Old 18th October 2009, 12:20   #8761  |  Link
albain
Media Control author
The xonar driver would even refuse PCM formats in wasapi mode
I really have to take some time to create this tool that will scan all the accepted types
For now, only radeon 5xxx owners can help
Once the stream will be working, we will focus on other cards
albain is offline   Reply With Quote
Old 18th October 2009, 12:22   #8762  |  Link
tetsuo55
MPC-HC Project Manager
that tool would probably save everyone a lot of time (we could check which drivers support what, to speed up testing)
tetsuo55 is offline   Reply With Quote
Old 18th October 2009, 12:45   #8763  |  Link
Blight
Software Developer
Blight's Avatar
I have a question with regards to the "FFMPEG-MT" H.264 decoder,
Is there any downside to using this decoder on a single-core system (as compared to the libavcodec)? Any compatibility issues or degraded performance?
Yaron Gur
Zoom Player . Lead Developer
Blight is offline   Reply With Quote
Old 18th October 2009, 13:10   #8764  |  Link
Skinleech
A.K.A Mangoat
Ok, I definitely will bow out for now
Skinleech is offline   Reply With Quote
Old 18th October 2009, 13:11   #8765  |  Link
EpsilonX
Hi guys...
Possible bug encountered in libavcodec for MPEG2 stream...
Works fine when changed to libmpeg2...
rev3098 works fine...
IIRC it broke since rev3099, FFMpeg update..?
Any confirmation..?
Thanx in advance...
EpsilonX is offline   Reply With Quote
Old 18th October 2009, 14:03   #8766  |  Link
clsid
@Blight
Performance with 1 thread should be the same as regular libavcodec. I haven't done any recent comparisons, but you can benchmark it yourself if you want numbers. Search the forum for Haali's "timecodec" tool.
@EpsilonX
What exactly is the bug? MPEG-2 playback is working fine here with libavcodec. You might got a bad build.
MPC-HC 2.2.1
Old 18th October 2009, 15:11   #8767  |  Link
SamuriHL
SamuriHL's Avatar
@albain:
No go. It changes the receiver to PCM mode, no audio.
http://pastebin.com/pastebin.php?dl=d73cc1bfe
Old 18th October 2009, 15:59   #8768  |  Link
EpsilonX
@EpsilonX
I've tried a couple of builds since 3099, at least 5 builds...
From here and xvidvideo.ru...
It only happen using libavcodec as MPEG2 decoder, reverting to 3908 fix it...
Sorry for the lack of detail in the previous post...
Tried it with MPEG2 files and it's working fine...
The problem only appear when it's used for DVD decoding...
Since my settings for DVD and MPEG2 are the same, a conflict with DVD Navigator maybe..?
Old 18th October 2009, 16:26   #8769  |  Link
XhmikosR
Just for educational purposes, I did a little benchmark using ffmpeg-mt compiled with -march=core2. Here are the results:
(My specs are in my signature)
ParkJoy_1080p50.x264.CRF18 x264 rev 1292
ffdshow 3108 ffmpeg-mt || Renderer: VMR9
*User: 1s, kernel: 0s, total: 1s, real: 6s, fps: 260.6, dfps: 74.9
*User: 1s, kernel: 0s, total: 1s, real: 6s, fps: 278.7, dfps: 74.9
*User: 1s, kernel: 0s, total: 2s, real: 6s, fps: 246.5, dfps: 74.5
ffdshow 3108 ffmpeg-mt -core2 || Renderer: VMR9
*User: 1s, kernel: 0s, total: 1s, real: 6s, fps: 256.4, dfps: 76.1
*User: 1s, kernel: 0s, total: 1s, real: 6s, fps: 250.4, dfps: 76.3
*User: 1s, kernel: 0s, total: 1s, real: 6s, fps: 273.9, dfps: 76.1
*User: 1s, kernel: 0s, total: 1s, real: 6s, fps: 299.5, dfps: 76.3
DivX H.264 Decoder Build 08_02_00_00026_Magnolia || Renderer: VMR9
*User: 1s, kernel: 0s, total: 1s, real: 4s, fps: 386.2, dfps: 100.2
*User: 1s, kernel: 0s, total: 1s, real: 4s, fps: 427.3, dfps: 100.5
*User: 1s, kernel: 0s, total: 1s, real: 4s, fps: 421.7, dfps: 100.1
*User: 0s, kernel: 0s, total: 0s, real: 4s, fps: 500.8, dfps: 100.2
ParkJoy_2160p50.x264.CRF22
*User: 7s, kernel: 0s, total: 7s, real: 23s, fps: 67.6, dfps: 21.2
*User: 7s, kernel: 0s, total: 7s, real: 23s, fps: 69.8, dfps: 21.0
*User: 7s, kernel: 0s, total: 7s, real: 23s, fps: 70.3, dfps: 21.2
*User: 7s, kernel: 0s, total: 7s, real: 23s, fps: 69.1, dfps: 21.1
*User: 7s, kernel: 0s, total: 7s, real: 23s, fps: 67.5, dfps: 21.4
*User: 7s, kernel: 0s, total: 7s, real: 23s, fps: 67.8, dfps: 21.5
*User: 7s, kernel: 0s, total: 7s, real: 23s, fps: 68.3, dfps: 21.6
*User: 7s, kernel: 0s, total: 7s, real: 23s, fps: 68.3, dfps: 21.5
*User: 4s, kernel: 0s, total: 4s, real: 16s, fps: 104.7, dfps: 29.5
*User: 4s, kernel: 0s, total: 4s, real: 17s, fps: 106.5, dfps: 29.2
*User: 4s, kernel: 0s, total: 4s, real: 16s, fps: 108.6, dfps: 29.5
*User: 4s, kernel: 0s, total: 4s, real: 17s, fps: 104.1, dfps: 29.2
The difference is not big, especially for the 2160p video. Of course DivX H.264 decoder is the winner in both videos.
For those interested, here is the 3108 core2 build while normal builds are here.
My Specs
XhmikosR is offline   Reply With Quote
Old 18th October 2009, 19:52   #8770  |  Link
tal.aloni
I'm having the same problem with AVC (libavcodec),
while I try to exit the playing application, it crashes,
it only happen with libavcodec (not with ffmpeg-MT), and with rev. 3099 and up, no problem with rev. 3098.
tal.aloni is offline   Reply With Quote
Old 18th October 2009, 20:10   #8771  |  Link
albain
Originally Posted by SamuriHL View Post
@albain:
OK then, I will come to plan B, which is harder and longer to put in place....
Old 18th October 2009, 20:12   #8772  |  Link
SamuriHL
SamuriHL's Avatar
Alright, man. Good luck. I'm sure you'll get it.
Old 18th October 2009, 21:06   #8773  |  Link
STaRGaZeR
4:2:0 hater
I have the same issue.
Specs, GTX970 - PLS 1440p@96Hz
Originally Posted by Manao View Post
That way, you have xxxx[p|i]yyy, where xxxx is the vertical resolution, yyy is the temporal resolution, and 'i' says the image has been irremediably destroyed.
STaRGaZeR is offline   Reply With Quote
Old 18th October 2009, 21:09   #8774  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Similar problem here with latest ffdshow build by clsid. DVBViewer will crash at application exit:
http://pastie.org/659774
Program received signal SIGSEGV, Segmentation fault.
[Switching to thread 3684.0x12b0]
0x6fd844ff in thread_func@4 () from D:\ffdshow\libavcodec.dll
Old 18th October 2009, 21:36   #8775  |  Link
clsid
The FFmpeg changes to w32thread.c must be buggy then. I don't have time to revert it now, maybe tomorrow, otherwise Tuesday.
MPC-HC 2.2.1
Old 18th October 2009, 21:42   #8776  |  Link
Sebastiii
Salut and Bon Courage
I can post now so i have tested with ATI 4350 and Xonar too. I have see longtime after that it must made on 5xxxx series.
So now when the light comes out with 5xxx.
I hope that it will work with 4xxx and Xonar
Encore merci
Thx,
Seb.
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355.
Sebastiii is offline   Reply With Quote
Old 18th October 2009, 21:47   #8777  |  Link
LoRd_MuldeR
Software Developer
Thanks for confirming.
Old 19th October 2009, 08:17   #8778  |  Link
albain
Encore merci
Thx,
Seb.
Merci pour les encouragements, il reste du boulot :-)
@Xonar owners
Can someone confirm me that with Total Media Theatre + a Xonar, you can play a M2TS file with a TrueHD streamin bitstream mode ?
I need to know this answer in order to go further
Thanks
Old 19th October 2009, 12:05   #8779  |  Link
Skinleech
A.K.A Mangoat
@Xonar owners
Thanks
No, you can't I'm afraid. You need to play a BD structure for bitstreaming to work at present.
Old 19th October 2009, 12:13   #8780  |  Link
Blight
Software Developer
Blight's Avatar
clsid:
Any possible stability issues with ffmpeg-mt compared to libavcodec??
Yaron Gur
