24th March 2009, 23:30 | #121 | Link | |
н∂-ƒαиαтι¢
^ its not buggy really it does what it says.
25th March 2009, 01:53 | #122 | Link |
Author of BDSup2Sub
I'll change this in 2.4 amongst a couple of other things.
@Pati: there'll also be better (yet not nearly perfect) support for faded HD-DVD captions. I'm too tired now and want to do some more testing, but chances are 2.4 will be released tomorrow. |
25th March 2009, 18:37 | #124 | Link |
Author of BDSup2Sub
25.03.2009 2.3 -> 2.4
25th March 2009, 19:27 | #125 | Link |
too much lurking
Would it be possible for you to include a changelog with each version? With the blazing rate at which you are making updates it's getting difficult to keep track of the progress and what version I currently have.
Also, when switching to a new version is it OK to keep the .ini from the previous version? Thanks for the great tool! |
25th March 2009, 19:38 | #126 | Link | |
I had problems pre 2.1 I believe it was with sup's showing in PowerDVD 8 and MPC-HC from TSMuxer's BD output but since 2.1 I haven't had an issue. I haven't been able to test on a standalone yet. 0xdeadbeef: If you are looking for SMlabs a developer has been active in in this thread lately another way to reach them is by email tsmuxer@smartlabs.tv Last edited by turbojet; 25th March 2009 at 19:52. |
25th March 2009, 20:32 | #127 | Link |
Thanks for version 2.4! I quickly tested the fade-in/fade-out SUP, and the subtitles are now visible, great!
However, the durations do not seem to be correct yet, and most of the time the subtitle stays visible half-transparent for what seems like much too long. Perhaps this is the fade-out problem you mentioned? Anyways, this is a big step forward, thanks! Pati |
25th March 2009, 20:33 | #128 | Link | |||
Author of BDSup2Sub
26th March 2009, 08:20 | #131 | Link | |
Though, since you have the exact same file that I am using as test material, perhaps my reporting my test results is not that informative or useful, so I'll just silently follow your progress from now on. Thanks! Pati |
26th March 2009, 18:29 | #132 | Link |
Author of BDSup2Sub
26.03.2009 2.4 -> 2.5
27th March 2009, 07:55 | #134 | Link |
Since 2.4 this colored sup is recognized as yellow, it should be a turqoise blue. When outputting to idx/sub it looks ok in yellow, when outputting as sup it looks like yellow with orange spots. Could you take a look?
27th March 2009, 11:14 | #135 | Link | |
Author of BDSup2Sub
Do you mean 2.5?
Since you complained about 2.4, but probably mean 2.5, I'm pretty uncertain how to handle this complaint. Do you complain that the colors are different in 2.4 and 2.5 (which they should be) or did you compare 2.4/2.5 to the real BD in a standalone player and found that 2.4 was correct while 2.5 was not? This would really puzzle me though since my PS3 shows the colors exactly like 2.5 does. As I changed the order of Cr/Cb components in 2.5 when reading SUPs, I somehow forgot about writing SUPs. I already fixed it locally though. |
27th March 2009, 12:33 | #137 | Link | |
Author of BDSup2Sub
And did you really compare the SUP as displayed by 2.5 to the output of a standalone? If so and you still say that the colors displayed by 2.5 are wrong, this really leaves me puzzled. Then either my PS3 or your standalone shows wrong colors or I'm totally missing something else. I'm already playing with the idea of a "swap Cr/Cb" option for the conversion dialog... |
27th March 2009, 12:57 | #138 | Link |
2.0-2.2 also output the correct colors. I didn't test in a standalone, don't have one here. But with any luck at all I can test it in a couple this weekend.
MPC-HC, PowerDVD, suprip, vobsub resync are what I've been using to detect the colors which also matches what BDsup2sub gui displays. Does Iron Man subs display wrong color in v 2.0-2.3? |
27th March 2009, 13:21 | #139 | Link |
Author of BDSup2Sub
As I already said: version 1.0 until 2.4 did use the same order of color components and therefore display the same colors. These colors are wrong (swapped Cr/Cb) when compared to what my PS3 displays - which I couldn't test until I got "Iron Man" which was the 1st BD with colored captions that I got my hands on. As I discovered this, I swapped Cr/Cb in 2.5 and now colors in BDSup2Sub 2.5 are identical to what my PS3 displays when the original BD is played.
So as I said: either the PS3 is wrong (which seems extremely unlikely) or your player(s) are wrong. Hard to tell without a 2nd standalone. Anyway: I added a menu option to swap Cr/Cb manually. 27.03.2009 2.5 -> 2.6
27th March 2009, 13:39 | #140 | Link |
Swapping Cr/Cb fixed it in 2.6 thanks.
Actually I downloaded 2.4 from videohelp just now and it handled it correctly, I obviously wasn't paying much attention to the version in title bar, you are right 2.5 is where the issue started. Last edited by turbojet; 27th March 2009 at 13:43. |
