17th February 2013, 05:49 | #4401 | Link |
After further investigation, this might just be an issue with batch converting. I tried converting a few files individually and they appeared to come out fine. I noticed this because I set the resolution first and then when I load the vob file, it auto changes the resolution to 384, and I have to manually change it back to 400. So, probably when batch converting, it's auto changing all the files to 384 and I don't have a chance to change it back to 400. Does anybody know on batch converting if there is a way to lock in the resolution, so that StaxRip can't change it?
17th February 2013, 14:01 | #4402 | Link |
it tries to resize while keeping the original aspect ratio as closely as possible.
scaling to a given resolution would either mean distortion of the image (i.e. changing the ar) or cropping into the image. which one do you want and why? black bars at two edges of the screen are normal, since it would be rather lucky to have content and screen ar match exactly. i would recommend to not do weird things during encoding, but rather during playback. i think in mpc you can do both, scale disregarding ar and "touch screen from outside", which keeps ar but crops away part of the image to completely fill the screen. |
17th February 2013, 18:43 | #4403 | Link |
It's not like I'm trying to crop the black bars off of a 2.35:1 AR movie and then stretching the frame to fill my screen. These are 1.85:1 AR movies that usually fill the screen but sometimes they have really thin borders around them that I like to crop off. They are so thin that they don't distort the picture at all when cropped, but they just annoy me.
19th February 2013, 05:32 | #4404 | Link | |
19th February 2013, 11:26 | #4406 | Link |
I have a problem with x264 ripping:
Since a few days I get a Windows message "H.264 (MPEG-4 AVC) encoder has stopped working" (APPCRASH in x264.exe v0.128.2216.9, module yadif.dll v1.7.0.0) every time I try to rip a HD x264 (mkv) to a lower resolution/bitrate one. Preset is 2Pass -> x264 Film Slower. The error occurs at around 40% of the first pass. I replaced the StaxRip folder with a redownloaded version. I tried a newer version of the x264.exe. Both didn't help. Any suggestion? Thank you |
26th February 2013, 23:21 | #4407 | Link |
Audio out of Sync in StaxRip
I think StaxRip is a great encoder program, it's just a pity that the audio is coming out of sync often when converting DVD. It's strange that only some DVD causes this. Do you have any tips to overcome this problem? I'm converting the sound from AC3 to AAC, 192 kb/s, VBR. And the audio is equally out of sync whether I'm using eac3to, besweet, or ffmpeg.
27th February 2013, 07:16 | #4408 | Link |
Rip the main movie only with DVDfab, is audio still out of sync if you encode this?
MultiMakeMKV: MakeMKV batch processing (Win) MultiShrink: DVD Shrink batch processing Offizieller Übersetzer von DVD Shrink deutsch |
27th February 2013, 18:57 | #4411 | Link |
It's just that I convert to mp4. So I guess that means that I cannot use MakeMKV to rip DVD's. None of the ripped DVD's have sync problems. It's only when converting to mp4 with StaxRip. When converting the same DVD's with Handbrake, they are in sync!
27th February 2013, 19:52 | #4412 | Link | |
Look here: http://forum.doom9.org/showthread.ph...34#post1609334 Cheers manolito |
27th February 2013, 21:06 | #4413 | Link |
Ok, then I'll try MakeMKV. Does it demux the video and sound before putting it in the mkv container?
I have managed to isolate the problem a bit with StaxRip and audio-out-of-sync. I demuxed the video with DGIndex, and the ac3 sound-file which it came out with is out of sync. In the film the sound starts at 3 sec. While in the demuxed .ac3 it starts at 1.42 sec. So it is DGIndex which has a audio problem. And StaxRip use DGIndex. |
27th February 2013, 21:16 | #4414 | Link | ||
Cheers manolito |
28th February 2013, 07:58 | #4415 | Link |
I had sync issues back then with AutoGK I attributed to "leftovers" from some of the more aggressive copy protections. Fengtao wrote on his board that ripping main movie only would definitely remove any copy protection from a movie and since I'm doing this I've run into no sync issues with my encodes.
28th February 2013, 20:54 | #4416 | Link |
Now I've tried a solution that worked. I re-encoded the .ac3 sound in MeGUI, and added a delay (the difference in sec.). I re-encoded to .ac3 using the ffmpeg choice in MeGUI. And then I used the fixed audio in StaxRip when encoding the video. Finally I got a video with the audio (aac) in sync! I converted the sound to aac in StaxRip.
I've also tried MakeMKV to ripp the dvd, and then I used MKV extract GUI-2 to demux mpeg2 video and ac3 sound. But when I play the mpeg2 video it doesn't look nice. Last edited by brusno; 1st March 2013 at 22:34. |
1st March 2013, 22:38 | #4417 | Link |
But, when I play the files while they're in the mkv container it shows well. And audio and subtitle are in sync too. And also when encoding with staxrip directly from mkv container, the result is good. So I guess it's not wise to extract mpeg2 and sound from mkv container with mkv extract gui. Last edited by brusno; 1st March 2013 at 22:58. |
9th March 2013, 19:32 | #4419 | Link |
I'm trying to use the auto crop function and it doesn't seem to work properly. After loading the source file it always disables cropping and my aspect ratio error is over my limit of 2 (Please see the log attached) Have you ever encountered this? Regards Last edited by Bogg; 9th March 2013 at 19:37. |
gui, h.264, h.265, hevc, mkv, x264, x265 |
