18th July 2013, 18:12 | #1 | Link |
[Updated 2019] Opus 1.3. New WebM audio codec (Opus+VP9/AV1)
Opus 1.3
http://opus-codec.org/ Demos (version 1.1)http://people.xiph.org/~xiphmont/demo/opus/demo3.shtml (version 1.2) https://people.xiph.org/~jm/opus/opus-1.2/ (version 1.3) https://people.xiph.org/~jm/opus/opus-1.3/ Previously Opus has shown excellent results beating LC-AAC, HE-AAC v1, HE-AAC v2 and Vorbis. Public Multiformat Listening Test @ ~64 kbps [March 2011] Public Multiformat Listening Test @ ~96 kbps [2014] Official builds of Opus 1.3 stable Win64 https://archive.mozilla.org/pub/opus...-1.3-win64.zip Win32 https://archive.mozilla.org/pub/opus...2-opus-1.3.zip Playback You can play Opus files on your Android/Apple iOS/Windows Phone smartphones/tablets via foobar2000 http://mobile.foobar2000.com/ Many players as MPC, VLC, foobar2000 (Windows, Android, iOS, Windows Phone) support Opus format as well as Rockbox (a firmware for portable players). https://www.rockbox.org/ For more information http://wiki.hydrogenaud.io/index.php?title=Opus Last edited by IgorC; 22nd October 2018 at 23:22. |
6th December 2013, 16:36 | #2 | Link |
Software Developer
Opus v1.1 has finally been released
For info see here: http://xiph.org/~xiphmont/demo/opus/demo3.shtml Fresh builds can be found here: http://sourceforge.net/projects/muld.../Opus%20Tools/
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 21st December 2013 at 12:47. |
7th December 2013, 14:51 | #4 | Link |
Life's clearer in 4K UHD
What do people think about Opus's surround sound encoding capabilities?
9th December 2013, 10:15 | #5 | Link | |
As expected, your build is a bit faster than the Xiph one, however it writes 60 bytes less when encoding the same source file on the same machine: Xiph: Code:
Encoding using libopus 1.1 (audio) ----------------------------------------------------- Encoded: 44 minutes and 53.6 seconds Runtime: 1 minute and 24 seconds (32.07x realtime) Wrote: 43510600 bytes, 134680 packets, 2696 pages Mulder: Code:
Encoding using libopus 1.1-SSE2 [2013-12-06] (audio) ----------------------------------------------------- Encoded: 44 minutes and 53.6 seconds Runtime: 1 minute and 21 seconds (33.25x realtime) Wrote: 43510540 bytes, 134680 packets, 2696 pages http://www.hydrogenaudio.org/forums/...dpost&p=851264 http://www.hydrogenaudio.org/forums/...dpost&p=851337 http://www.hydrogenaudio.org/forums/...dpost&p=851357 |
9th December 2013, 11:07 | #6 | Link |
Yes, I'm weird.
@Brazil2
According to Jean-Marc Valin, that may be due to rounding behaviour (with different optimization levels).
“Never argue with stupid people, they will drag you down to their level and then beat you with experience.” — Mark Twain |
10th December 2013, 19:57 | #7 | Link | |
I would be interested how low can man go to keep transparent sound. Seems that effective ~210k still give superior quality on 6 channel audio.
10th December 2013, 21:53 | #8 | Link | |
Software Developer
Not that a difference in file size would mean anything. In theory, the bits could be distributed completely different and still the exactly same file size could be hit! Instead, you should decompress both files to uncompressed Wave/PCM and then add the inverse of the one file to the other file (e.g. use "mix paste" in Audition). As long as the result is silent - or at least very close to silent - there is no reason to be concerned. Furthermore, you could also try to ABX the files... [EDIT] I just converted a complete album (Chinese Democracy) to Opus format, once using the "i386" build and once using the "sse2" build. Both files came out at identical size. Files were not identical by content. Of course, not. The encoder signature string already differs. Next I decoded the "i386"-encoded file with the "sse2" decoder and the "sse2"-encoded file with the "i386" decoder, which should be the most extreme test case, I think. The difference between the two decoded files is silent. There are a few minor peaks in a few places, but noting critical. Average RMS of the diff is -85.79 dB.
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 11th December 2013 at 00:33. |
11th December 2013, 08:08 | #9 | Link |
Yes, I'm weird.
Actually, I've discovered that if you compile Opus and Opus-tools with GCC, you can add "-fno-strict-aliasing" to CFLAGS to get the same (bit identical) results with -O level from 0 to 3. (Of course, it only applies when you're comparing the results encoded by the same machine.)
13th April 2014, 14:22 | #10 | Link |
Software Developer
FWIW, here's a set of fresh Opus binaries made from current Git Master:
http://sourceforge.net/projects/muld...3.zip/download
14th January 2015, 15:38 | #11 | Link |
Swallowed in the Sea
fyi, Opus Audio format has been validated by mp4ra.org...and a draft is in progress to encapsulate Opus files into MP4.
14th January 2015, 16:17 | #12 | Link | |
14th January 2015, 17:48 | #14 | Link | |
15th January 2015, 08:38 | #15 | Link | |
15th January 2015, 10:24 | #16 | Link |
Opus in MP4 is still a draft, and VLC adding a potentially unfinished draft just seems like a not-well-thoughtout move. At least they only demux and don't mux files which may be wrong eventually...
27th January 2015, 15:39 | #17 | Link |
Not sure if this a a playback or a 'I'm just stupid' king of bug.
I'm using: Code:
ffmpeg -y -threads 8 -loglevel fatal -i "H:\Output\test.ac3" -ac 6 -ar 48000 -f sox - | sox --multi-threaded --ignore-length --temp "H:\Temp" --buffer 524288 -S -t sox - -b 16 -t wav - | opusenc --bitrate 192 --comp 10 --framesize 20 --expect-loss 0 --max-delay 1000 --ignorelength --raw-bits 16 --raw-rate 48000 --raw-chan 6 - "H:\Output\test.opus" Reencoding seems to work fine, but upon playback the channel order is wrong lfe comes through the front right box. -> My guess is that I either need to rearrange the channels before encoding or there is a problem with the decoding through MPC-HC. |
27th January 2015, 15:51 | #18 | Link | |
Try play this: http://www6.zippyshare.com/v/50RpBiHm/file.html eac3to test.ac3 stdout.wav -normalize | opusenc --ignorelength --vbr --comp 10 --bitrate 192 - test.opus Last edited by Anakunda; 27th January 2015 at 15:55. |
27th January 2015, 18:30 | #19 | Link | |
EDIT: The last time I checked, LameXP was able to correctly assign the channel order...
