3rd November 2018, 19:14 | #1222 | Link |
There was a new release by gispos: https://forum.doom9.org/showthread.php?t=175823
17th July 2019, 17:32 | #1223 | Link |
ByteShare
NekoPanda also has a version that works with their AVIsynth Neo version: https://github.com/nekopanda/AvsPmod/releases
4th April 2020, 15:31 | #1225 | Link |
Hi everyone - be gentle with me, I'm feeling a bit tender after finally (re-)starting my VHS tapes to digital program.
I treated myself to a new Windows 10 PC and so I'm dedicating my old(er) Windows 7 64 bit machine to the task. On my (even older) XP machine I used a Dazzle connection but the drivers don't exist to use it on 7 so I got an ezcap and after quite a few stumbles, managed to get a test .avi. I decided to follow Andrew Swan's tutorials which include using AvsPmod and have followed his install instructions and .avs template - 1 SetFilterMTMode ("QTGMC", 2) 2 FFMPEGSource2("D:\filename.avi", atrack=1) 3 ConvertToYV12() 4 AssumeBFF() 5 QTGMC(preset="Slower", EdiThreads="2") 6 BilinearResize(720,576) 7 Prefetch(7) I fall at the first hurdle though as when I click on the video timeline, I get an error message – Cannot load a 32 bit DLL in 64 bit Avisynth: ‘C:/Prgram Files (x86)/AviSynth+/plugins64+/mscvcm90.dll’. (D:\Avisynth\Template.avs, line 2) I’ve gone back over the install instruction from a number of sources but can’t get past it. I’m thinking that the .dll is the video playback and there may be things linked to that which are causing the problem. Any ideas? |
4th April 2020, 20:12 | #1226 | Link | ||
Avisynth 64 bit can only use 64 bit plugins, 32 bit only 32 bit plugins. [Not all plugins have 64 bit versions].
What is "D:\Avisynth\Template.avs" ? FFMPEGSource2 requires FFMS2.avsi in plugins. (as well as ffms2.dll)
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 4th April 2020 at 20:14. |
5th April 2020, 14:50 | #1227 | Link | |||
5th April 2020, 15:59 | #1228 | Link | |
7th April 2020, 12:04 | #1229 | Link |
Audio preview in AvsPmod
I have a project on the go which requires edits based more on soundtrack than pictures. Is there anyway to preview a trim operation in both video and audio?
I realize that I can do this with an external player but that is extremely time consuming, having to scroll through to find the edit point each time. Ideally I need to play the video and audio from a few frames before the currently selected frame, to a few frames past it. I imagine I could launch an external player in a macro, but how do you tell the player to start at a predetermined frame rather than frame 0? Any ideas please? |
8th April 2020, 22:55 | #1231 | Link |
Big Bit Savings Now !
Waveform()
10th April 2020, 16:34 | #1232 | Link | |
Traceback (most recent call last): File "AvsP.pyo", line 5329, in OnClose File "AvsP.pyo", line 7195, in ExitProgram File "AvsP.pyo", line 7820, in SaveSession IOError: [Errno 13] Permission denied: u'C:\\Program Files (x86)\\AvsPmod\\_last_session_.ses' I have now changed the permissions for that folder and all is well. Looking forward to my first file! I haven't done anything fancy, just the bare minimum, having mooched around in the forums, it looks like it's a very, very long piece of string - you guys amaze me. |
30th August 2020, 19:28 | #1234 | Link |
App Digger
AvsPmod 2.6.3.5 GPo x64 fails to load with the following error log in error_log.txt:
Traceback (most recent call last): File "run.py", line 49, in <module> File "avsp.pyo", line 19771, in main File "wx\_core.pyo", line 8622, in __init__ File "wx\_core.pyo", line 8187, in _BootstrapApp File "avsp.pyo", line 19758, in OnInit File "avsp.pyo", line 5412, in __init__ File "avsp.pyo", line 13471, in LoadSession File "avsp.pyo", line 13559, in LoadTab KeyError: 'bookmarks' Windows 10 Home build 19041.450, x64 AviSynth+ 3.6.1 (installed) I rolled it back to 2.6.3.4 and it works OK. |
30th August 2020, 21:31 | #1235 | Link | |
The sessions saved with the previous version cannot be opened with the new version. So you have to save a new session first, then there should be no problems. If it is absolutely necessary to open the old sessions with the new version, I can fix that. The AvsPmod thread of the newer versions is here.
Live and let live |
22nd January 2021, 02:26 | #1236 | Link |
Trimming has been somewhat broken since 2.6.6.0. I have to revert to 2.6.5.3 to make it work properly. Hope there's a fix soon!
https://www.youtube.com/watch?v=DvqWM-jcBgM |
22nd January 2021, 09:25 | #1237 | Link | |
https://forum.doom9.org/showthread.php?t=175823 |
22nd January 2021, 12:39 | #1238 | Link | |
In the youtube video I can't follow your fast moves so please explain the error to me in more detail. I found one mistake, but it is probably not the only one. And please post in the thread that arestarh has linked. I sent you a private message.
Live and let live Last edited by gispos; 22nd January 2021 at 13:08. |
12th July 2021, 17:06 | #1240 | Link |
Check last ver?
https://forum.doom9.org/showthread.p...84#post1946784 |
