspace with the appropriate bitstream flags for NTSC content
--colorprim smpte170m --transfer smpte170m --colormatrix smpte170m
or convert the colorspace to HD specs with colormatrix mode "Rec.601->Rec.709". https://avisynth.org.ru/docs/english...olormatrix.htm Since it appears you are upscaling to HD resolution. Some DVD's are encoded at Rec.709, there are instructions in the link to see how you can find out which colorspace is used.
Gser is offline   Reply With Quote
Old 27th February 2018, 12:08   #6  |  Link
Ghitulescu
Ghitulescu's Avatar
Hi I'm going to be archiving DVD's for our Church...
If the Church would not have enough money for storage, then who else... The IRS?
I gather these are private DVDs, thus no copyright protections of any kind. Therefore, COPY/PASTE
Born in the USB (not USA)
Old 27th February 2018, 15:34   #7  |  Link
Sharc
Thanks
Do you see the jaggies when you play your DVD via a standalone HW player + TV?
If the DVD video is interlaced and you watch it via PC+monitor without deinterlacing you will always see such jaggies or combes, even more so when you downscale the picture for viewing.
Can you upload a few seconds sample of the .vob file? Perhaps the problem is already on the DVD (poor transfer).
For archiving I would recommend to make 1:1 copies of the original DVD as Ghitulescu wrote. If you process the source "somehow" you may introduce irreversible new artefacts.
Old 27th February 2018, 19:43   #8  |  Link
musicman
I've never used a VOB editor before, so let me try playing it in different set top players. I have some "regular" DVD players and I also have an Oppo 93.
Old 27th February 2018, 20:37   #9  |  Link
LoRd_MuldeR
Software Developer
If it's really "interlaced" footage, then most likely either the DVD Player or the TV Screen will do the required de-interlacing. So if you don't see the "combing" artifacts on the TV Screen, don't be surprised
The same goes for "software" DVD players on your PC. Therefore it is very important that you look at the original footage in some editor that does not apply any kind of post-processing...
(Again: The best thing would be to provide an unprocessed chunk of the original VOB files. You may use, for example, DGSplit for this purpose - provided you have ripped the VOB's to your HDD already)
Old 27th February 2018, 22:58   #10  |  Link
musicman
Ok, I just realized that there is no tearing when I play the DVD in my computer using Media Player HC. When I copied the .vob onto my computer and played it with the same player, it had lots of tearing.
Old 27th February 2018, 23:42   #11  |  Link
Sharc
What do mean by tearing? MPC-HC has a lot of settings how to play a video source. It may or may not deinterlace, may blend the fields etc.
So how does it look when you play the DVD with your DVD player(s) and watch on TV?
The original source was perhaps a VHS tape which has been - more or less correctly - transferred to DVD.
Without a sample it is difficult to give you good advice.
Old 28th February 2018, 08:15   #12  |  Link
Ghitulescu
Ghitulescu's Avatar
He means interlacing.
Probably a teaching to him to archive them as DVDs and not, WRONGLY, as VOBs or whatever. The OP must understand how interlacing works, because, if I would be the priest of the parish he destroyed the recorded memories I'd excommunicate him...
Old 28th February 2018, 18:59   #13  |  Link
musicman
Only the Pope has that authority.
I will try the BGSplit tonight to make a clip.
Old 1st March 2018, 18:51   #14  |  Link
musicman
So just to recap, when I play the DVD in my computer using MPC-HC, there is no problem. But when I rip it using Handbrake using H.264 codec in a MP4 container, I get video lines wherever there is motion. They don't occur across the entire screen. I'd like to rip them and archive them without loosing any quality but be playable using an "average office PC or Mac."
Thanks
http://s000.tinyupload.com/index.php...95894408675023
Old 1st March 2018, 19:48   #15  |  Link
LoRd_MuldeR
Software Developer
So, yeah, definitely interlaced video. Here you see the "original" interlaced frame (left) and the two separated fields, stacked vertically (right):
...as you can see, the hand has moved in between the two fields (the fields are from different time indices!), which is why you get those "combing" artifacts if the fields are weaved into a single frame.
Old 1st March 2018, 19:52   #16  |  Link
I dont have Handbrake installed at the moment and long time since I used it,
Looks like you are upsizing without deinterlacing, you should not do that.
I presume that there is an option to deinterlace first, try it.
Old 1st March 2018, 19:53   #17  |  Link
Sharc
Thanks
The video is interlaced, 720x480, 29.97 fps or 59.94 fields per second.
... when I play the DVD in my computer using MPC-HC, there is no problem....
Because MPC-HC apparently kicks its deinterlacer or bobber in, and you see it on the monitor as progressive video without the combing artefacts.
... But when I rip it using Handbrake using H.264 codec in a MP4 container, I get video lines wherever there is motion ....
I am not familiar with Handbrake, but I suspect that Handbrake encodes the video as interlaced, and for some reason the player does not recognize it as interlaced and plays it without deinterlacing - hence you see the combes on the PC monitor.
Try to enable a deinterlacer in Handbrake, or force the deinterlacer (or bobber) in MPC-HC so the video gets deinterlaced during playback.
Old 1st March 2018, 19:56   #18  |  Link
LoRd_MuldeR
Software Developer
musicman, here is what a script as simple as this can do to your sample
musicman_sample_v2.zip
Old 1st March 2018, 20:01   #19  |  Link
This tab (Deinterlace)
EDIT: Maybe try Deinterlace=Slower
Dont know where you would choose field order, perhaps is automatic.
EDIT: Handbrake help seems to be Offline.
Also try Preview before render.
EDIT: A forum thread on deinterlace field order (I have not read it).
http://forum.digital-digest.com/f114...p-94946-2.html
Another one:
https://forum.videohelp.com/threads/...rlace-Settings
More:
https://www.google.co.uk/search?sour....0.RYJQyPAfrXk
Old 1st March 2018, 20:20   #20  |  Link
Sharc
musicman
I just tried Handbrake. No problem with settings like:
Filters Tab:
Detelecine: off
Deinterlace: yadif
others leave at default
Video Tab:
Framerate 29.97
Constant Framerate
You will get a deinterlace video without combes.
Good luck.
