14th January 2006, 03:55 | #101 | Link |
There are older .NET 1.1 versions of megui on the SourceForge Files page
https://sourceforge.net/project/show...d=156112#files. The ones compiled for 1.1 are 0.2.3.1029a and before. |
14th January 2006, 04:16 | #102 | Link |
I know what's up with the native error dialog on startup because I learned it the hard way recently. If you run a .NET application and it crashes with the native error dialog while startup then you got a exception somewhere in the ctor of the startup form, simply use a try catch block and add some logic to handle the exception.
14th January 2006, 12:04 | #103 | Link |
Incorrect time
Problem can be seen in the screenshot here: http://img65.imageshack.us/img65/4308/progress0ql.jpg
The time remaining and time elapsed are both completely wrong. This is using Sharktooths' r399 build. |
14th January 2006, 13:22 | #105 | Link |
clueless n00b
@lexor: you can build your own megui-x264 build.. it should be compilable under 1.1 with no changes except for the compile.bat file.. it has links to the 2.0 compiler (%windir%\Microsoft.NET\Framework\v2.0.50727\csc), replace the v2.0 directory with the name of your 1.1 directory and you should be fine. The full release however will not compile under 1.1. That way, you know you have the same code for both builds and the only thing different is the runtime.
14th January 2006, 13:48 | #106 | Link |
Since I've updated Megui from 02.3.1b to 02.3.2017 the Avisynth Generator doesn't work anymore. It gaves me the error "DGIndex reported......" (see snap1.jpg) when i load the *.d2v file into the generator. When I downgrad again to 02.3.1b all work fine.
14th January 2006, 16:40 | #108 | Link |
When using the AviSynth script creator and choosing an AVI file, a dodgy avs file is generated. The resulting file that is saved is loading up the "temp.avs" file as opposed to the actual video file selected. This means that if i make a few avs files with the generator, they'll all point to teh same temp.avs file, and if i delete the temp.avs file, none of em will work at all.
Gonna make a fix now assuming i can spot the error |
14th January 2006, 16:41 | #109 | Link |
I'm at a loss at the apathy towards this issue. I mean don't you guys share your computer with other family members? An encode that takes 12 hours for first pass and 15 hours for second, bound to conflict with your family's desire to use the mahcine. Doom I know you have win xp installed, don't you get this problem with user switching? I mean it's so easy to check, just start some job, switch users and switch back again. What's this suddent need for me to be a compiler and debugger? Someone must have old sharktooth's build lying around (sharktooth for one), I'm willing to put up time for testing an reporting, but I have neither energy nor time to pretend like I'm one of the developers.
Geforce GTX 260 Windows 7, 64bit, Core i7 MPC-HC, Foobar2000 |
14th January 2006, 17:13 | #110 | Link |
Mr. Sandman
Another bug (MeGUI-x264):
Menues vanished and same problem as the previous bug.
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 14th January 2006 at 18:06. |
14th January 2006, 17:14 | #111 | Link |
@lexor: I'll try to take a look at it, but i'm really new to MeGUI, so i spend a lot of time just browsing the code trying to get a feel for it. Webpages are no bother to me, they're simple as compared to Windows applications
14th January 2006, 17:51 | #112 | Link | |
clueless n00b
In addition, wouldn't it be reasonable that YOU would first try on another box before pointing the finger at us? While I'm very possessive of my box and would never let anybody else us it, just for you I created another user account. Then I started encoding on my primary account (an admin account), switched to the second one.. encoding kept going. Then I aborted, went to the second account (one with limited privileges), started megui there (the latest CVS checkout.. done just 10 minutes ago, built with the compile script that comes with it), then switched back to the account I'm typing this from. I see from the CPU usage that encoding is still going strong, in fact, it hardly takes a performance hit at all since I only have a few resource-friendly apps running. By the way the job I'm encoding is a standard x264 one with all the default settings, and my x264 build is revision 389 from Sharktooth. Bottom line, I can't reproduce it.. it works as it's supposed to.
14th January 2006, 18:14 | #113 | Link | |
14th January 2006, 18:30 | #114 | Link | |
clueless n00b
However, the point is now moot because the problem seems unreproducible.. perhaps you can make the same experiment I did (MeGUI is still encoding on the secondary account and has been throughout my dinner).
14th January 2006, 19:04 | #115 | Link |
Well I'll be damned, it is fft3dgpu that's incompatible with user switching, but I did test it without that filter before though, and it would still break, now it does not. I reinstalled Std package since then though. Perhaps that first time it crashed it corrupted some files while writing to them? Dunno, anyway sorry for the inconvenience.
And for the record I never asked anyone to compile anything for anyone at any point, all I wanted was old .7z or Sharktooth's, that's all. I'll go bug fft3d dev now
14th January 2006, 21:46 | #116 | Link |
Since a few versions (0.2.3.2017 if I remember correctly) I do not get the FPS displayed in the Progress Status window when encoding with x264. All the other parameters (current video frame, video data, projected filesize, time elapsed and time remaining) are correctly displayed with version 0.2.3.2022.
14th January 2006, 22:18 | #118 | Link |
clueless n00b
@Pasqui: they use a comma as decimal separator in your country, correct?
14th January 2006, 22:28 | #120 | Link |
clueless n00b
Do you remember the old problem where you never got a status update? This is the same.. the fps parser chokes because I forget to force the neutral locale that uses the dot as decimal separator. But I set up all line parsing to catch all errors and just return 0.. that's why you get the rest of the updates. The progress is directly calculated by MeGUI and not taken from the x264 commandline.. that's why you have that.
