Old 24th January 2016, 07:05   #1  |  Link
LilWiz
QTGMC help for a complete beginner having serious struggles...
Hi all. About 2 weeks ago I posted this thread to the Sony Vegas Creative COW forum asking for ideas as to how I could take interlaced TV footage and convert it to 50fps video I can use in Sony Vegas. The deinterlacing methods available in Vegas are primitive and I'm looking to get the best out of the footage I've got. In summary, I want my 1080i (or 576i occasionally) video to be editable in 50fps unlike the 25fps I'm usually forced to work with. The footage I use appears best when using the 'Bob' deinterlacer in VLC.
It was suggested in the thread I posted to look into QTGMC with Avisynth ('in conjunction with VirtualDub', of which I can't appreciate the relevance at this point). I read the absolute basics on the wiki, downloaded the skeleton, but got stuck at the point it asked me to load an .avi file, which I rarely come across in my editing. I tried to find a plugin that would allow me to load .ts files, but had no luck, when windows media player told me it could not open the file. I used an .avs file that read this:
LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\ffms2.dll")
FFmpegSource2("x:/filename.ts")
I have absolutely no idea if this is even a good start for what I want to do. This was after I had downloaded all the required plugins for QTGMC as outlined by the avisynth wiki. These were all downloaded from assorted websites, and as such I didn't feel confident from the outset. I also didn't even know what was going to be the result if I was successful... would it just open the video file in Windows Media Player with a filter applied? How do I capture the video with these filters permanently applied?
I'm looking to start fresh, and I am extremely keen to learn and would be incredibly grateful for any help I may get from this forum. I'm not sure if many people come here with no previous posts looking to get quick answers, but I understand how annoying that may seem. I'm hoping to get a working solution within maybe a week, but Avisynth appears to be an extremely helpful resourse - as of now I use MediaCoder to trim and convert footage, so I'd love to replace this with a more all-encompassing method.
I've probably left some important information out, so if this is super vague I'm happy to expand on it. Thanks
Also, if anyone wants an example of the kind of footage I'm dealing with, I took a section from a 576i video using VLC and uploaded it to MEGA here. It's from a football game, so safe for work.
LilWiz is offline   Reply With Quote
Old 24th January 2016, 08:38   #2  |  Link
ChiDragon
ChiDragon's Avatar
This would be where VirtualDub comes in. You open the AVS file in that and save an intermediate AVI file for editing (preferably in a lossless format).
Your script is wrong. Read the docs for FFmpegSource2 for more info on proper usage.
Here is one way:
FilePath = "x:\filename.ts"
A = FFAudioSource(FilePath)
V = FFVideoSource(FilePath)
AudioDub(V,A)
There will be a delay while the file is indexed before it opens.
LoadPlugin is redundant because you already have the plugin in the autoload directory. But leaving it in wouldn't cause a problem.
ChiDragon is offline   Reply With Quote
Old 24th January 2016, 11:19   #3  |  Link
BakaProxy
Well you can create a script and open it in a media player and it will just play the video with said filters applied (assuming there weren't any errors in the script). If you want to render the script so you can use it in vegas then you have a couple of choices: open that script in virtualdub and save it as avi (this can be lossless or lossy depending on the codec you choose in virtualdub, IIRC the default is uncompressed), otherwise you can use x264 (or really most command line encoders have support for avisynth and if they don't there are workarounds for that) to input the avisynth script or you can use a gui for x264 or so like megui.
Also with a .ts source I'd suggest using dgindex (or variants) as source filter, don't think ffsource even supports .ts sources properly.
Verstuurd vanaf mijn SM-A500FU met Tapatalk
BakaProxy is offline   Reply With Quote
Old 24th January 2016, 11:43   #4  |  Link
Groucho2004
As for a suitable script for the sample you posted, this looks pretty good to me:
LWLibavVideoSource("vlc-record-2016-01-12-21h36m08s-20160110 rangers-cowdenbeath english.ts-.ts")
a = LWLibavAudioSource("vlc-record-2016-01-12-21h36m08s-20160110 rangers-cowdenbeath english.ts-.ts")
AssumeTFF()
QTGMC(Preset="Slow")
AudioDub(last, a)
This will result in a 50 fps clip. If you need the original 25 fps, add "SelectEven()" after the QTGMC() statement.
Old 27th January 2016, 09:16   #5  |  Link
LilWiz
Thanks very much for all the helpful and prompt replies everyone! I redownloaded the QTGMC plugins and got the LSMASH plugin also (hopefully I have done everything corrrectly!)
I feel far closer to success than before! As Groucho suggested, my .avs file now reads:
LWLibavVideoSource("x:\vlc-record-2016-01-12-21h36m08s-20160110 rangers-cowdenbeath english.ts-.ts")
a = LWLibavAudioSource("x:\vlc-record-2016-01-12-21h36m08s-20160110 rangers-cowdenbeath english.ts-.ts")
AssumeTFF()
AudioDub(last, a)
As for understanding what's written here, I am on track with that, I think my minute experience in coding (albeit with Python) means I pretty much get it. However, I must still have a problem somewhere. When opening the .avs file with Windows Media player, it no longer brings up a Script error message! However, only audio plays, no video. When attempting to open with VirtualDub, I get the same error message I have been getting since install:
AVI Filter Import error: (Unknown) (80040154)
There may be a couple problems I need to address here. I have read that this error may mean I need to reinstall avisynth?
Once again, thanks for the prompt and extremely helpful replies guys!
EDIT: Here are the contents of the avisynth plugins folder, just in case it's relevant.
There are probably a couple of plugins in there that are unnecessary; should I leave or remove them?
Old 27th January 2016, 09:21   #6  |  Link
ChiDragon
ChiDragon's Avatar
Be sure to use 32-bit VirtualDub when you are using 32-bit Avisynth.
Old 27th January 2016, 09:28   #7  |  Link
LilWiz
D'oh! Getting the correct version now.
Old 27th January 2016, 10:23   #8  |  Link
LilWiz
The file is now opening in VirtualDub! Plus it looks excellent.
I do have one slight problem, and I guess it might not be relevant in this thread any more, but the projected output file size if I choose to save as an avi is around 4.5Gb, over 100x the size of the original file! Maybe I should have expected this, but is there a way to cut down on this size? It seems ridiculously large, doesn't it? 1080i clips would be huge
Old 27th January 2016, 10:38   #9  |  Link
kuchikirukia
You have 45MB turning into 4.5GB? That's... interesting.
kuchikirukia is offline   Reply With Quote
Old 27th January 2016, 11:34   #10  |  Link
Groucho2004
First you have to decide what target format you want. You probably selected "Uncompressed RGB" in VDub which explains the huge size.
Old 27th January 2016, 11:43   #11  |  Link
LilWiz
Here's some more info.
The original file details are below:
General
ID/String                        : 30559 (0x775F)
CompleteName                     : x:\vlc-record-2016-01-12-21h36m08s-20160110 rangers-cowdenbeath english.ts-.ts
Format                           : MPEG-TS
FileSize/String                  : 38.0 MiB
Duration/String                  : 1mn 16s
OverallBitRate_Mode/String       : Variable
OverallBitRate/String            : 4 148 Kbps
Video
ID/String                        : 69 (0x45)
MenuID/String                    : 1 (0x1)
Format                           : MPEG Video
Format_Version                   : Version 2
Format_Profile                   : Main@Main
Format_Settings_BVOP/String      : Yes
Format_Settings_Matrix/String    : Custom
Format_Settings_GOP              : Variable
Format_Settings_PictureStructure : Frame
CodecID                          : 2
BitRate/String                   : 3 749 Kbps
BitRate_Maximum/String           : 15.0 Mbps
Width/String                     : 704 pixels
Height/String                    : 576 pixels
DisplayAspectRatio/String        : 16:9
FrameRate/String                 : 25.000 fps
Standard                         : PAL
ColorSpace                       : YUV
ChromaSubsampling                : 4:2:0
BitDepth/String                  : 8 bits
ScanType/String                  : Interlaced
ScanOrder/String                 : Top Field First
Compression_Mode/String          : Lossy
Bits-(Pixel*Frame)               : 0.370
TimeCode_FirstFrame              : 13:32:37:19
TimeCode_Source                  : Group of pictures header
Gop_OpenClosed/String            : Open
StreamSize/String                : 34.2 MiB (90%)
Audio
ID/String                        : 68 (0x44)
Format                           : MPEG Audio
Format_Version                   : Version 1
Format_Profile                   : Layer 2
CodecID                          : 3
BitRate_Mode/String              : Constant
BitRate/String                   : 192 Kbps
Channel(s)/String                : 2 channels
SamplingRate/String              : 48.0 KHz
Video_Delay/String               : 8ms
StreamSize/String                : 1.75 MiB (5%)
Language/String                  : English
And here's what the screen shows in VirtualDub:
EDIT: Okay, so I need to change the codec in the Compression menu? I have 7 other options, I'll see how it looks with some of those. Thanks again!
Old 27th January 2016, 11:55   #12  |  Link
Groucho2004
Yes. However, the options that VDub comes with are very limited. As I wrote, first decide what target format you want. This choice mainly depends on the playback device you are going to use. Also, VirtualDub can be configured to use external encoders like x264.
Old 27th January 2016, 12:03   #13  |  Link
LilWiz
Yep, got it. I downloaded the XviD codec because the others weren't going to work, and so far so good. If I don't reply, everything worked out! Thanks again for your patience Groucho! I'll make sure to come back here for a browse next time I have some queries or things I'm looking to learn
Old 27th January 2016, 15:10   #14  |  Link
ChiDragon
ChiDragon's Avatar
It's silly to use XviD as an intermediate codec these days (and probably ever).
You originally said "I'm looking to get the best out of the footage I've got." That would mean using a lossless intermediate, in 4:2:0 if your sources are all transport streams -- and assuming Vegas can properly handle 4:2:0 with whatever editing/filters you will be applying.
Use Fast Recompress in VirtualDub to avoid conversion to RGB. A lossless 4:2:0 file will still be much bigger than your input, but a fraction of uncompressed RGB. My personal favourites are Ut Video and MagicYUV, but there are others.
Old 14th December 2017, 21:32   #15  |  Link
abolibibelot
That thread is quite old, but I'm surprised noone mentioned AVFS : you can avoid having to export a huge intermediate lossless file by opening the AVS script with Avisynth Virtual File System, which, as its name implies, will create a virtual uncompressed file in a "C:\Volumes" directory. It won't occupy significant space on the system partition (despite the huge size displayed in Windows explorer), but it will behave just like an uncompressed video file created with the same Avisynth script would : you can read it with a media player, or you can directly import it in any non-linear editing software. You may need to configure ffdshow for raw YUV footage to be recognized by those softwares (ffdshow video decoder configuration > Uncompressed video > toggle "all supported formats").
http://turtlewar.org/avfs/
abolibibelot is offline   Reply With Quote
qtgmc
