21st February 2010, 16:26 | #1542 | Link |
This is awesome news. I need to get all the latest stuff installed and try it out. Let's see here...dxva support, bd subs, and bug fixed bitstreaming. Hmm, yea, that sounds nice.
21st February 2010, 16:33 | #1543 | Link | |
Thx Albain : Seb.
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355. |
21st February 2010, 16:37 | #1544 | Link |
My time has been limited the past few weeks. Between my job situation, my second HTPC blowing up....twice, and now my cable box dying...twice, I haven't had a lot of time to mess around with anything. Hopefully things will calm down a bit this week.
21st February 2010, 19:50 | #1550 | Link |
Is anyone on a clarksdale able to play LPCM tracks? I'm referring to tracks that come as LPCM on the disc (Pirates of the Carribean, etc.)?
I'm getting PIN errors, the splitter cannot even connect to FFDSHOW.
HTPC #1 with Xonar HDAV, Pioneer VSX-TX01H HTPC #2 with Clarksdale, Pioneer VSX-TX01H XBMC for the win!! |
21st February 2010, 19:57 | #1551 | Link | |
Media Control author
We don't have any valuable dump traces to reverse engineer the format Maybe some of you did but I may have missed them |
21st February 2010, 20:07 | #1552 | Link |
It should be possible now with the TMT3 beta to get those dumps. Someone with a 32 bit install and the dump tool should post some 48/24 LPCM track dumps.
21st February 2010, 21:17 | #1554 | Link | |
http://forum.doom9.org/showthread.ph...34#post1370134 Caution: Install ffdshow and reclock before MPC-HC. I'll edit my post that i gave the link to show how to config MPC and Reclock more detailled; i don't use ffdshow for lpcm. |
21st February 2010, 22:05 | #1555 | Link |
I'm still trying to find out why ffdshow does not stream TrueHD to the MPC audio renderer on my system with this error message:
TaudioParser::checkOutputFormat refused for codec bitstream Dolby True HD with sample format 256 |
21st February 2010, 22:14 | #1557 | Link | |
21st February 2010, 22:16 | #1558 | Link |
That's pretty odd. Have you tried the realtek driver at all? Also, you can get Tulli to make you an override specific for your equipment now if you want. There's a new tool to get the realtime EDID info so that he can make a custom driver for you. Not sure if that'd help or not but it might not hurt to try it.
21st February 2010, 22:28 | #1559 | Link |
Thanks for the suggestion! I have had the Realtek driver installed previously but not since installing the latest ATI graphics driver. How do I identify which is which? This is the driver info from device manager:
ATI High Definition Audio Device Driver Provider: ATI Driver Date: 2010-01-15 Driver Version: 6.57.0.6602 AtiHdmi.sys file version: 6.57.0.6602 The EDID override matches my system almost exactly so I think it might be the least likely problem. Tulli said in some post that the bitstreaming works the same with all overrides. |
21st February 2010, 22:30 | #1560 | Link |
Ok, that's the driver from the 10.2 Catalyst set. So that's good....in theory. I'd give the realtek driver another try and if it doesn't work, you can just uninstall it and the ATI driver will come back.
