Old 26th September 2007, 11:12   #101  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Originally Posted by MR Nice View Post
Can you make your own root menu and also add your own background image?
No menu generation capability, right now. Maybe in the future...
What is this program like for converting nstc 29.97fps to pal 25fps?
Try it and give us your impressions
Q?
Could you please add more "verbosity" to this question?
Can this program convert a batch of avi files?
Yes
Bye
________
justin bieber fans
MrC is offline   Reply With Quote
Old 26th September 2007, 13:34   #102  |  Link
MR Nice
MR Nice's Avatar
Hi, I tried to add 5 avi tv episodes to your program but it will only let me add one avi file. Can you tell me how to add a batch of avi files?
MR Nice is offline   Reply With Quote
Old 26th September 2007, 13:43   #103  |  Link
rendez2k
rendez2k's Avatar
Batch to me means adding 5 separate movies to 5 separate discs. You want to author a full disc, surely with a menu for navigation which AVStoDVD won't do. Theres lots of other tools on this forum alone which will do that.
rendez2k is offline   Reply With Quote
Old 26th September 2007, 14:08   #104  |  Link
MR Nice
MR Nice's Avatar
I mean 5 avi tv episodes onto one dvd. A batch of avis means more than one avi onto one disc not five separate discs. Hope this helps
Old 26th September 2007, 14:10   #105  |  Link
rendez2k
rendez2k's Avatar
As I said, AVStoDVD can't do this. It will accept one movie per job, so you'd need to join them together first, which is probably useless for 5 TV episodes!
Old 26th September 2007, 14:10   #106  |  Link
Delta2
Taking the big brother (VSO) as the master reference, that issue is the most hard task to a free gui to accomplish
- people like speed, with good results, that's a fact
What strategy should a gui use for this ?
A) convert separately, and author all together in authoring stage ?
B) join the movies and subtitles like VDub append segments ?
A) it is only effective if you use 1 pass
5 episodes = 5 passes each
imagine more passes
5 episodes converted at 2 passes = 5 * 2 = 10 passes total
takes a long ... long time
B) it is the best way for fragmented movies, but less effective with episodes due to the limitations of : same bitrate..same samplerate...etc...
correct me if I'm wrong
Delta2 is offline   Reply With Quote
Old 26th September 2007, 16:52   #107  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Yes you hit the point: batch encoding (at least for AVStoDVD - click "Jobs List" on the toolbar) means a series of separated jobs to be done one after one.
Bye
________
VF1100S
Old 28th September 2007, 13:50   #108  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
AVStoDVD release 1.1.2 is available.
Change log:
- Some bugs fixed
- Added AviSynth Crop filter management
- Added AviSynth Tweak filter management
- Added Static Preview (experimental) in AVS Script Window
- Removed "Deinterlace" option in AVS Script Window. Everyone can choose and insert manually their preferred deintelacing filter.
- Added release number in ini file and startup check
- Added "Scene Detection" also to QuEnc encoding ("Very High" and "High" Quality profiles)
- Tested on Vista: OK
As usual, comments and suggestions are welcome.
Bye
________
ipad guides
Old 15th October 2007, 20:32   #109  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Keeping update. Hoping someone is still interested.
AVStoDVD release 1.1.3 is available.
Change log:
- Some bugs fixed
- MediaInfo updated to 0.7.5.3
- Added support to multi core CPU (max 4) by using MultiCoreEnc.exe (available only to QuEnc)
- Added "Settings/System Preference" tab
- Added "DefaultEncodingQuality", "DefaultVideoMaxBitRate", "DefaultAudioBitRate" preferences in AVStoDVD.ini
- Added AviSynth Normalize() audio function in AVS Script
- Revised encoder selection criteria (1): HCenc and CCE SP can be used only for "Very High Quality" encoding
- Revised encoder selection criteria (2): QuEnc is automatically used when choosing "High Quality" or "Standard Quality" encoding
- Revised Audio Time length detection thru MediaInfo
Bye
________
maryjane
Old 16th October 2007, 05:57   #110  |  Link
Dkruskie
Thanks for the update MrC
Dkruskie is offline   Reply With Quote
Old 16th October 2007, 10:26   #111  |  Link
DarkNite
Almost Silent Member
DarkNite's Avatar
Yay for multicore support!
Rethinking the "Why?" chromosome.
DarkNite is offline   Reply With Quote
Old 16th October 2007, 11:01   #112  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Yes, thanks to Mr_Odwin's small&smart utility "MultiCoreEnc.exe"
Bye
________
Yamaha TDM850
Old 17th October 2007, 10:35   #113  |  Link
DarkNite
DarkNite's Avatar
In my first test the encoding took far longer than I thought it should with such a simple script and QuEnc. So I opened the log file and saw this:
<10/16/2007 10:43:43 PM>
WARNING: Cannot find 'C:\Program Files\AVStoDVD\Plugins\MultiCoreEnc.exe'. MultiThread disabled.
I looked in the plugins folder and found this:
MultiCoreEnc_.exe
Once I had renamed the file it worked as expected.
Old 17th October 2007, 18:52   #114  |  Link
MysticE
Nice. Thanks.
MysticE is offline   Reply With Quote
Old 18th October 2007, 08:02   #115  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
MultiCoreEnc_.exe
bug targeted.....
Bye
MrC
AVStoDVD Homepage
AVStoDVD @ Doom9 Forum
Old 20th October 2007, 21:56   #116  |  Link
MysticE
I'm finding 1.1.3 to be a bit confusing. I was hoping it would remember some of my settings, vid bitrate and Muxed MPEG2 Streams output (it does remember the audio bitrate). It also took me a while to figure out why HCenc wasn't being used even though I picked it in settings, although the ability to quickly change to a quicker (with QUenc) encode from the main page has it's uses. And for some reason the preview does not switch to 16:9 (it used to) when WS is chosen.
Old 21st October 2007, 11:22   #117  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Very sorry: my purpose was to make GUI more friendly...
As it is said in the History file, "Quality profile", "Max video bitrate" and "audio bitrate" are remembered. Not Avg video bitrate because it depends from input streams and DVD size choosen.
Yes, by choosing "Standard Quality" or "High Quality" profile, QuEnc is automatically used (1-pass); instead by choosing "Very High Quality" profile, the proper encoder specified in the Settings Window is used (QuEnc or HCenc or CCE SP, 2-passes). I find this change more intuitive and quick to setup project. Don't you?
However in the next release I'm planning to stop CCE SP support (is anyone still using it in AVStoDVD?), to include HCenc in the installer package and to use HCenc as unique "Very High Quality" encoder. What do you think?
I will fix it in the next release.
Bye
MrC
AVStoDVD Homepage
Old 21st October 2007, 13:00   #118  |  Link
bionic
Havent tested much, but if theres no video source file loaded
and you hit the preview in the avisynth script window, avs2dvd throws an runtime error 53 with description file not found Path:\preview000000.jpg and then exits.
Which is of course natural since theres nothing to preview, and why would anyone try to preview nothing, but i thought id mention it anyway for coding completeness
bionic is offline   Reply With Quote
Old 21st October 2007, 14:04   #119  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Right, well done. Will fix it!
Bye
MrC
AVStoDVD Homepage
Old 23rd October 2007, 08:22   #120  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
... Muxed MPEG2 Streams output ...
@MysticE
Since the next release, I will replace DVDAuthor with MuxMan/BatchMux. That means multiplexing m2v+ac3 step is no more necessary. Will removing "Muxed MPEG2 Stream" choice cause you any troubles or may I do it?
Bye
MrC
AVStoDVD Homepage
[IMG] code is Off
